Question about Harman Kardon Televison & Video
Hello My Harmon Kardon 680i Will not keep memory on radio channel.And I always get a lost of static when first turn on, and you hear only one speaker, Until it warm up. After a period of time on it work fine. Is because I don't play it all time or what thanks Johnnie
There is a board mounted NiCad battery inside that needs to be replaced. Not too tough, but it is soldered in, and you must make sure you use a NiCad only.
Posted on Jul 16, 2009
A disk is stuck in my Harmon Kardon player. The door will open and close and I can see the disk but cant' get it out.
turn on the unit and then tried to press the play button while the cd tray is in place. if doesn't work, unplug the dvd player then open the cover to access the internal part. look for a broken limit switch for cd tray mechanical assembly or check weather the cd not in proper place in the tray that is why an error occur.
Sep 02, 2012 | Televison & Video
Hello! My harmon kardon hs100 constantly blinks an amber light and is inoperatable. I tried plugging it out in fact for months I did so and still not working power light still blinking amber.
This is due to a audio output problem in the amp, first check the speaker wires for shorts, if okay! the audio output semiconductors must be replaced to remedy the situation.
Apr 06, 2012 | Harman Kardon DVD31 DVD Player
Disc error
Ok, disc error happens for 2 reasons....1. If this is self made dvd, it wasn't finalized, or, as was already said the lens is dirty. If you feel up to it, unplug it, and remove the top....if you can get to the lens, simply apply rubbing alcohol with a q tip. Hopefully, it fixes the problem.
Dec 08, 2011 | Harman Kardon DVD 25 DVD Player
Power on but nothing works
It may havenot been used for sometime.There could be a few answers to this, so i`m trying likeliest first.
I think or we have to eliminate the build up of condensation in the dvd.
Put the dvd and remote in a warm room plug in, and leave for 2-3 hrs,then fingers crossed try the dvd again.
Dec 03, 2009 | Harman Kardon DVD-22 DVD Player
Can't figure out what channel to put radio on to get sound for dvd in car
The only way to hear it through the car radio is if it has a built in fm modulator installed.
Usually the car manufacturers use the lowest (or close to it) number on the dial. 88.7...88.9 etc.
On some factory installed units - you must press SOURCE for the DVD sound.
If it is aftermarket - an FM transmitter is almos alwyays part of the unit - and you'll have to find the proper channel.
Stick in a music CD, and then scan the stations manually.
Some FM Modulators use only 4 selectable channels... and some can use any channel.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 02, 2009 | Televison & Video
Panasonic DMR EH75V - no channel guide after power went out
since there was power failure , the settings( channel guide) that u had programmed has got earsed completly & u will have to reprogram (memorise)them
this has happened because there is a small capacitor(looks like a small battery) which keeps the memory has lost its charge & needs to be replaced.its job is to store the details in case of power failure!!!
Feb 08, 2009 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
My HK dvd101 player reports "disk error" with every disk
Hello Fixya Team,
I've focused in on the location of the problem. ATT, I'm trying to find a replacement input control board from Harmon. Not looking good tho. It acts like a cold solder joint or a flaky connector.
Thanks for getting back to me. If I end up stuck, I'll get back to you.
TKS,
BG
Jan 29, 2009 | Harman Kardon DVD 101 DVD Player
Harmon Kardon and Infinity Modulus
I got the answer for No-1.
The balance was turned on the Right Channel. That is why Left Channel was not working during the Channel test.
For Channel test the Balance should be in the middle so that both Right and Left Would be heard.
I am working on my Subwoofer Isuue.
I opened the Back Panel and Yet I could ot figure out any issues.
I will open the front panel and see if any connection is loose.
Dec 29, 2008 | Televison & Video
Audio static through DVD Recorder
I your TruTech T650-DR is geting real hot turn it off its over heating.
If thats the case then your not setup right. What ever is gonig on dont keep using it, its gonig to burn out. cheek to make shure you have every thing plug in right.
Oct 17, 2007 | TruTech T650-DR DVD Recorder
Remote control freeze
Hi friend have a tech check your remote it could be damage and not transmitting signals to verify that take a radio and tune into AM point the remote it press the button on the remote.you should hear some static noise like putty putty putty constantly if you do not hear that then you could say that your remote is damage.if not then have a tech look at your set the IR could be bad and needs to be replaced.good luck.
Apr 06, 2007 | Samsung DVD-R130 DVD Recorder
Televison & Video Logo
169 people viewed this question
Top Harman Kardon Televison & Video Experts
Electro Med Services...
hims Patel
Are you a Harman Kardon Televison and Video Expert? Answer questions, earn points and help others
