Question about Sharp Office Equipment & Supplies
How do I change the developer in a Sharp sf2022 copy machine?
  • 97 Answers
- If you have Manual please read carefully and follow the instruction.
- If you know how to change the Toner Cartridge? the same procedure also the developer.
- Developer located at the Toner Cartridge side
Posted on Sep 23, 2008
Sharp photocpi machine ar5520d devloperisdamage after 4 days
The developer was improperly installed. Please install developer type sharp ar205dv.
Jan 20, 2013 | Sharp AR-5520N
Hello, how to enter SP mode at copier SHARP AR122 ,AR152 ,AR153 ,AR157 , i need reset service call and developper change after 30K copies, or have anybody service manual to download ? please
Hallow, mostly when you see signs on the machine, its always good to obey their meaning for copier reliability. When the copy quality is good and the service and developer signs appear, you can continue working and ignore them but if they offend you, then here is the way to reset;
  1. Press C then density then C then density keys in that order. Display must go off if not repeat till it does.
  2. For service call reset, enter 20 then press copy key then 1 then copy key.
  3. For developer reset, repeat 1 above and enter 24 then copy key then 3 then copy key.
  4. Turn the copier off then on and the signs will not appear.
Dec 10, 2010 | Sharp AR-153E Copier
Need to know how to add developer power to a sharp ar-208d. my copies are all coming out blank
No need developer.When your machine need developer,it show developer signal.blank page print means,charger problem please check corona wear may be it broken or displace.
Jan 07, 2010 | Sharp AR-208D Printer
The diagnostic window on my sharp copier sf2022 displays H4. What does this mean. Nothing is working.
Hello sir; H4 it means fuser unit temporature too high, it can be reset the procedure as follow; Press '' clear" "pause" "0" "pause" then enter 14, press print. it should take care of you.
Nov 21, 2009 | Sharp Office Equipment & Supplies
After changing toner on my sharp, SF-2022 copy machine, the copies are coming out with black smudge marks across the paper? how/where should i clean?
This means the machine is over-toning ie using more toner than required caused by either improper toner or different brand of toner. The correct toner is sf 222T1. Replace developer and use the right toner and clean the drum and its blade. You may need to clean fuser rollers for cleaner copies.
Nov 13, 2009 | Sharp Office Equipment & Supplies
Solution for "CH" code given by the copier Sharp SF2022
Hello sir; CH code means somewhere the door open , it seems like right hand side door did not close right.
Feb 13, 2009 | Sharp AL 1631 Copier
Sharp ar-235 doble image in the copy
1.Might be a fuser problem. Check the upper fuser roller not to have toner on it.
2.The quenching lamp, if any, might be burn out.
Oct 19, 2008 | Office Equipment & Supplies
Sharp ar5320 developer reset code
The developer doesn't have a reset code.  It uses a calibration program instead with the reset integrated into it.
Even though the copy quality is fine for now, it can change in the next few days.  You should order some developer.
Sep 16, 2008 | Office Equipment & Supplies
"maintenance needed" after so many copies
I hate this machine. Right now I can't print. It tells me to change the tray when I try to print.
Mar 13, 2008 | Sharp AR-M162 All-In-One Laser Printer
62 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
