Question about HP LaserJet 2200D Printer
2200d hp laserjet
Put in a new cartridge and unit still won't print. ...only clean blank pages come out. The green light flashes.. and as the paper is about to exit the printer the red light comes on and stays on. The paper ejects, but as mentioned before; it's blank!
  • sealemich Sep 19, 2008
    Thanks for the suggestions; however had already tried shaking and re-seating both the original and new cartridges, made sure all the packing strips were removed, and made sure all doors were closed. Everything works fine except that it won't print. I installed the PS ...5e, and subsequently the PS...6 drivers and the printer is communicating with the computer, so it's something not working inside the printer. It does not even leave any marks on the paper when it cycles through the printer.
    ...I downloaded the manual from the HP site to make sure I am extrapolating the light codes correctly and that was my first thought that that toner needed to be replaced. The cartridge cost me almost 50$ and that's a big reason I want to get this printer working instead of having a giant paper weight. I can't return the cartridge. :(
  • 1,689 Answers
Have you completely removed the protective plastic strip? if yes, try to take the cartridge out and gently shake it tilting the sides back and forth. now if this still did not work, get your old cartridge, shake it too and try to use it. if it prints sparkles (like its supposed to since it is empty) bring the new cartridge back to the store for replacement...
if you have other concerns, lemme know
Posted on Sep 19, 2008
    Problem Solver:
  • 7 Answers
The green flashing light lets you know that the machine is recieving data. This is completely normal, however, the red (Attention) light can mean several things. There can be a door open, missing toner cartridge, out of paper, or paper jam. In this cause it is probably the toner cartridge. Typically on these machines there is an Orange or Green tab on the side of the toner cartridge that needs to be pulled to fully engage the cartridge. You may want to make sure this has been pulled and the cartridge has been properly seated.
Hope this helps...let me know if you need any further assistance
The red light is flashing, after I replaced the toner it still flashing?
Posted on Oct 15, 2008
HP 2200LaserJet prints a few pages, then gets stuck
You may have a recurrent paper jam. Use a strong light to examine the entire paper path. Even a tiny fragment of paper can cause the problem you describe
Jan 27, 2013 | HP LaserJet 2200D Printer
My printer Hp laserjet 1010 prints blank paper, eben the test paper, although the cartidge is new. could you tell please what I can do
Have you pulled the tape from the new cartridge? If you pulled, then push the green button on the printer, if a blank page again disassemble laser module and clean dirt with cloth and alcohol.
Oct 10, 2010 | HP LaserJet 1010 Printer
After cleared paper jam, HP LaserJet 1320 prints blank pages
Yes you can replace the transfer roller, but check to make sure the roller is firmly seated into its holder and that the springs are contacting the metal shaft.
Good Luck
Nov 20, 2009 | HP LaserJet 1320 Printer
HP LaserJet 2200 Series PCL huge dark smudge
Replace toner cartridge. If problem persist replace fuser unit. P/N # RG5-5559
Apr 28, 2009 | HP LaserJet 2200D Printer
Shadow print from 2200d laser printer
This shadow, or backgrounding, is generally caused by excess debris remaining on the drum. This is mostly caused by the wiper blade not dislodging all the waste toner. You will need to replace the cartridge (C4096A).
Mar 22, 2009 | HP LaserJet 2200D Printer
HP Laserjet 2200 Keeps Spewing Out Blank Paper
sounds like it has a solinoid that is stuck open.
Dec 16, 2008 | HP LaserJet 2200D Printer
HP Laserjet 1500 Color, Print out Blank
Hi devi960:
Pages print, but all
colors do not print or
the pages are
completely blank.
One of the print cartridges might be
low or empty.
Run an engine test and see if all four colors print. If
not all colors print, replace one or more of the print cartridges. If the
engine test is successful, replace the formatter.
If the printed pages are completely
blank, the file might have blank
Check the file to make sure that it does not contain blank pages.
A print cartridge might be low or
Check the printer control panel for a Supplies Status message,
print a Supplies Status page, or use the embedded Web server
(HP color LaserJet 2500 series printers only) to see the levels
remaining in the print cartridges. Replace any print cartridges that
are low or empty. Messages are not created for non-HP print
If you are using non-HP print
cartridges, one or more print
cartridges are low or empty. The
control panel lights do not indicate
low or empty for non-HP print
Replace one or more of the print cartridges.
Font DIMM might be selected but the
font DIMM is not physically installed in
the printer. (This issue applies only to
printers using an Asian-language font
In the settings for this printer, clear the Font DIMM check box on
the Configure tab if no font DIMM is installed in the printer. Select
the Font DIMM check box only if the font DIMM is physically
installed in the printer. If you think that the font DIMM is installed,
make sure that it is installed correctly.
The paper curls when
exiting the top output
The paper needs to print to the
straight-through paper path.
Open the rear output door to print to the straight-through paper
path. Remove each sheet as it exits the printer.
The stack was slightly curled when it
was placed in the tray.
Turn the stack over in the tray.
The paper does not meet
See the user guide for information about print-media specifications.
If you are printing on light media, the
Type setting might not be correct.
Select Light in the Type is field in the printer driver.
Nov 13, 2008 | HP LaserJet 1500L Printer
Hp 2200d laserjet
possiably bad gear assembly.
Sep 21, 2008 | HP LaserJet 2200D Printer
Hp laserjet 2200d
If the toner smears after the page comes out of the printer you may need a new fuser. The fuser is the heating unit in the printer and can usually be seen from opening the back door. Check and see if it has a line worn down the same side as the mark on your pages.
Feb 15, 2008 | HP LaserJet 2200D Printer
HP LaserJet 2200D Printer Logo
410 people viewed this question
Ben Johnson
