Question about Toshiba TLP-S10 Multimedia Projector
Problem with image from LCD
The image projected on the wall once the Toshiba is hooked up is green, what causes this? We haven't had any problems with the LCD before. Coul dit be a bulb?
  • 115 Answers
No, If the problem comes with connecting the signal, then it could be RGB.
if this is coming with all time then check LCD panels and Fly-eye lens.
Last thing is lamp unit.
Posted on Sep 27, 2008
Epson 460 powerlite hooked to smartboard green light blinking and no image.
Yes this is most likely the lamp. Does it eventually go back to just a red light?
Dec 06, 2012 | Epson PowerLite 410W LCD Projector
Toshiba LCD TV: Double image (right side) on power on
Did you find a solution to your problem?
May 21, 2010 | Toshiba Televison & Video
When I project, the display on the wall is green, can't figure out why. Is it the INPUT into the projector?
i have lcd projector but problem to connect dell vostro 1510 only not show laptop. only show lcd projector but without show laptop. i need both laptop show and lcd projector how explain me.thank
Apr 27, 2010 | Toshiba TLP S30 Multimedia Projector
Toshiba LCD model#TLP-T60M. Projects images but screen is green.
reset the settings to factory default. then make sure that the input matches the signal and that the cables are working. if you still have a problem, and the entire screen (including the initial toshiba screen) is entirely green tinted, you may have a main board issue.
Oct 19, 2009 | Toshiba Office Equipment & Supplies
50inch toshiba color problem
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
May 03, 2009 | Toshiba 50A62 50" Rear Projection...
48 inch toshiba with color alingment problem
Thanks for this forum.
I have a Toshiba 48" rear projection TV which started to show red and green lines on the left side of the screen and have also started affecting the left-hand focus of the image shown on the screen. I have had this TV for 14 years and had a projection adjustment done once before.
Thank you in advance for your assistance.
Ed Alexander
Dec 06, 2008 | Toshiba Televison & Video
Toshiba 65H80 Rear Projection Multi Image Problem ( Trailing )
There is a problem in the imaging circuitry in your Toshiba. It could be anything but most likely in the focusing circuitry. I would have a certified Toshiba repair on it.
Sep 17, 2008 | Toshiba 65H80 65" Rear Projection...
Projector Image Problem
Hi There
Your Projector switches to a 16:9 ratio when hooked up to a Video signal and to a 4:3 Ration when hooked up to a PC signal.
You can manually change this in the Menu functions if this bothers you.
Simply go to Aspect Ratio in your Menu's subfolders and press left or right once you scrolled down to it.
Sep 21, 2007 | BenQ MP610 Multimedia Projector
Green Convergence problem
O.K. This is a CRT Projection TV see The Manual is available from , and this describes the Manual Convergence process, I doubt this will help, but it's step #1. The problem you are describing sound to me like a deflection problem. The electron beam in the green projection 'tube' (a super bright CRT) is probably not being controlled correctly. This can be caused by several things, from least likely to most :) I do not recommend that someone untrained in electronics attempt to service a CRT based television due to the potential for extreme shock or electrocution. That caveat said, here are the possibilities. #1 Physical Trauma: The TV has been shifted moved or bumped hard, and one or more of the fixed permanent magnets used to help convergence has come loose, or the CRT projection tube was damaged. I don't think these TVs use convergence magnets anymore, but it's possible. The green CRT tube failing would be more likely if all four corners were affected, but I've seen a failing CRT affect a single corner/edge before. I believe that this model has projection tubes that are separate from the colored filters, so swapping the tubes around may be possible. I do not have a service manual for this set, and this may be a hazardous operation due to high voltages. #2 Stray magnetic field: Someone dropped a magnet into the TV, and it landed close enough to the green tube to effect it only, or perhaps some other piece of equipment is effecting JUST the Green CRT (clock radio, speaker, badly designed wall wart, etc.). Removing the offending magnetic field may cure the problem. Perhaps the offending magnetic field has been removed, but it's presence is still felt. Try using the degauss function built into the TV set (I can't find one in the manual, but it may be present). You may want to try using a degaussing coil, and see if that helps the problem. Just be careful not to get the coil too close to the base of the projector tubes. #3 Deflection drive electronics: A CRT works by using an electron beam to excite fluorescent compounds on the face of the CRT. To move the electron beam about, a process called deflection is employed. Magnetic coils (the choke) are used to steer the electron beam up, down, left or right. These coils are driven by transistors, and as one fails, you will get an image that starts collapsing in the affected section. On a standard CRT TV, that would mean the entire image is affected, but a CRT projection display uses separate red, green, and blue CRT projection tubes to build the image, so you have three times the deflection, three times the possible transistor failures, and in your case, the odd result of just the green part of the image displaying incorrectly. This problem will probably require a service call, and a electronic board swap, but the problem could be the choke (the magnetic coils) on the green CRT projection tube. Swapping the green tube for another tube could prove if it's the tube or if the deflection electronics that are going out. Again, my feeling is that this is a deflection issue requiring a board swap (I doubt anyone actually does component level repair anymore) Sorry, I don't have a better answer, peace. Paul.
Jan 13, 2007 | Toshiba 50H82 50" Rear Projection...
Toshiba TLP-S10 Multimedia Projector Logo
170 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
