Zebra Eltron Orion LP2443 Thermal Printer Logo
Posted on Sep 19, 2008
Zebra LP2443 My Zebra printer will only print 1 label at a time. If I try and print multiple labels they come out totally gray. Can't see the print or anything.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 16, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
352
Points
Gjgjgfjyikjiyytfityuytutyu
2 partial labels being printed on 1 label
most likely to do with sensor --- label has a notch in it it in middle make sure it is clean --- do labels have a hole that align with sensor?
Look at Cleaning printer to locate sensor
http://www.zebra.com/content/dam/zebra/manuals/en-us/printer/ql-qlp-qrg-en.pdf
DO I need the software for the zebra eltron lp2443 printer pluse the driver
The only software you need for the LP2443 is the driver from http://www.seagullscientific.com/aspx/thermal_printer_list.aspx#Zebra
Install this driver, then you can use any windows application that uses win drivers.
Or you can download Zebra designer software to design labels from
http://www.zebra.com/id/zebra/na/en/index/products/software/label_design_software/zebradesignerpro/zebradesigner.html
Won't print
This printer is Thermal Direct (DT) only (ie it does not use a ribbon, the paper is thermally sensitive).
Check your labels are DT material by quickly running the edge of your fingernail across the surface. If it leaves a black mark then it is the right material, if no mark then it is not the right material, contact a label reseller for DT labels.
ie www.lancerlabels.co.uk
1helpful
Prints only part of label
Fixed problem. Labels were too thin so LED was still being detected to stop progress of labels. Fixed by sticking some backing paper over the sensor and seems to be working fine.
3helpful
2answers
I can't find a driver for my ELTRON LP2443PSA thermal label printer. Please help
Please send me an e-mail to: [email protected]
With the subject line: Eltron Orion LP2443 PSAT Label Printer, and I will be more than glad to help you.
If you will use this subject line, then it will be easier for me to identify that the message that you are going to send me is NOT spam message. Because I get a lot of junk mail per day. Which is about 75% of the total e-mail's that I get in my inbox every day. And usually I do not have time to go through reading all of my messages, so if the message title will look suspicious, or all capital letters, or all small letters, than I may flag your message as "Spam".
I have the same exact printed which I also bought at the end of January, 2009, which I originally received without any drivers at all, but after I spend a lot of time looking, and with hard work, I finally found the correct drivers that I use for this same exact Thermal Label Printer.
Also, just a suggestion: If you are going to use this printer for shipping online, then you can go to www.UPS.com, and get free Thermal Shipping Labels to use with UPS shipping service.
Currently, I have 2 completely compatible working drivers for this label printer. 1 of the drivers is for Windows 2000, or earlier systems, and the other driver is for Windows XP, or later operating systems. I use the second driver, with Windows Vista, and I have no problems using my Thermal Label Printer.
Therefore, I do not remember where I exactly downloaded the 2x drivers for this Thermal Label Printer, and do not have enough time to upload them online, because I am very busy, but, I do have 2x of the drivers downloaded on my computer, in it's own folder, that I can upload later on to some online file sharing site, like www.mediafire.com.
So, if you still need the drivers for this Thermal Label Printer, please send me an e-mail, and I will be more than glad to help you with both getting the drivers, and if I will have time, or if it won't take me very long time, Installing this Thermal Label Printer on your computer.
Hope I could help you. Thank you very much.
Zebra LP2443 thermal label printer wont print
Hi Buck,
What type of labels are you using?
Cheers
Bob
12helpful
2answers
My printer display keep showing " Warning, Ribbon in", cannot print multiple label at a time
i have the same problem , but my printer is ZEBRA S4M ZPL
my solution is:
in your barcode software: change printer settings: 1 and 2
1 . in media setting : change media type --> Thermal transfer
2. in documents options , configuration --> use printer settings
by Lin Yu Hsien
2answers
The print out aligned left on Zebra LP2443 Orion
If you can tick rotate 180° in your driver then this should solve your problem
Z6M printing issue
try adjusting the presure of the printhead
here is the site for the manual
http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html
good luck
Top Zebra Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
ExpressFiX
ExpressFiX
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
