E-Machines M2352 Notebook Logo
Posted on Sep 19, 2008
Want to hook up my blackberry as a modem - E-Machines M2352 Notebook
I want to use my blackberry 8520 as modem to my laptop
Yes. I used to do that before 3G became popular.
The Dial Code depends on the country and carrier. I used *666#
Set Up a Dial-up Connection
You'll need to set up a dial-up connection on your Windows machine to use the BlackBerry modem. When you installed the BlackBerry Desktop Manager, it should have automatically installed the modem drivers to use with your device, and you should have a modem called "Standard Modem" in the Phone andModem Options section of your Control Panel. The drivers are located in the following folder: C:\Program Files\Common Files\Research In Motion\Modem Drivers. Use the following steps to set up your connection:
  1. Connect your BlackBerry to your computer using the standard USB cable that came with your device and start the BlackBerry Desktop Manager software.
  2. Go to the Control Panel, then Network Connections, and select Create a New Connection.
  3. Select Connect to the Internet, then Set up my connection manually, then Connect using a dial-up modem, and select your BlackBerry modem from the device list.
  4. Choose a descriptive name for the ISP Name (e.g., BlackBerry Modem Connection).
  5. Enter the phone number for your service provider. You'll probably have to check with your carrier to get the right number. For Cingular and other GSM carriers (AT&T, T-Mobile), it's *99#. For CDMA providers (Sprint, Verizon), the number will be #777.
  6. The username and password will vary by carrier as well. Cingular just accepts null values for both fields.
  7. Complete the wizard, being sure to deselect the "Make this the default connection" checkbox.
How to use Blackberry Curve phone as modem O2 Guru TV
My 8330 does not let me browse the internet on my
Hi BlackBerry smartphone with tethered modem capabilities can be used as an external modem to connect a computer to the Internet.
To set up a tethered modem, complete the following tasks from A to D
A) Install BlackBerry Desktop Software 4.1 or later on your computer.
B) To set up an Internet APN, complete the following steps:
1) Click Start > Settings > Control Panel.
2) Double-click Phone and Modem Options.
3) In the Phone and Modem Options window, click the Modems tab.
4) Select Standard Modem and click Properties.
5) Click Change Settings.
6) In the Standard Modem Properties window, click the Advanced tab.
7) In the Extra initialization commands field, type the following:
+cgdcont=1,"IP","<your Internet APN>"
The extra initialization command is: +cgdcont=1,"IP","wap.voicestream.com"
8) Click OK.
9) In the Phone and Modem Options window, click OK.
C) To configure dial-up networking, complete the procedure that is appropriate for Windows Vista
1) Click Start.
2) Select Connect To.
3) Click Setup a connection or network.
4) Click Setup a dialup connection.
5) In the Dial-up phone number field type *99#.
6) Type the user name and password provided by your wireless service provider.
7) In the Connection Name field type BlackBerry.
8) Click Dialing Rules.
9) Make sure the profile created in Task 2 has been selected, and then click OK.
10) Select Connect to establish an Internet.
D) To connect to the Internet using dial-up networking, complete the following steps:
During this procedure, do not operate the BlackBerry Browser or any third-party applications on the BlackBerry smartphone. An active data session might interfere with the modem connection. Also, make sure an ethernet connection is not active at the same time.
1) Connect the BlackBerry smartphone to the computer.
2) Open BlackBerry Desktop Manager.
3) Click Start > Settings > Network Connections > <name of your new connection>.
4) Type the user name and password provided by your wireless service provider.
5) Click Dial.I hope this information will help you
Modem
Found this after some deep looking from blackberry itself: Good Luck
A BlackBerry smartphone with tethered modem capabilities can be used as an external modem to connect a computer to the Internet.
Summary of Tasks To set up a tethered modem, complete the following tasks:
  1. Install BlackBerry Desktop Software 4.1 or later (one time only).
  2. Set up the Internet access point name (APN) (one time only).
  3. Configure dial-up networking (one time only).
  4. Connect to the Internet using dial-up networking.
Task 1
When you install BlackBerry Desktop Software, the drivers that allow the BlackBerry smartphone to communicate through the Universal Serial Bus (USB) port and virtual communications port are installed. The standard modem, which is used by dial-up networking, is also installed.
Note: If upgrading your BlackBerry Desktop Software from version 4.0 to 4.1, the required virtual communications port and standard modem might be removed during the upgrade process. If this is the case, re-install the BlackBerry Desktop Software 4.1 or later and choose the Repair option to re-install these components.
Task 2
Set up an Internet APN.
