Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Side by Side Whirlpool Refrigerator: Refrigerator is freezing food
We have Whirlpool Model No. ED25PEXHW00 and it has recently started freezing everything in the refrigerator side. We have tried adjusting both the controls in the refrigerator and freezer side and nothing has worked. We have also tried unpluging it for a while and that didn't work either. Is there something that we can try before we have to call out a technician?
  • riverbyfarm Sep 22, 2008
    Huuum,
    Is it possible that the freezer being so full could have led the motor to stop operating. That is what we are dealing with now. I thought that maybe it was running for so long that it just wore out. Please let me know what you opinion is. I am sure at this point we are looking at an expensive repair.
    Thanks again,
    Riverbyfarm
  • frozen up Nov 20, 2008
    I have a whirlpool side by side refrigerator model # D25TQ which is about 10 years old and just since the first of this week, (approximately 3 days) its started freezing everything in the refrigerator side. I initially thought that maybe it was because we've had a very colder than normal fall so I turned the temp settings to warmer on both freezer and refrigerator side hoping this would eliminate the problem, but to my dismay, it didn't. I got up this morning and EVERYTHING in the refrigerator was frozen solid. The water dispenser in the door is frozen solid. I have cut off the breaker to the fridge and am HOPING that maybe it will resolve itself but if this doesn't work, have you any other suggestions?
    Thanks so much! I really can't afford to buy a new fridge.
  • 750 Answers
Hi, riverbyfarm
You did try what i would of recommended first!
The resetting of the system by, turning off the controls of the freezer and the fridge first and then unplugging it or if you can't reach the plug, to throw the breaker off for 5 minutes!
That is a possibility in the order that I described!!!!!
Second I ask, is the freezer packed full to the hilt with packages?
In some refrigerators if the frozen food covers the air vents in the freezer cause they are plied sky high and deep in the freezer it can cause a problem.
The freezer and fridge share the air and have to have the vents or passages free so to allow sharing of the cold air!
Let me know if the measures as I prescribed have an affect.
Waiting for your reply!
Bless You Huuum
Please do not forget to enter a rating here before you sign off.
Thank You.
Posted on Sep 21, 2008
  • Neil Golan
    Neil Golan Sep 22, 2008
    Riverbyfarm,
    I do not think the cause was the freezer being packed to the top for the compressor dying.
    It would have let you know right away by the fridge side being warm enough for you to feel the problem. The freezer and the fridge share air and if not it gets warm in the fridge!
    You may want to try service once before running out and getting a new one.
    Perhaps the coolant leaked out or is so low the compressor will not kick in!
    Or perhaps it is only the thermostat needs to be replaced!!
    You are not sure the compressor is dead till you try at least one service call to check it.
    If it's not the compressor needing to be replaced,( which is expensive for a 8 year old fridge.) then you saved the price of the new fridge for a while.
    Here is an interesting article that I just read!
    Repair or replace?
    When to pull the plug on your old refrigerator
    It nearly always makes sense to undertake simple do-it-yourself repairs,
    such as replacing a gasket on a refrigerator or a freezer.
    Typically, you'll also find a troubleshooting section for more-serious problems
    in the owner's manual.
    Should you pay for a repair or buy a new model?
    The answer depends mostly on the age of your refrigerator,
    how much you bought it for,and the cost of the repair.
    Follow these guidelines:
    When a repair makes sense.
    If your refrigerator is under warranty or less than four years old (three years for top-freezers),
    paying for a repair makes sense.
    Note that refrigerators under warranty might require service from a factory-authorized technician;
    readers have found them on a par with independent repairers.
    When a repair might be a wise choice.
    If your refrigerator is out of warranty and is four to seven years old,
    it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
    But you might want to buy a new model even at this stage,
    given that today's models are quieter and have added features.
    Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
    are 43 percent more efficient than conventional models built before 2001 and 56 percent
    more efficient than those built before 1993.
    When it pays to replace.
    The repair costs more than half the price of a comparable new refrigerator.
    Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
    six or more years old or a bottom-freezer or side-by-side eight or more years old.
    Thanks to better recycling programs, less than 10 percent
    of a refrigerator you replace is likely to end up in a landfill.
    RiverByFarm,let me know how it turns out.
    Thanks for giving me the opportunity to help!
    Please do not for get to give a rating before you sign off!
    Thank You, HUUUM
Whirlpool ed25rf refrigerator side freezing on bottom
your evaporator motor may be going bad also check to see if your condensing unit and fan motor are clean this can cause similar problems.
Dec 11, 2013 | Whirlpool 25.2 cu. ft. Side-by-Side...
My refrigerator and freezer smells like chemicals
Your problem might be something caught in the water hoses going into your fridge and condensation is freezing around it
Apr 03, 2012 | Whirlpool Refrigerators
Hello, The fridge side on my Whirpool side by side is freezing food. Whirlpool Estate model TS25CGXTD. Thanks
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
May 15, 2011 | Refrigerators
The fridgerator keep freezing the food. it is on the lowest setting but still it freezed the food. whirlpool MODEL: ET18NMXAW03 SERIAL: ED3042768 have had someone tell me to clear the food so that it...
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 25, 2011 | Whirlpool Refrigerators
My Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator bottom meat section and veggie drawer is freezing my meats and vegetables. Why?
heatman101
Dec 16, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer all of a sudden is not freezing food model whirlpool ED5CHQXKT03
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 09, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool model # ED25DQXDW04 - Everything freezes in the back of the refrigerator and it stopped making ice cubes - no water comes into the freezer side to make ice cubes. We're throwing away a lot of...
This may not be the problem now but by the sound of the malfunctioning ice maker, it could be in the future. The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component. Mine recently caught on fire at this device that is located near the compressor. If you would like to be a part of the petition for a recall on this appliance contact me at jboooor@hotmail.com
Jun 07, 2010 | Whirlpool ED5FHEXMQ Side by Side...
Refrigerator is too cold and freezes food.
Good day,
If the machine is under one year old, all working components are under factory warranty. Call for warranty service from selling dealer, or if you moved out of the area, an authorized Whirlpool warranty dealer.
Nov 25, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer not freezing on whirlpool side by side fridge. Its a 2001 model... ED0GTQXKQ00
Inside the fresh food compartment near lights is the defrost timer. Turn it clockwise slowly until you hear refrigerator compressor start. If this works, replace the defrost timer. Let me know, Thanks, Sea Breeze
Mar 18, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
2,963 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
