SOURCE: Linksys WRT150N is connected to
Reset the router for 30 seconds. Then power cycle the router and modem.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
I only have 3 suggestions.
1st one is to make sure the ssid is not similar to other routers you are using on your profile. ie.(change it to a unique name)
2nd is to make sure you check the box that says broadcast your ssid.
3rd check to make sure you select the router as an access point and not adhoc or infrastructure option. Finally you can try to change the channels eg. i like channel 3 b/c it doesnt interfere with any phone lines.
good luck
smeags.
please clarify,do u have a question or giving it away? if giving away i will take it!
