Question about LG Washing Machines
LE Error Code on Tromm LG WM2277HB Clothes Washer
  • majrdf May 04, 2009
    The LE light is on and the machine will not work.
  • Anonymous Mar 31, 2014
  • 706 Answers
Http:// page 18 of this service manual elaborates on the LE error code and what to check.. Hope this helps you..
Posted on Sep 20, 2008
I had this same tissue and the only thing that worked was to actually throw the breaker for the washing machine in our electrical panel. It happened a few times about a year ago and have had no problems since. I guess you can unplug it too, it helps to reset the memory or something to that extent but ours are stacked and I can't easily get to the power cord!
Posted on May 15, 2009
Annoying LG Tromm wm2277hw "LE error" won't go away.
Might be "tE" error code. Thermistor error. A $6 parts and pretty common and causes the symptoms you described.
Mar 02, 2017 | LG 4775er2002a Door Hinges for Wm2277hb...
Error Message and Tub not spinning
UE is likely an unbalanced load or load is too large. Reduce the size of the load and your issue should be resolved.
Jul 21, 2009 | LG WM-2277HW Front Load Washer
My washer is marking LE.What does that mean?
This is a motor overload. Could be too many items in the barrel. I have had this code in the past and took some items out and it went away. I still think there is an underlying issue with the hall sensor or the motor altogether.
Jun 23, 2009 | LG WM-2277HW Front Load Washer
I HAVE A LG TROMM WM2277HB and its not spining i keep getting a LE ERROR CODE
First try unplugging the machine for a few minutes and then retry a cycle. If you still get the LE error:
The Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in the US). Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
In the US, find a service provider using your zip code at or call LG at 800-243-0000
Jun 12, 2009 | LG WM2277H Stainless Steel Front Load...
LG Tromm washer WM2077CW reading code LE
LE means "Overload in Motor" Unplug the washer, remove clothes, wait 15 minutes for motor to cool down. try again. If problem persists you'll need a certified technician.
May 31, 2009 | LG WM-2077C Front Load Washer
" LE " displays
lg washing machine shows an error everytime i turn it on error such as pe
Nov 05, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
2,274 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
