Question about HP LaserJet 2820 Printer
Lcd message "close cover"
All the covers are closed, but the printer dont works
  • 97 Answers
Try to clean all sensor
Posted on Sep 22, 2008
QLn420 the media head cover is open but it is closed
Switch maybe in the wrong position, check the cover switch is OK.
May 30, 2014 | Zebra QLn420 Direct Thermal Printer -...
Its showing "close ink cover"
Hi there!
The message "Close Ink Cover" means that the cartridge door is not closed securely.
-please open the ink cartridge cover and make sure all cartridges are installed correctly and then close the cartridge cover. That should clear the message on the screen.
Hope this helps!
May 08, 2011 | Brother DCP 165C Compact Color Inkjet...
My problem with the Aficio is that I get the error message Close R Cover but I dont have the R Cover on the printer it was given to me without it is there any way that i can bypass this
look at the right side. the 'r' cover is most likely the right side cover.
it might appear closed, but make sure. and look to see if the switch that senses it being closed is not bent or broken.
Dec 29, 2010 | Ricoh Aficio AP3200 Laser Printer
Message 'Clean Sensor' has appeared. Followed advise to open Cover D and close it again but to no avail. Has anyone got any other suggestions, please?
Follow the steps below to clear the "Clean Sensor" error message.
  2. Slowly close the cover again. c2600_close_cover_d.jpg This action will move the lever shown below and clean the sensor.
  3. Open and close the cover several times. Once the front cover is left closed the printer will start to calibrate.
Once complete, the error should no longer appear and the printer should resume normal operation.
Note: If the error message is still apparent after following the steps above, contact Epson for further advice.
Nov 16, 2010 | Epson AcuLaser C2600N Printer
Front cover of phaser 8550 won't close correctly
You can download the service manual free at ww.eserviceinfo.com
Aug 18, 2009 | Xerox Phaser 8500/DN Printer
Replace Panel in Xerox 8550 Color Printer - Close Exit Cover
Open that cover and look in the frame of the machine for an opening. Then look on the upper cover. There is an interlock switch on the machine. The plastic tab on the upper cover often times breaks off and will not actuate the switch, giving you that message.
You can fix it by gluing a paper clip onto the cover. Or call 1-800-835-6100 and order a new cover.
May 14, 2009 | Xerox Phaser 8550DP Printer
X3480 printer.message is saying;cover is open
the meaning of cover is open means --------the cover means.the thing which you lift to remove or install the cartridges.just keep that cover closed.if that cover is closed still its showing the same error.then the sensor which detects the cover closed is got moved from its orignal position.to reset the sensor just tap all the sides of the printer for couple of minutes.mostly the top side and front side of the printer.and then check out the error must go away.if still the same error then its quite possible that sensor is broked as it very very delicate .so it needs a technician to replace the broken sensor.the cost to replace the sensor must not exceed then $5.
Feb 26, 2009 | Lexmark X3480 All-In-One Printer
Lcd message close cover hp 2820
Make sure that the door switch actuator is plugged in and that the tab on the door isn't broken or bent.
Oct 07, 2008 | HP LaserJet 2820 Printer
Printer cover open error message
I had that problem too.
Unplug the printer.
Hold the printer cover open while you plug in the printer.
Then wait for the printer to power on while still holding the cover open.
Then close the cover.
The buttons should work and th error message should be gone.
It worked for me.
Nov 01, 2007 | Lexmark X2250 All-In-One InkJet Printer
HP LaserJet 2820 Printer Logo
Seeker5211
Seeker5211
