Question about Philips Magnavox 9P6034C 60" Rear Projection Television
60" TV Tint does not work
Posted by ervin444 on Sep 18, 2008 Report abuse
Everyone on my tv have to much peach color, and anything thats white is peach. I tryed to adjust my Tint, But the Tint does nothing. I adjusted the color and everything else. I just know its the Tint, because there is no difference when I adjust it high or low. Is this Something I can fix on my own. Comment by ervin444, posted on Sep 19, 2008 I would like to fix it myself, with help from you and the PDF file. My Email address is ervin714@gmail.com were you can email the PDF file.
Thank you Tim. Still need a solution for this problem? Try our Premium Assistance plan Solution #1 posted on Sep 18, 2008
experttv
Rank: Guru
Rating: 87%, 37 votes
This actually prabably being caused by a fungus in the tubes. This model is knowen for fungus to grow in the tubes and cause a pink or red tint. If you are interested in reparing this yourself you will need to change the coolant in the tubes. I have a PDF file that will instruct you on how to complete this. If you have a repairman do this for you you will most likly pay $300-$400 to have this fixed.
Let me know what way you want to go.
Tim Nolan
  • 4 more comments
  • mrkanderson Sep 22, 2008
    I have the same problem, I also would like the pdf file to learn how change the fluid.
  • Anonymous Sep 23, 2008
    I believe i have same problem cani receive this file to do it yourself!
  • charleyh Oct 06, 2008
    Mine is the same issue. Can I get the pdf on how to change the fluid please?
  • birdman09 Oct 10, 2008
    ORNAGE PINK TINT IN COLOR OF SCREEN
  • Anonymous Dec 01, 2008
    yes, I have the same problem and would like to fix my TV
  • rohonupe99 Jan 23, 2009
    orangish pink screen. i would like the pdf as well
  • Philips Master
  • 3,459 Answers
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
60
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common60" TV Tint does not work - 2c07611.pngbr />
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture 60" TV Tint does not work - 578ba6c.jpgat needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Feb 13, 2009
    Novelist:
    Champion:
  • 203 Answers
Email sent
Posted on Sep 20, 2008
I have the Sony KDS- 60A2020 60 inch TV. Recently, my picture has appeared more yellowish. Everyone on it looks like there dark yellowish or have fairly dark (bronze) sun tans. I changed my lamp yesterday...
I have a older 2006 SXRD rear projection TV. I had the same problem after the TV warmed up this yellow tint started in the corner and crawled its way down the TV. It turned out that Sony had a recall on the optic block of the TV. If you replaced the Lamp and adjusted the color this kinda sounds like the same problem. Here is a link explaining it. In this article it shows up as a green haze and blob, but in my TV it manifested as a yellow tint.
http://www.avsforum.com/avs-vb/showthread.php?t=1086180
Jun 09, 2011 | Sony KDS-60A2020 60" HDTV
I have the same model. My picture is bad my white
If the pic seems dull and the colors are all washed out as well as the tint not being able to be ciorrected to correct tones. Its almost always caused by the CRT coolant needing replacement. You can get the phillips CRT coolant kit from www.tvrepairworld.com the kit contains the coolant for all three CRT's and the CD with instructions.
Jul 18, 2010 | Philips Magnavox 9P6034C 60" Rear...
Blue tint on rear projection tv
If this is a crts model , then one of the crts had blown, if it is a lamp rear projection, then it is a fault on the video circuit.
Mar 14, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
Tint does not work.
Tim Nolan
Sep 18, 2008 | Philips 60P8341 60" Rear Projection...
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
OR....
2POINT IRE
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
Sep 15, 2008 | LG 42LG50 42 in. LCD HDTV
Dead spots
you could try antenna booster for the phone
Sep 05, 2008 | Cell Phones
Tv clicks off
You most likely have dry joints. If you are not competent with soldering and electronics, you should take it to a qualified repair person. They should not charge you more than £10-15 for repair.
Jan 01, 2008 | Sanyo DS13204 TV
Phillips Magnavox 60 inch Projection Tv
I have a white glow around all the white letters and just all the white colors in general. What do I do ?
Sep 24, 2007 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
200 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
