Question about Kenmore 56549 / 56542 / 56544 / 56546 Side by Side Refrigerator
Door handle loose on 10656542400 kenmore
The door handle is seperating from the door and is loose. How can I correct this?
  • 2 more comments
  • collinslc1 Oct 16, 2008
    there are no caps on this model. you can see some type of spring clips under the handle but I cannot figure out how to release and tighten. Hope someone else knows how to fix this particular model.
  • Anonymous Nov 20, 2008
    I'm not understanding the desription. Anyone got a picture or a diagram?
  • Anonymous Mar 25, 2009
    We have a Kenmore (model106.56676501) side by side refrigerator with a loose door handle. The handle is separated at the top and the entire handle is loose.
    We tried lifting handle toward ceiling to remove, but cannot move it.
  • huffman2 Mar 31, 2009
    I have been lifting the handle upward until the fridge about comes off of the floor. The top end of the handle is loose but the bottom is fine. How hard to I have to lift this thing!!??
I got it!!! Okay, the most common problem is the fridge handle at the top is coming loose from the mere fact that the fridge gets opened more than the freezer and people grasp the handle higher than lower. Okay, open the door until you can look at the handle sideways where it attaches to the door. What is happening is the screw that slides into the bracket is simply backing out. Try lifting the handle straight up, only about an inch plus. The bracket is the same on the bottom of the handle as the top. If you cannot get the handle to lift, get a very slim standard screwdriver and push the retaining clip down (away from the handle) so the screw head can get passed it. You may have to push the retaining clip pretty good to get it down. When you have it pushed away from the screw head, lift the handle and it should pop up. Take the handle away from the door and tighten the screw. The screw head takes a torques screw head (star shaped, like a philips but different) Tighten it until it stops the just realign the TWO screw heads into the upper and lower bracket and slide the handle down gently. No problem! You can do it!
Posted on Mar 31, 2009
    Scholar:
  • 84 Answers
Hello, All you have to do is take a firm grip on the handle and pull up toward the ceiling, then you will see some torque screws that you can turn in and then reinstall the the handle. It may take a few times to get it tight like you want.
CYA, Gator
Posted on Feb 06, 2009
THANK YOU huffman2!!
I had same problem. No visible screws or plastic pieces to remove and wouldn't lift. Clip inside door handle. (Sorry for poor quality)
Posted on Nov 20, 2012
  • 943 Answers
Hi there is a small cap at each end of the door . pry off with a small screw driver and tighten the screws thanks the appliance doc
Posted on Oct 16, 2008
2 Suggested Answers
SOURCE: door handle loose on 10656542400 kenmore
The solution on the Kenmore 56822 turned out to be very simple:
With the door closed, pull up on the door handle (requires some force). The door handle will slide up, and once it is up, it can be removed by carefully pulling it off of the door. Then the screws holding the mounting lug can be tightened. Place the handle back on the door, and slide it down, and voila, no more loose handle. I am going to put some LockTite on the screw on mine to ensure that it stays tight.
Posted on Dec 26, 2008
Bosch refrigerator door handle is loose
there is only one screw on the handles from what i found out from fixing my loose handle. the bottom of the door handle has one screw. once you loosen that one up then you lift it and it comes out at the top enough to slide the handle out and tighten it.
Aug 03, 2014 | Bosch Evolution 800 B20CS80SNS Stainless...
Sub-Zero 601R door handle is loose
My Sub is a 650S. Not sure your handle assy. is the same or not. But each of the 2 attachment points have a small 3/32" set screw on the bottom of each short piece between the vertical handle and the door. These set screws grab onto posts that are screwed into the door. There can be 3 points where the handle can work loose.
1. The set screw(s) have backed out and not holding tightly onto the door studs. 2. The studs in the door are loose and need to be tightened with a screw driver. 3. After loosening the handle via the set screws, when you look back into the cavity vacated by the studs from the door, (pivot handle clockwise past edge of door) you will see a Philips-head screw that secures the spacer to the handle. If the spacer is loose, tighten it with screw driver. Then mount back into door stud and tighten set screw. Problem Solved. Have a beer!!!
Nov 26, 2010 | Sub-Zero 601R
Top freezer door does not close tight
Sounds like the top hinge is loose. If the hinge has a cover, remove it then hold the door in the correct position and tighen the hinge screws.
