Question about Microwave Ovens
How to install charcoal filter in ge microwave md# jvm1870 sk04
  • Anonymous Jan 11, 2009
    I needed help with the model number I entered, R-1872...I bought the unit new and I need install the first charcoal filter. I cannot figure out how to do so. The owner's manual on page 26 simply says to insert it. We cannot get it to fit anywhere.
  • fawltytowers Jan 21, 2009
    trying to install charcoal filter for the first time, does not fit anywhere
  • Microwave Ovens Master
  • 9,098 Answers
From the owner's manual, page 37:
To remove the charcoal filter, disconnect power at the main fuse or circuit breaker panel or pull
the plug.
Remove the top grille by removing the screws on top of the grille that hold it in place and sliding the
grille to the left (opening the door makes grille removal easier). Slide the filter towards the front of the oven and remove it.
You can download GE owner's manuals and installation instructions here.
You can order new filters by entering your full model number here.
Posted on Sep 26, 2008
How do I change the Charcoal filter on my GE microwave model # JVM1750WMC02
the charcoal filter is either in the top of the microwave or on the bottom, but you can order from APDEPOT.COM, Repairclinic.com or searspartsdirect.com
Feb 22, 2011 | GE JVM1750DM Microwave Oven
How do i install the ge jx81d recirculating charcoal filter
It will show you how to do it.
You can find helpful exploded view diagrams and order parts (and accessories like charcoal filters) by entering your full model number from the tag on the oven here.
Jan 23, 2011 | GE JVM1790 1000 Watts Convection /...
How to install charcoal filter in ge spacemaker microwave
top of the front grill there are 2 screws. remove those together with the grill. install filter in location underneath.
Dec 15, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Can't install my GE microwave charcoal filter.
Most or the ones I have seen just sort of lay in there at a bout a 45 degree angle. I can t say i have really ever seen one " snap" in place
Sep 27, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
Changing filter
The grease filter is changed from the bottom of the unit.
The charcoal filter is changed as follows:
To Remove Charcoal Filter
pull the plug.
that hold it in place and sliding the grille to the
oven and remove it.
To Install Charcoal Filter
To install a new filter, remove plastic and other
outer wrapping from the new filter.
Insert the filter into the top opening of the oven as
shown. It will rest at an angle on 2 side support tabs
and in front of the right rear tab. Replace the grille
and screws.
Aug 20, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
How do you install charcoal filter on a GE profile Convection oven.
Jun 02, 2009 | Microwave Ovens
Where is the charcoal filter?
There is no charcoal filter unless you replaced the standard filter with a carcoal filter. Also, it may have m=been changed to a charcoal filter if the unit was alterd during installation as a re-circulating vent, not vented to the outside via the roof or wall.
The filter (Charcoal or not) is on the bottom of the unit. Put your head under the microwave and look up, there it is.
Apr 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
When opening the door a venting sound immediately starts up.
The charcoal filter needs to be changed every 6-12 months, or sooner if it gets clogged.
You can find helpful exploded view diagrams and order parts (including charcoal filters) by entering your full model number from the tag on the oven here.
Feb 11, 2009 | GE XL1800 1100 Watts Microwave Oven
Microwave message says to replace charcoal filter. User manual states charcoal filter is used if unit is not vented outside. Our unit is vented outside
External vent systems have the charcoal filter removed, generally at the time of installation, as it is not needed for this application.
The charcoal filter removes odors from internal recycled airflow.
There should be an aluminum grease filter that you can remove to clean in a warm soapy solution, let dry, and reinstall.
May 27, 2008 | GE Microwave Ovens
Microwave Ovens Logo
2,405 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
