Question about InstallShield Update Service Version 3
Installshield 3 Help (maybe)
I need to go back and install an application that is using Installshield 3. I've tried installing it on a NT4 (VM), a windows 2000, and XP and all produce the same error on file Setup.INS. The script was created using installshield3. Recompile the script using Installshield SDK. I am not a developer. I've been trying to find an answer on google for about 12 hours. Other than finding that Installshield was sold twice in the last 8 years (I think) I have gained little else. The Setup.INS file has a date of 8/20/1999. What do I need to do to install this app? Thanks in advance for your answers.
I didn't get a solution but the project was dropped. I don't have to do this install.
Posted on Sep 21, 2008
I am tryign to uninstall fix it, get error 5006
Installation or uninstallation of an application or game fails and gives the following error code:
This issue is due to a previous installation not finishing properly
Solution 1. Rename the Installshield folder
Make sure you've enabled Show hidden files and folders.
Find and rename the Installshield folder:
Windows 32-bit: C:\Program Files\Common Files\Installshield
Windows 64-bit: C:\Program Files (x86)\Common Files\Installshield
If there is an Installshield file in the Common Files folder, rename that one also (e.g. to Installshield_OLD).
Solution 2. Remove all traces of previous uninstall
If renaming the Installshield folder had no effect, find and delete any traces of uninstalled applications.
Applications that can assist you are: Revo Uninstaller, Windows Installer Cleanup Utility , CCleaner.
Alternatively, do a manual clean-up:
Close all running programs. Then clear the Temp folder (found via input of %temp% in Start > Search or Start > Run).
Use the Windows registry editor to delete registry entries related to the program.
Restart the computer.
hope this helps
Sep 10, 2012 | Microsoft Windows Vista Home Basic Edition...
Errorvalue c000009c disk type 5 i had flexerasoftware install shield 2010.exe from saturn.installshield.com i down loaded it but my computer won't let me use it can you help me i hope so. mary ...
Looks like a dll registration failure and/ or a Permission problem.
  • Please go to your Event Viewer. (Start -> Run -> Type in Eventvwr.msc and hit enter)
  • Go to Application category
  • Check for the Errors (Red X) and read the description and make sure that program is the one returned the error
  • Post here the errors with details.
  • You can use this Link to browse or ask for assistance from InstallShield
Thanks and have a good day! -Lasitha
Jul 17, 2010 | Computers & Internet
I just installed windows XP service pack 3, installshield errors
Hi, "I hope this will help you out with the problem! Try this Link: http://www.technospot.net/blogs/download-directx-10-for-windows-xp-from-alky-project/ "If this help? Feedback is appreciated, thanks paul7of9."
Feb 04, 2010 | InstallShield Update Service Version 3
Looking for wireless on switch on laptop
Right Side, underneath your volume control. If it is switched on and still cant access the internet wireless give this a try.
Use Control Panel's Add or Remove Programs utility to uninstall the Toshiba Hotkey Utility, and then reinstall it.
This program is called E-Key Utility on the Toshiba Satellite M30X/M35X Recovery and Applications/Drivers DVD. It's called Toshiba E-Key Utility for Windows XP on the Toshiba Support website.
Unistalling the Toshiba Hotkey Utility:
  1. Click Start.
  2. Click Control Panel.
  3. Double-click Add or Remove Programs.
  4. Select TOSHIBA Hotkey Utility.
  5. Click Change/Remove.
  6. Click OK to confirm that you wish to completely remove the selected application and its features. The InstallShield Wizard will begin the removal process.
  7. Click Finish to exit the InstallShield Wizard.
Re-installing the Toshiba Hotkey Utility using the Toshiba Satellite M30X/M35X Series Recovery and Applications/Drivers DVD that shipped with the computer:
  1. Insert the Toshiba Satellite M30X/M35X Series Recovery and Applications/Drivers DVD into the CD/DVD drive and close the tray. The setup program on the DVD should start automatically.
  2. When the Toshiba Recovery and Applications CD window appears, verify that "Install applications and drivers" is the selected install type, and click Next.
  3. Select E-key Utility from the list, and click Install.
  4. When the WinZip Self-Extractor window appears, click OK.
  5. Click Unzip.
  6. Click OK to acknowledge that the files were successfully unzipped.
  7. When the InstallShield window appears, click Next and follow the prompts to complete the installation.
  8. When the installation is complete, click Exit and then OK to close the Toshiba Recovery and Applications CD window.
  9. Remove the Toshiba Satellite M30X/M35X Series Recovery and Applications/Drivers DVD from the optical drive and close the tray.