Aug 31, 2009 | GE GTS22KBP Top Freezer Refrigerator
Loose handle on door
The door handles mount on hex bolts sticking out of the door, the door handles have key hole inserts that match with the bolts. The door handles are then slid in one direction to lock the handles in place. Removal is the reverse. To tighten the door handle screw the bolt out enough that you can still put the handle over the bolt heads and slide the handle to lock the handle in place.
Apr 12, 2009 | GE Profile Stainless Bottom-Freezer...
Amana AFI2538AEW bottom freezer door handle is loose?
My dad's freezer handle is loose, model ABB2224DEW. Went to partselect.com and located drawing of freezer door parts. Found a link to a "do-it-yourselfer" that describes removal and replacement of the handle. Hopefully this helps.
Replacement of freezer door handle.
1. Removed freezer door handle. First I read the freezer door handle removal instructions in the Amana refrigerator user guide. Removing the handle requires inserting a plastic card at least 1.5 inches under the left end of the right side of the handle so it releases the butterfly clip latch on the freezer door. Next I pulled the right side of the handle to lift it away from the freezer door. Then still holding the handle away from the door, at the spot that is 1.5 inches from the inside of the right side of the handle, I held the plastic card vertically and slid one corner of it between the handle and the freezer door and worked the card down until it released the butterfly clip latch. Keeping the card at the same space under the handle so the latch was released, I then turned the card to the left until it was horizontal and was lifting the left end of the right door handle away from the freezer door. I then slid the handle across the card to the left until it cleared both door butterfly clip latches and it lifted off the door.
2. Installed freezer door handle. First I read the freezer door handle installation instructions in the Amana refrigerator user guide. The handle is curved on one edge and must be installed the curved side down. Correctly installed, the outside ends of the handle curve upward and the handle curve is down so it looks like a frowning mouth. Next holding the handle curved edge down, I turned it up so I could see the brackets and held it against the door. I lined up the handle brackets slightly to the left of the butterfly clips on the freezer door. Next I turned the handle with the brackets against the freezer door and slid it slightly to the right until the left side of the handle held onto the door butterfly clip by itself but was not latched. Then I lined up the right handle bracket with the right freezer door butterfly clip and carefully slid the whole handle to the right until I heard the left butterfly clip latch click. Next I slid the handle back slightly left once more and then slid it back to the right until I heard the right butterfly clip latch click.
Parts Used: HANDLE, DOOR (WHT) Level of difficulty: Difficult Time to do repair: 30 - 60 mins
Apr 02, 2009 | Amana AFI2538A Bottom Freezer French Door...
Door handle is loose
If my memory serves me correctly, you should see two posts attached to the refrigerator door right now. The handle slips over these posts and if you look closely there is a little hole in the handle where you would insert a allen key wrench to tighten the little screw against the post protruding from the door itself. With the door handle in your hand, properly match up the correct allen wrench to fit the allen screw very snug. Realign the door handle on the protrucing posts and tighten. Once finished, you should have a tight fitting door handle again. Let us know if we can help further.....Eric
Feb 13, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Nov 24, 2008 | Refrigerators
Bottom freezer door handle loose
There is a plastic card that you are supposed to slide under the right side of the handle. Once you have done this correctly the whole handle should slide off to the left.
Nov 14, 2008 | Amana ABB1927DE Bottom Freezer...
Door handles loose
i have a whirlpool conquest side by side and had loose handles,couldn't figure out.but then i grabbed handle and push in and up,handles slide off you can then tighten bolts then slide it back on.hope this helps.n
Oct 14, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
LOOSE DOOR HANDLE whirlpool frige GC5SHEXNQ00
Pulled the handle up to release it from the clips on the door. The screw in the plastic door handle that attaches the handle to the door clip was striped. I used a small amount of J B Weld epoxy to repair and reattach the screw. Realign the handle with the clips and push handle down to reinstall.
Jul 29, 2008 | Refrigerators
Kenmore 56549 / 56542 / 56544 / 56546 Side by Side Refrigerator Logo
1,917 people viewed this question
Top Kenmore Refrigerators Experts
Jim Goldsmith
Jim Goldsmith
Richard Roth
Richard Roth
deton8 von Splosion
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
