Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Figidaire Dishwasher ModelFDB65BRAC1
The dishwasher is not draining. The water is just sitting in the bottom of the dishwasher.
I just had this problem with a zanussi dishwasher - I opened it this afternoon to find the bottom full of water - luckily not deep enough to flood my kitchen when I opened the door. I determined that the sink drain was clear (ran water, could hear it going down the drain outside), so the problem had to be in the dishwasher or drain hose. I poured just a little mr muscle sink & plughole unblocker in the bottom of the machine where the trap is, left it about 30 mins as per instructions, followed by a little boiled water - no difference. Scooped out the water, removed the filter (the big round bit, not just the trap that you pull out and empty) and scooped out till I could see what appears to be the out pipe. Thought what the heck and ran a rinse cycle - no dishes, no detergent and lower tray and arm thing removed for convenience. Water drained just fine, ran a second rinse cycle which got rid of the suds from the plughole unblocker. I now have an extremely clean and sparkling dishwasher and am about to run a load of dishes through it.
I hope that my post is helpful to you, I don't know if all the steps are necessary, it may have been a freak occurrence that would have gone away with a simple rinse cycle. It may of course be a problem with the pump on yours, I was hoping that wasn't the case on mine, and I had lots of old towels on hand in case water came out when I opened the door. But it's possible your machine has the same problem as mine and that this info works for you, I hope that is the case.
Posted on Sep 19, 2008
How do I fix a frigidaire galarie dishwasher. The water will not drain out of the bottom
if you bought it new it is under warranty and if you do anything repair wise you void any you have left contact the seller
Mar 21, 2015 | Frigidaire Dishwashers
Our dishwasher will not empty the water. we have checked all drains and pipes and everything is clear. the water just sits in bottom of dishwasher
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Aug 14, 2011 | Bosch Dishwashers
Water is not draining out of the bottom of the dishwasher and is sitting in the bottom
heatman101
Apr 27, 2011 | Maytag Dishwasher
Water is sitting in bottom after cycle is done.
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Aug 27, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Not draining properly
Check for plugged drain hoses in your dishwasher, also make sure that the pump is working correctly
May 06, 2010 | Kenmore 24 in. 15689 Built-in Dishwasher
DIshwasher doesn't drain. 3-4 inches of water sits in the bottom
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Sep 25, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwasher did not drain all the water - water sitting in bottom of dishwasher
start and cancel cycle to drain the water out and check the position of your drain hose.....water is probably backwashing into the d/w, hose should leave the drain and go up to the height of the d/w
Jun 10, 2009 | Dishwashers
Water sitting on the bottom of the dishwasher
disconnect it from you drain and put it into a bucket. Then start a program and then cancel it, the begining should start with a drain anyway. Then you will see if any water comes out. You can also take a shop vac after to get the water out to see if there is any stuck there.
Sgt 48
Apr 25, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
266 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