Reinstalling the Toshiba Hotkey Utility using the file downloaded from the Toshiba Support website:
  1. Download the Toshiba E-key Utility for Windows XP from the Toshiba Support website, and save it to your computer. See also the bulletin Obtaining downloads and support docs from the Toshiba Support website.
  2. Navigate to where you saved the file and double-click it.
  3. Click Run.
  5. Click Unzip.
Feb 21, 2009 | Toshiba Satellite M35X-S111 Notebook
Camera wont download the photos.
http://digiblue.com/customer-service/downloads/drivers/SQ905C_DSC_Drive_XP_Vista_DigitalBlue_V2.005_2007MAY24.exe
if you are using windows vista use the following above link to download the new driver.
1) Please install the Disney Pix 2 software and the Disney Pix Micro Downloader to your computer via the software CD that came with the Disney Pix Micro
2) Please double-click on the "Setup" to begin the install of the Pix Micro drivers. The User Account Control will appear warning you that a program is trying to run. Please click "Allow".
3) Complete the install of the driver by following the prompts.
4) After the install completes, you are prompted to restart the computer. Please select "Restart now" and then click "Finish".
5) You can now delete the Setup program from your computer
6) Connect your Disney Pix Micro to the computer and wait for the device to install.
7) Double-Click on the Downloader shortcut to open the downloader
Now the Pix Micro Downloader is open with the correct privileges and the Pix Micro camera is connected. If you click the "Download" button. A dialog box appears saying "Pixel Up".
Please click the "OK" button and the download will complete successfully. The images can even be deleted via the downloader after the images are downloaded. Although, every time you open the downloader, you must run it as an administrator and every time you download, the "Pixel Up" box will appear.
If you are having a problem installing a product that uses InstallShield as their installation tool, and the steps below do not resolve your issue, you will need to contact the vendor of the software, as we cannot provide further support. Your vendor, who used InstallShield as an installation tool, created the product that you are trying to install. It is very likely that the error you are getting is related to how the vendor used our product and only the vendor would know which InstallShield product they used, which version and how they programmed it. Thank you for your understanding and patience.
This article applies to the following errors when trying to install an application that uses InstallShield:
Error extracting support files
Error installing Ikernel.exe (0x any number)
Access is denied
Error loading Type Library/DLL
Discussion
Detect Version
Different troubleshooting steps are necessary for different version of InstallShield. To check the version of InstallShield Professional that was used to create the setup, take the following steps:
1.Right-click on the setup.exe
2.Select "Properties".
3.In the Properties dialog, select the tab labeled "Version".
4.Near the top there will be a filed labeled "File Version". The number specified here will tell you approximately what version of InstallShield was used to create this install.
InstallShield 5.x and 3.x
If the version of InstallShield is less than 6.00, see article Q100198, HOWTO: Eliminating General Setup Initialization Errors.
InstallShield 6.x
If the version is 6.00 or greater, continue with the following steps.
Setup initialization errors can be caused by a number of factors. This is a non-exhaustive list of possible resolutions:
1.Insufficient permissions on the machine. If you are using a Windows NT or a Windows 2000 machine, you need to have administrative permissions to run an InstallShield Professional 6.x setup. Make sure you have the correct permissions.
2.If you just ran an InstallShield setup, the engine takes a few seconds at the end of the installation to clean up. During this time Ikernel.exe (the engine file) is running in memory from a previous process. That is why you are not allowed to launch another setup. Waiting a few seconds and running the setup again should resolve this.
3.Check and make sure Ikernel.exe is not in memory. If it is, and no setup is running at the time, end that task and restart the system.
4.Clean out the Temp directory.
5.Delete the Program Files\Common Files\InstallShield\Engine folder and then rerun the setup.
6.Reinstalling Internet Explorer (IE) 5.x can also repair a number of corrupted/missing core Windows files from your machine, so reinstalling IE 5.x and the NT service pack is also suggested.
7.Another possibility is that you do not have sufficient COM permissions. For information on how to troubleshoot this, see article Q104986, INFO: Initialization Error Troubleshooting.
8.The other potential cause is a missing Stdole.tlb file. This is a core Windows file and should exist on your machine. Make sure that if you get this file from another machine, the machine is running the same operation system as the machine you are trying to run the setup on.
9.If you are trying to install to a Windows 98 machine, download and run Dcom98.exe from the following site: http://www.microsoft.com/com/dcom/dcom98/download.asp.
10.Make sure that you are using the latest version of the InstallShield engine. To install the latest engine see article Q105097, INFO: Install the Latest Version of Ikernel.exe
Aug 01, 2008 | Disney Pix Micro Digital Camera
Try to install D-LINK DWL G630, get error 1607, windows xp
Error 1607 appears while trying to install the product. The installer is unable to invoke "InstallShield", a third-party utility used to perform the installation.
