Too Black & White
Our copy machine prints out really dark, unclear copies :(
To get them remotely readable we have the settings on manual exposure & as light as we can go. If this action is neglected the copied document will get caught in a hot ashy & crumpled mess somewhere within the copier. Is this worth fixing or should we seek a replacement?
  • moogie_j Sep 19, 2008
    I forgot to mention that it is a Sharp SF 2022
  • 1,326 Answers
Have you cleaned the optic's resently? You most likely need a New Drum and Cleaning blade. If I were you, I would first try to clean the scanning lamp & reflecyor with alchol. Before I forget un-plug the copier first. Then with a dry rag wipe off the dust from the there mirrors that you can see. If you really want too you can also take the Black Box off and clean the two mirrors under that. Reinstall, what was removed inclueding the copy board glass and plug it back in and see what the copis look like.. They should come out better.....There is more that can be done, but first see what that can do for you without spending any Money......
Posted on Sep 20, 2008
Mysterious fluctuation in quality of copies.
fuser drum is bad. photocopier use electricity to transfer the toner to the paper, then it is heat fused to paper. it appears that the problem is occurring around the time that the toner is attracted to the paper.
Mar 07, 2014 | Canon PC-940 Black and White Copier
Sharp Photocopier 2114 makes all black copies
OPEN top cover make a copy see if copy exposure lamp turns on or not
May 25, 2010 | Sharp AR-5320 Black and White Copier
My copy machine will just print a totally black sheet of paper.
Pull out your toner cartridge, push back the drum shutter and see if the drum is coated in toner. If so, it is defective. Replace it and it will be fine.
*please rate me ;)
Mar 21, 2009 | Canon PC-860 Black and White Copier
Canon PC-D320 prints only left half o document with closed cover
I had the same problem but it was caused by the scanner that was not running flash under the copier glass,if I remember correctly there are spacers on the scanner that keep the scanner to run exactly the same distance from the glass of both sides of the scanner.
On the other machine,I found a faulty scanner cable that cause a similar problem.
Jan 30, 2009 | Canon PC-D320 Copier
Dark edges
It depends... never use a Reman cart in these machines... only use sharp...especially if the machine is under warranty.
Does this happen when,
Using the Doc Feeder
When making copies from the Glass
Or when you print from a computer (assuming you print from a PC)
If you print something and this happens then it is inside the machine
Probably toner or developer dumping...
Take a few pieces of large white paper and cover the entire glass surface... make a copy is the line there? If so see the answer above... if not then close the top and make a copy with no paper on the glass... is that black line there.. If so then your top needs adjustment...
One more test
If you make a copy using the doc feeder, this black line only occurs when making copies with the doc feed, clean the **** glass, and try again...
Oct 25, 2008 | Sharp AL 1215 Black and White Copier
Xerox xc1020
is it a printer/copier?
yes....do both prints and copies off the glass come out black?
yes...probably a problem in the drum/ CRU area
No- prints OK but copies black lift the lid and watch the exposure lamp...does it light up? does it move? Both of these scenarios would usually bring up a fault code, so I would still be inclined towards the drum unit.Pull the unit out and make sure no paper has sneaked up between the drum and the exposure slot, or even into the drum unit. another cause could be a broken corotron wire (very thin wire close to the drum usually behind a grid (charge grid) If it is a customer replacement drum unit (CRU) the charge grid will be built into the unit and will require the whole thing replacing.......
Dec 27, 2007 | Xerox CopyCentre C20 Black and White...
Streaking
hi im jules_09.his there any error code?if no error code try to adjust the voltage on the exposure lamp,if that does not work can you send me a sample print at cmhal_09@yahoo.co so i can see the print .
Oct 14, 2007 | Toshiba 2060 Copier
Light Copy
first you press the exposure key and select the manual exposure mode then press and hold exposure key for 5 seconds when it blinks select the position to dark and press exposure key again,try to make the copy if no defrence ,select the photo mode and press and hold the exposure key again select the dark position by dark exposure key and press exposure key again.check the copy if again no difference change the DEVELOPER
Sep 14, 2007 | Kyocera RI-3530 Black and White Copier
95 people viewed this question
jasbo
jasbo
