Question about GE Eterna EGR2000EMWW Gas Kitchen Range
Ge eterna gas range
Brought down from my parents' farm in Iowa. The unit is about 5 years old. After set-up here in Texas, there is barely any gas coming to the stove. GE repair man says it's the regulator (450.00 repair). Yikes! there was nothing wrong with it when I left Iowa. My parents used LP gas, as they are rural. thought this might be the problem - we have natural gas in Dallas. But repair guy says the LP kit was never installed. So how were they using it? And what do I do now - I don't believe it's the regulator. And the range we used before this one was working pretty well, so I don't think it's the gas pressure.
  • 213 Answers
SOURCE: ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Posted on Nov 21, 2007
rickzilla
  • 706 Answers
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Posted on Sep 01, 2008
  • 111 Answers
SOURCE: GE Profile JGSP32GEV3BB slide in range - regulator went bad #WB19K5020
"GE makes garbage" that's what a lot of independent servicers says about brands they can't become authorized to work on because GE for instance has factory service. What makes the repairman think the regulator is bad? It is highly unlikely to be the case.
Posted on Jan 02, 2009
MNTECH
  • 1543 Answers
SOURCE: Converting a GE Profile Gas Range from LP to natural gas
GE ships gas ranges set for natural gas, with the LP orifices included, usually on a metal tab held with one screw right near the regulator (where the gas connects to the range). If the range was converted to LP, the person who did the conversion was suppose to put the natural gas orifices back in that holder. If they are missing, comment back on the exact model number and I can look up the part number(s) for you.
Posted on Jan 06, 2009
  • 198 Answers
SOURCE: Natural Gas to Propane for Ge xl44 Gas range
The kit is located at the rear of the range right near the gas valve, there are probably 5 spuds and an extender for the large burner, directions are with the range. For the bake and broil you will need to tighten the brass orifice nuts down as tight as possible, also the brass nut on the gas valve needs to be reversed
your local LP dealer should be able to do this for you if you are uncomfortable doing it yourself.
Posted on Jan 27, 2009
When I turn on the broiler on my GE Eterna the flame actually comes up and out of the oven. I can smell th plastic from somewhere melting. So I don't dare use the broiler. And don't
This shouldn't be happening. You may have a delayed ignition causing this. the igniter may be going bad causing this delay. Or the igniter is too far away from the gas tube.
Sep 23, 2014 | GE Eterna EGR2000EMBB Gas Kitchen Range
How do you get the GE externa series stove to fire? the gas stove will not light.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Sep 03, 2010 | GE Eterna EGR2000EMBB Gas Kitchen Range
Ge spectra eterna series gas stove broiler will not fire up. The glow plug gets hot, but the broiler fails to start.
I have an GE Spectra Eterna Series where the oven comes on and only gets warms no matter what setting the oven is set at. Can some one solve this problem?
Mar 07, 2010 | GE Eterna EGR2000EMBB Gas Kitchen Range
Can fix Gas leak smell in GE Eterna stove: Model EGR3000EH1BB
If it was used with LP and you are using it with natural, did you change everthing back over to natural gas settings? Orfices, regulator cap, and oven orfice?
It could be a pressure issue.
Please let me know if I can assist you further.
Vic
May 30, 2009 | Kitchen Ranges
Claibrating the temperature of a GE gas oven
5 degree increments from factory setting
1 is +5
2+10
and so on
Apr 12, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Ligthing the oven glow bar
you need to replace the oven glow bar take out the oven racks in the bottom of the range you will see two screws remove them remove the bottom oven pan under that is the flame spreader shield under that under it you will se the ignighter at the back of the burner bar just follow the instruct sheet with the ignighter to install and reverse just because the old bar glow-es don't mean its good just replace it
Jul 16, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge spectra gas stove top not lighting
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Eterna EGR2000EMWW Gas Kitchen Range Logo
47 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
