My philips hts3154 home theatre system has just frozen up. it's stuck on 'disc', i can't change source or function ot even turn the thing off or on using either the remote or the buttons on the unit itslef.
  • r_bthomas Sep 22, 2008
    Thanks. Many times,,no luck,
    Scholar:
  • 148 Answers
How to Remove a Stuck DVD From Your DVD Player
  1. Unplug the DVD player and take the outer casing of the DVD player off. This entails either taking out two or three screws or simply sliding one of the pieces of plastic in either direction.
  2. Locate the disc loader cover. The disc loader cover is located where the extending DVD tray finally comes to rest within the DVD player. It’s the part that holds the DVD loader in place.
  3. Bend the two tabs outward that hold the loader in place. This is a delicate procedure because you don’t want to hurt the device. The tabs are relatively easy to break since they're plastic in most cases.
  4. Slide the disc tray out. If your disc got stuck before it was read, it's probably still on this tray. If so, your problem is solved. However, if the disc was fully set and loaded, the job isn’t quite finished yet.
  5. Move the small mechanical arm that holds the disc in place over so that the disc and the reader are both exposed. Some DVD players will not have anything holding the disc in place. Instead, these devices use a system not unlike that of a common DVD case. The DVD will be locked in place in the center.
  6. Carefully lift the disc up and out of its loaded position in the DVD player. This may entail sliding the disc reading mechanism over slightly. This won't hurt the device as long as you’re careful. You should be able to access and remove the disc.
Posted on Sep 19, 2008
  • Zander Rovic Ocampo
    Zander Rovic Ocampo Sep 19, 2008
    • Before you remove the DVD player cover, try
      turning the device off and then back on to see if the disc will come
      out after the machine has rebooted.
    • Use the opportunity while you have the outer casing off to clean the lens of your DVD player.
    • Never work on an electrical device that's still plugged in.
    • Opening a DVD player may negate the warranty. Read yours carefully before you proceed.
  • 2,336 Answers
Have you try unplugging your device from the main power source and plug it back in after?
Sometimes it works.
I dont have Aux in function in my philips home theatre model lx2600d Is there any way to create aux in to my philips home theatre?
Does your unit have any analog inputs? If you only have digital inputs, you can purchase a analog to digital adapter. For more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 20, 2013 | Philips SoundBar DVD Home Theater with...
Philips hts6600 remote stoped functioning
Did you get any answer as i faced same problem... and it's hard to find out how to fiw or even replace it
Sep 20, 2012 | Philips HTS 6600/12 Home Theatre...
Surround system did not come with manual
You did not indicate the model of your home theatre system. The Philips websites can be a source of information including the Quick Start Guide and User Manual.
For the Philips Blu-ray Home Theatre Sysytem see here.
If this not your model try searching the site. You may also switch to your country of purchase in the top right corner of the website.
If you require further help, please reply with your model information.
Jan 08, 2012 | Philips Audio Players & Recorders
My philips dvd home theatre system shows bad disc all inserted into it after some time even original newones.
It sounds to me like the laser is broken, the little red laser that reads the cd. It might have gotten scratched by a cd being put in or taken out the wrong way. But new ones should not do that. I might be wrong, I am not an expert at home theater systems but thats sounds like the problem from what you explained.
Jun 23, 2010 | Philips DivX Ultra HTS6500/37 Theater...
Corrupted Firmware on Philips HTS3555 Home Theatre System
Only posibility is finding a service shop that services Philips....
Mar 23, 2010 | Philips HTS3544/37 Theater System
Philips Home theatre system HTS3000
try to clean the lens of your player with the cd lens cleaner available in the computer store or appliance store.
Jul 20, 2008 | Audio Players & Recorders
Have a philips tv and a home theatre system but the remote off the surround system just changes the tv settings. Its kind of frustrating when I want to watch a dvd! Do I have to assign a freq?
When you press a function key on the remote control, not only does it change the function on the system (eg DISC, TUNER, TV etc) but it also changes the function on the remote.
However, if you change the function or source on the system, then only the system changes.
It sounds like you have changed the function on the system to DVD, but the remote is still set to TV. When in TV mode the remote will send Philips TV codes.
Press the DVD or DISC button on the remote.
May 10, 2008 | Televison & Video
Televison & Video Logo
194 people viewed this question
Top Televison & Video Experts