Step 1
  1. Select Start, Run, and type REGEDT32. Click OK.
  2. Browse to the following key:
    HKEY_LOCAL_MACHINE\SOFTWARE\InstallShield
  3. Check the permissions on this key:
    Windows XP: right click and select "Permissions"
    Windows 2000/NT: navigate to the "Security" menu and then select "Permissions"
  4. If not already assigned, assign "Full Control" to the following groups:
    a. Administrators
    b. SYSTEM
  5. Reboot the computer
  6. Try the installation again
Step 2
If step 1 did not correct the problem, please see this article on the InstallShield web site.
HERE is a link to the Microsoft Knowledge database that may be of help as well. (ALthough it mentions its for games, it should work with any software)
Should you have any further questions, please feel free to post them here. Please do not assign a rating until you feel your problem is resolved. I will try my best to help you further if need be.
If you are satisfied with my solution or have no other questions, please close the problem by assigning a FIXYA rating for my solution. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Apr 19, 2008 | Computers & Internet
Photo explosion deluxe will not install
Hello Again...
Install the InstallShield InstallScript engine. To do this, you will need to click on the following link to download the IsScript.zip file:
http://support.installshield.com/kb/files/Q107094/IsScript.zip
When prompted to Run or Save the file, select the Save option and select a location to save it, such as your desktop. After the file has completed the download, double-click on the file to open it. Extract the IsScript.msi file to a location, such as your desktop. Once that is extracted, double-click on that file to run the IsScript installation. After this installation has been performed, reboot your computer and try to install the software again.
This Should Solve your Issue...
Kindly give a feed back to Improve my statistics by Rating My Advise and to see If it was helpful for you...
Thanks and Regards
Mar 28, 2008 | Computers & Internet
Create automatic software installation packge
The complete installation authoring solution, includes trialware functioanlity, network repositories, multilingual support and the Update Service Starter Edition. FLEXnet InstallShield enables developers to stay current with today’s fast-moving technology market by introducing new functionality for authoring strong and reliable installations. New capabilities, such as MSI 3.0 support, automatic updating of XML file settings, and Trialware functionality, allow developers to add more power and flexibility into their setup projects.
The Premier edition includes:
* InstallShield Collaboration 5-pack license
* A centralized repository
* Standalone Build engine
* FLEXnet InstallShield Repackager
* Support for 33 languages
Key Benefits:
* Maximize team efficiencies to develop industry-standard Windows-based installations
* Stay current—Version 12 supports the latest Microsoft technologies, including SQL Server 2005, Windows Mobile 5.0, and DIFx 2.01
* "Get Ready for Vista" with support for the latest beta of Microsoft Windows Vista—including Internet Explorer 7, Windows Installer 4, and other exciting new technologies
Top NEW Features:
* Major InstallScript Engine Overhaul for Increased Reliability
* FLEXnet InstallShield Repackager Project Conversion Tool
* FLEXnet InstallShield Collaboration 5-pack License
* Standalone Build Engine — A Premier-Only Feature
* Includes All of the Features of the Professional Edition
Download From RapidShare :
http://rapidshare.com/files/36259663/MIS12PE.part1.rar
http://rapidshare.com/files/36261408/MIS12PE.part2.rar
Megaupload :
http://www.megaupload.com/?d=UG50AA5J
http://www.megaupload.com/?d=8TJFHUWB
Keymaker and how to Crack The Application
http://rapidshare.com/files/36256423...ntructions.rar
http://www.megaupload.com/?d=HD4MFSK9
http://d01.megashares.com/?d01=9d94422
http://www.sendspace.com/file/isomil
http://www.filefactory.com/file/0758fd/
http://www.zshare.net/download/221091612d139f/
http://www.mediafire.com/?49xajgf1s11
http://depositfiles.com/files/994711
If That Helpful Please Rate
Sep 26, 2007 | Tablets & eReaders
Desktop Software Will Not Load!
The problem that you are encountering right now is a windows problem. "idriver.exe" is related to the installshield application on your computer and installshield is used to install application on your computer, so if idriver is not working, installshield will not work also. I suggest try the windows update. It might fix the problem.
Sep 11, 2005 | Palm Tungsten E Handheld
InstallShield Update Service Version 3 Logo
320 people viewed this question
Top InstallShield Computers & Internet Experts
Robin Hill
Robin Hill
Jon Slaton
Jon Slaton
Are you an InstallShield Computer and Internet Expert? Answer questions, earn points and help others
