Question about Intel D845GVSR Motherboard
Motherboard won't boot
Have eMachines that had a bad power supply and took out MB. Purchased an identical MB with the same rev Main Number on the intel sticker and when system boots up it indicates the support CPU speed is only up to 2.8Ghz, my Intel Celeron D CPU is 1.93Ghz.
It does not make sense I would have this problem when I have an identical replacement MB.
    Problem Solver:
  • 5 Answers
U can go to ur mb bios nd check ur processor setting.may be 845gvsr not support intel crl processor.u can give load bios default from ur bios press F6 or F7,
Posted on Sep 19, 2008
2 Suggested Answers
colliewob
  • 781 Answers
SOURCE: CPU incompatibil
Do you get to the boot screen if so press the key to enter BIOS and set BIOS to default then from there set up to suit CPU and memory
Also check the M/board battery is OK
Posted on Sep 25, 2008
My PC power supply crashed, burnt resistors, Powerman IW-P250A3-1 20 pin plug to motherboard, bought new power source, but the old power source had a white cable to the 20 pin plug which was -5vdc 0.3amp....
For your system to boot up properly, you need an identical power supply for your system. Most likely the reason why your system won't boot up right now is because you purchased a different power supply and it is lacking something(which is the other pin).
Regards
Sep 14, 2011 | Computers & Internet
Giga Byte GA81RM REV 2.2 does not boot
Try clearing the CMOS by either taking the motherboard battery out for 20 minutes or moving the plastic jumper that is next to the battery to the other possition.
If this does not work then you are probably looking at a replacement motherboard.
Regards.
Feb 19, 2010 | Computers & Internet
Finding the exact model number and manual for my MB
Hi there.
Is this your board>>>>>>>
If so they are not cheap to replace, about $150+ , you may get one second hand a bit cheaper, maybe $60-80
You mentions it beeps, the beep codes described is a Video (Mono/CGA Display Circuitry) issue
this can be memory related, so take out the main power supply (the power cord) and the motherboard battery for an hour, then put back in the memory, the battery and then the power cord and try to boot up.
Post back if you need help.
Good luck
May 29, 2009 | HP Compaq Motherboard
No boot, New PS, Green light on MB lights, No Fans running
Bottom line: Either your power supply or (hopefully not) the mother board has gone bad.
Replace power supply (remove old one), take to local independent computer shop, ask them for new unit. Should be around $50.00. - no more. After reinstall, if still no fans, boot, etc. Replace motherboard or buy a new machine. MB's installed probably will run you around $250.00-ish.
Good luck.
gurutim
Mar 21, 2009 | E-Machines eMachines Desktop PC
EMachine T5026 no boot
This just happened to my t5026. I had to replace the power supply to fix.
Mar 08, 2009 | E-Machines Emachine T5026 power supply **...
Emachine T2890 won't power up. New power supply.
move its bios jumpur on cofig mod and after some time post it its orignal post .it will ok ok Insha Allah
Feb 19, 2009 | Intel D845GVSR Motherboard
2 emachines won't boot
Are you attaching them properly
if so then it is something other then power supply
something has caused both power supplies to blow
have you installed anything in the first emachine you talk about
Jan 17, 2009 | E-Machines eMachines Refurbished EMA...
My gateway 700 xl doesnt boot
Unplug the power from you 700xl and from you monitor. Try removing the cmos battery and reinstalling it. Then, plug everything back in and try restarting. If it continues to give you the yellow light, you may need to replace the CMOS battery, especially if it is more than two years old.
Another thing to consider is if your power supply is underpowered for the number of external devices you have plugged into it (i.e., cd, dvd, external hard drives, printers, pci cards, etc). Gateway installed very low powered power supplies in their 700xl desktop computers. Usually only around 250 watts maximum.
If you are replacing the power supply with another 250 watt maximum power supply, and you have a lot of external devices plugged in, you may need at least a 350 watt power supply....if your CMOS battery is not the problem.
Nov 06, 2008 | Gateway 700 XL PC Desktop
Can not power up
To my personal experience eMachine MB's dies a slow aggravating death. I have had 2 that went janky and would take about 15 power up tries to boot. Probably the situation you are in now.
Did the power supply you had go bad? I seem to recall a bit of an issue with some older machines in the 2k series that when the Power supply died it took out the MB with it.
Sep 28, 2008 | E-Machines eMachines Desktop PC
CPU incompatibil
Sep 22, 2008 | Intel D845GVSR Motherboard
Intel D845GVSR Motherboard Logo
104 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
