Question about Tec Patio II Grill
Both burners seem to explode at different times
I have had one, for a while, of my burners make this boom sound extinguishing the infrared burner during cooking but still glows at the bottom making a hissing noise. Now the other burner is doing the same thing. It scares the heck out of you if you are standing in front of the grill cooking. You can turn the grill off & relight the pilot light and start the burners back up after it cools down. It only takes a few minutes to blow up again. Both burners are doing it now and I have the cooking dial below the halfway mark with this occurs. What do I need to do to fix this problem & apparently huge safety concern?
  • 4 more comments
  • Anonymous Nov 25, 2008
    I have the same problem and my burners have been replaced within the three years.
  • meridethc Jan 26, 2009
    We have the same problem
  • Anonymous Feb 15, 2009
    I have had the same problem with 1 burner. I just took the grill head completely apart and see that the ceramic is cracked. I have had the grill for 4 years and very dissapointed in how sensitive it is, the high maintenance and outrages replacement part prices. I will never buy another TEC product
  • reeems Apr 11, 2009
    I have the same problem. What makes the burners crack so quickly? Can I replace them myself? If so, where can I get instructions and parts?
  • dsisolak Apr 20, 2009
    Same thing happens to me all the time. I will never buy another Tec product.
  • Jaseon May 15, 2009
    I have same problem! Started when I first got it - had part replaced and now three years later its back. Grill was expensive so I hate to give up on it, but overall not very satisfied - I've found unless you want to cook at super high temps, not a very versatile grill. Looks like I could buy a new grill for about the price of the replacement part!
I had the same problem. I disassembled the grill and found that both burner box assemblies were shot. With these being worn out too much air was being mixed in the assembly.
You'll need two burner box assemblies...not cheap! You'll also need new gaskets
Posted on Jun 22, 2009
Sounds to me like the burner casing is deteriorating. The burner can be removed as one piece and then further disassemble into 2 pieces (if you have a 2 burner TEC that is) I believe the problem is in an area where the 2 burners meet each other, the side walls are probably rusting away and have some holes in them, this area can only be seen when the burner is taken apart. The only solution is replacing the burner.
Posted on Sep 24, 2008
Glass turns black inside
You don't indicate where the glass is that becomes black/sooty but you can get cleaner specifically intended for cleaning glass fireplace doors. It is more effective than using ordinary glass cleaners
Apr 29, 2013 | Napoleon Fireplaces Napoleon Prestige PRO...
Water heater goes out
The burner needs to be adjusted
Mar 13, 2017 | Water Heaters
Have a home depot ducane 5 burner. just replaced burner tubes. have never used the rotisserie burner on it before. it lights but won't stay lite after releasing knob...any suggestions? Thanks
Infrared burners requite that the gas control knob be held in for 2 minutes or so, to allow the thermocouple on the infrared burner to heat up completely. If it's windy were you are, the wind can blow the burner out, while trying to light it. That's why it has a thermocouple on it, to stop the gas if the burner goes out. All cooking on the rotisserie is doon with the lid/hood closed, at temperatures around 250 degrees F. Once the infrared burner turns bright red, release the control knob.
Hope this helped you to get it lit. Thanks for choosing FixYa.
Aug 24, 2011 | Ducane 30400040 Stainless Steel Grill
Shortly after igniting the infrared burner, and while the burner is still heating up, the gas will explode spontaneously, blowing out the flame.
What you have is partially delayed ignition, This could be caused by a manufacturer's defect or the burner is clogged with debris. To test this theory, when you're preheating the burner, preheat on the lowest flame setting that you have, that will keep the burner lit. After 8 to 10 minutes, gradually turn the flame up to high. If the burner responds as it should, you shouldn't get that delayed ignition problem. If you do get it, the burner is defective and should be replaced.
Hope this helps solve your problem.
Feb 28, 2011 | Fire Magic Infrared Burner System For...
Furnace ignites when thermostat calls for heat, runs for a few minutes and the burners extinguish, repeats... changed flame sensor, nodifference, saw 4 quick red flashes evry few seconds after burners...
You don't say if the blower is coming on, no blower would cause the limit to open. By the way, the limit is internal and auto-reset, not the manual reset roll out switches on the burner assembly.
Jan 11, 2010 | Goodman Heating & Cooling
What causes delayed ignition, causing a slight boom on lighting main burner?
There will be a web or bug or debris in the pllot asssembly /rail that blocks the path of the transition to main burner or ignition of pilot assembly itself, when it does ignite, theres too much gas built up in the pilot ignitor area and it explodes, clean the orifices in the pilot asssemblt / and or the pilot rail or main burners orifices at the pilot area.
Jan 01, 2010 | Cozy Enclosed Front Console Heater 20,000...
Burnes extinguish once lit.
These have flame failure technology so the gas will cut out if there is no flame. The thermocouples do this by keeping the gas valve open once they have heated up. This should only take 5-10secs though so any longer is probably an issue with the thermocouple
Apr 16, 2008 | Fisher and Paykel GC913 - Stainless Steel...
Gas cooktop BOOM
Gas is taking too long to ignite. Make sure the burner rings are installed properly. They have grooves that need to line up. Also make sure all the holes are clean.
Apr 03, 2008 | Cooktops
Tec Patio II Grill Logo
932 people viewed this question
Top Tec Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Are you a Tec Grilling Expert? Answer questions, earn points and help others
