Question about Samsung Sp-H710AE Multimedia Projector
Lamp shutss off after about a minuet or so..
Lamp shutts off after about a minuet or so..
the wierd problem is.. the lamp does not shutt off.. and everthing seem to work fine if the unit is set on either of its sides.
any help is appreciated. thanks. JR
  • Samsung Master
  • 5,568 Answers
Sounds a lot like a heat problem; the unit may not be running hot but there may be a bimetal thermal switch that has become fussy.
If you have an electronics supply nearby, they will have 'freeze spray' and if you procure it, you can see if the projector will turn back on if you give it a shot in a vent. Do NOT spray it on a hot lamp; it may cause it to fracture.
I would also keep it out of the reach of kids since it can impart a nasty 'burn' if misused.
If this does make it turn back on, you will have to come back and seek help in locating the failing switch although the common ones are disc-shaped with two contacts coming from them.
This construction is failing in 100s of thousands of drip coffee makers too.
Posted on Sep 19, 2008
My Sanyo plc su20n comes on but shutts off after a couple of minutes. Does not give a temp warning just ready indicator goes of and picture goes off. IF you wait a couple of minutes the ready light will...
check the physical nature of the lamp in the projector. around the filament of the lamp, you might notice dark corrosion building around it. this what normally cause premature shut off.
Sep 14, 2011 | Sanyo PLC SU20N Multimedia Projector
Tv repeatedly starts at and shutts down. Lamp come on but then shuts down
Those lamps build up a internal resistance and they get to the point where it will not come on at all, replace the lamp, and you will be good.
Oct 18, 2010 | Samsung HL-S4666W Television
It shutts off ramdomly the red lite blikes an have to what for green light to come on before it turns back on
Tv "LAMP" LED lite indication flashes or staying on?The tv projection lamp life is over.The projection lamp require changing.
Aug 06, 2010 | Panasonic PT-50LC14 50" Rear Projection...
Lamp keeps going off an on (1 min intervals)
I will need the model number of your set. The HD52W59 doesnt have a lamp as thats a three picture tube TV.
Jun 26, 2010 | RCA HD52W59 HDTV Projection Television
I have a kdf-50e2000. when i turn on the power the green light comes on then goes off and red light comes on blinks 3 times on power and screen stays black. changed lamp and reinstalled(just bulb). picture...
Check the lamp door switch. This switch is really cheaply made. The switch is not available. short rhe wires to fix the problem. then never change the lamp witout unplugging the ac power in the future.
Oct 30, 2009 | Televison & Video
Replaced bulb but unit goes through cool down then shutts off
You can't, since the unit doesn't have the ability to do what the remote can do. However, the remotes are inexpensive and easy to obtain. Simply type in "Cinego Remote" as a search expression on your search engine, and several places will pop up. Alternatively, contact your local Radio Shack store.
Jun 26, 2009 | Radio Shack Cinego D-1000 Multimedia...
I have replaced the lamp.Now the lamp wont come on and tv shutts
Did you replace the lamp cover after replacing the lamp? Make sure the cover is properly installed.
Jan 21, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Tv shutting off after turning on
replace your lamp, that should solve your problem
Nov 08, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Cinego Automatically shutts off after 15 seconds
had the same problem - replaced the lamp even though it only had 632 hours on it. seemed to fix the problem - 10 hours and 4 moves later still doing ok
Jun 12, 2007 | Radio Shack Cinego D-1000 Multimedia...
Samsung Sp-H710AE Multimedia Projector Logo
203 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