  1. Click Start > Settings > Control Panel.
  2. Double-click Phone and Modem Options.
  3. In the Phone and Modem Options window, click the Modems tab.
  4. Select Standard Modem and click Properties.
  5. Click Change Settings.
  6. In the Standard Modem Properties window, click the Advanced tab.
  7. In the Extra initialization commands field, type the following: +cgdcont=1,"IP","<your Internet APN>"
    Note: The following is applicable for T-Mobile® customers only:
    Note: If you do not know your Internet APN, or if you do not have an Internet APN, contact your service provider.
  8. Click OK.
  9. In the Phone and Modem Options window, click OK.
Task 3
To configure dial-up networking, complete the procedure that is appropriate to the operating system you are using:
Windows Vista
  1. Click Start.
  2. Select Connect To.
  3. Click Setup a connection or network.
  4. Click Setup a dialup connection.
  5. In the Dial-up phone number field type *99#.
  6. Type the user name and password provided by your service provider.
  7. In the Connection Name field type BlackBerry.
  8. Click Dialing Rules.
  9. Make sure the profile created in Task 2 has been selected, and then click OK.
  10. Select Connect to establish an internet.
Note: For instructions on connecting a computer to the Internet using a BlackBerry smartphone with CDMA as a tethered modem, see KB04664.
Windows XP operating system
  1. Click Start > Settings > Network Connections.
  2. Double-click New Connection Wizard. The New Connection Wizard opens.
  3. Click Next.
  4. Select the Connect to the Internet option. Click Next.
  5. Select Set up my connection manually. Click Next.
  6. Select Connect using a dial-up modem. Click Next.
  7. If the Select a Device screen appears, select the Modem - Standard Modem check box. Click Next.
  8. In the ISP Name field, type a name for your connection. Click Next.
  9. In the Phone number field, type *99#. Click Next.
  10. Indicate which users will have access to the connection. Click Next.
  11. Type the user name and password provided by your service provider. Click Next.
  12. Click Finish.
  13. In the Connect window, click Properties.
  14. In the Properties window, verify that Modem - Standard Modem appears beneath the Connect using heading, and then click Configure.
  15. In the Modem Configuration window, clear the Enable hardware flow control check box and make sure none of the other check boxes are selected. Click OK. In the Properties window, click OK.
Windows 2000 operating system
  2. Double-click Network and Dial-up Connections. Note: The following is applicable for T-Mobile customers only:
    Under the networking tab in the properties window for the dial-up connection, clear the Enable LCP Extensions check box, as well as all check boxes beneath the PPP Settings window.
  3. Double-click Make New Connection. The Network Connection Wizard opens.
  4. Click Next.
  5. Choose Dial-up to private network. Click Next.
  6. In the Phone number field, type *99#. Click Next.
  7. Indicate which users will have access to the connection. Click Next.
  8. Type a name for your connection. Click Finish.
  9. In the Connect window, click Properties.
  10. In the Properties window, verify that Modem - Standard Modem is selected, then click Configure.
  11. In the Modem Configuration window, clear the Enable hardware flow control check box and make sure none of the other check boxes are selected. Click OK.
  12. In the Properties window, click OK.
Task 4
Note: During this procedure, do not operate the BlackBerry® Browser or any third-party applications on the BlackBerry smartphone. An active data session might interfere with the modem connection. Also, make sure an ethernet connection is not active at the same time.
  1. Connect the BlackBerry smartphone to the computer.
  2. Open BlackBerry Desktop Manager.
  3. Click Start > Settings > Network Connections > <name of your new connection>.
  4. Type the user name and password provided by your service provider.
  5. Click Dial.
Blackberry 8700g
You can follow the steps provided in this how to.
http://www.blackberryforums.com/blackberry-guides/2019-user-howto-use-blackberry-modem-laptop.html
best regards
p.s. You should check if your blackberry has a build in modem in it.
2answers
RIM blackberry 8310 Curve as a modem
This is the web page for the Blackberry explaining exactly how to use it as a modem...
Blackberry 8310 as a modem problem
make sure you have PAM DATA service with your provider you will also need your carriers PAM software to ge this to work
2helpful
2answers
8350i modem problem
BlackBerry 8350i does not support "Phone as Modem" straight out of the box :(
Your best solution would be to try Shark Modem. It's a BlackBerry application that allows you to use your BlackBerry modem. 8350i BlackBerry Modem Application
Confirmed that the 8350i doesn't support modem > here
1helpful
2answers
Usb modem driver
Try to searh in softpaedia.com or download.com
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
