Posted on Sep 19, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a HP psc1510 all in one, when i turn on the power on the check print cartridge button flashes yet it has new catrdiges in, and when i press the buttons on the printer intself there is no repsonse
Anonymous
Level 2:
  • Expert 84 Answers
  • Posted on Sep 19, 2008
Anonymous
Expert
Level 2:
Answers
84
Questions
0
Helped
28010
Points
238
New carts have shipping tape removed? Installed correctly ...
remove them and reinstall
1helpful
Hp deskjet 948c. What Do The Button's Do
buttons and lights The HP Deskjet printer buttons let you turn the printer on and off, cancel a print job, or resume printing. The lights give you visual cues about the state of the printer
sayurisan20_33.jpgcancel button
print cartridge status symbol and light **The light above the Print Cartridge Status symbol flashes when a print cartridge is low on ink or incorrectly installed.
sayurisan20_35.jpg resume button and light
**The light above the Resume button flashes when an action is required such as loading paper or clearing a paper jam. When the problem is fixed, press the Resume button to continue printing.
sayurisan20_36.jpg power button and light **
The Power button turns the printer on and off. It takes approximately five seconds for the printer to turn on after you press the Power button. The green light above the Power button flashes when printing is in progress. Caution! Always use the Power button on the front of the printer to turn the printer on and off. Using a power strip, surge protector, or a wallmounted switch to turn the printer on and off may cause premature printer failure
Have hp deskjet 6540 printer. yellow light on right side under x keeps blinking not printing. Am I out of ink?
Follow each of these steps until the problem is resolved:
Remove and then reinsert the print cartridge(s) into the printer.
Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
Manually clean the print cartridges and print cartridge cradles:
Open the printer cover and wait until the carriage moves to the center.
Press the Power button to turn off the printer.
Disconnect power cord from the back of the printer.
Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
Lightly moisten a cotton swab with distilled water.
Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
Reinsert the print cartridges.
Close the printer cover.
Connect the power cord to the back of the printer.
Press the Power button to turn on the printer.
Calibrate the print cartridges.
If the light is still flashing, replace the print cartridges.
1helpful
2answers
Replaced ink cartlidge and now wont print
After replacing the ink cartridge you should print the alignment page to work product perfectly.
Follow the below instructions to print alignment page:
  1. Turn on the HP PSC 1200 or 1300 series product.
  2. Disconnect the USB cable from the all-in-one.
  3. Press the sequence of front panel buttons below to start the print cartridge alignment process. The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
    1. Press and hold Cancel .
    2. While holding Cancel , press On .
    3. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
    4. Press Cancel again.
    5. Press Copies .
    6. Press Paper Type .
    7. Press Color Start Copy . The alignment page will begin printing. If the alignment page does not print, repeat the button-press sequence in this step.
  4. When the alignment page has printed, place the page face down on the scanner glass and press Scan . The alignment is complete when the On light stops blinking.
  5. Reconnect the USB cable.
If the issue still persists, perform semifull reset by following the below instructions
  1. Unplug the power cord from the wall outlet.
  2. Unplug the power cord from the back of the all-in-one.
  3. Wait 30 seconds and plug the power cord back into the wall outlet.
  4. Plug the power cord to the back of the all-in-one.
  5. When the lights begin to flash, press and hold the On/Resume and Number of Copies Buttons.
  6. When only the On/Resume light is flashing, release the buttons.
  7. When the On/Resume light is steady, the reset is complete.
1helpful
"check print cartridge was flashing, so I changed the ink, but it still is flashing. Also, there is an "E" across from the copies button. I disconnected it from the computer and "check print cartridge...
hi, is it hp ink cartridges? did you refill cartridge or replace?
press cancel button, then on/resume. if no change. make sure all tape, paper is removed from ink cartidge connectors and there is no dirt, smudges or adhesive or anything else that may interfere with the connection. reinstall cartridges. if still no change, power off, then disconnect power. wait about 5 mins. reconnect and power on. this should reset the printer.
I have a HP deskjet 6949 series printer. I have had it for three months. My problem is that lights on the from panel(power button light, resume light and print cartridge status light) are blinking...
Power, Resume, and Print Cartridge Status lights are flashing in unison The printer might need to be restarted.
  1. Press the Power button to turn off the printer, and then press the Power button to restart the printer. Proceed to Step 2 if the lights continue to flash.
  2. Press the Power button to turn off the printer.
  3. Disconnect the printer power cord from the electrical outlet.
  4. Reconnect the printer power cord to the electrical outlet.
  5. Press the Power button to turn on the printer.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
2answers
Print cartridge
This may sound simple, but did you remember to remove the tape covering from the ink cartridge before installing it? If so, run a self-test and let me know the results:
1. Turn the printer ON.
2. Press and hold the POWER button.
3. Press the RESUME button FOUR times.
4. Release the POWER button.
You should get a nicely printed self-test. If it fails, there may be other troubleshooting methods we can employ.
I hope this helps!
Regards,
Char1ieJ
My printer is not working properly. The light on the left (Amber Light, I guess this is what it is called) is blinking, but there is no paper stuck in the printer. How do I get it to stop and keep...
hello!
You will see 3 led lights on the printer. They will blink continously if:
if the print cartridge status light is flashing
-- check if the top cover is open, Close the top cover.
-- there may be a problem with a print cartridge
1. Verify that the correct print cartridges are installed.
2. Check if a print cartridge is low on ink or improperly installed.
if the resume light is flashing
-- the printer may be out of paper
1. Place paper in the In tray.
2. Press the Resume button on the front of
-- the printer may be ready to print the second side of a two-sided document
1. Follow the onscreen instructions for printing the second side.
2. Press the Resume button.
if the power light is flashing
-- the printer is preparing to print
-- The light stops flashing when the printer has received all data.
if all lights are flashing
-- the printer may need to be restarted
1. Press the Power button to turn off the printer, then press the Power button
to restart the printer.Proceed to step 2 if the lights continue to flash.
3. Disconnect the printer from the power source.
4. Reconnect the printer to the power source.Press the Power button to turn on the printer.
Light flashing printer no print
unplug the (USB or Parallel) cable of the Printer from Printer backside which is connected to the Computer
open the top lid of the printer and check whether the carriage comes to middle or not?
It it moves automatically, then its fine.
Check the cartridges.
click the URL Link giveb below it will open a webpage. If it does not open a webpage then please copy the entire link and paste it in the address bar of the internet browser and click on "GO"
HP Deskjet 800 Series Printers - Fixing Blinking Lights
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpd09169&cc=us&lc=en&dlc=en&product=59305&dlc=en&lang=en
HP Deskjets - What are the front panel lights and buttons on the 800 series printers?
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpd09133&cc=us&lc=en&dlc=en&product=59305&dlc=en&lang=en
Check the End of warranty date on both the cartridges.
Deskjet 882c printer does not support reserve mode printing.
Means, even if only cartridge is defective or expired the printer will not print with other cartridge which is fine.
Both the cartridges should in inwarranty and fine.
Shake the cartridges well
With the color and black cartridges touch a clean, slightly damp cloth (squeeze out excess water),
to the printer nozzle area on the print cartridge, to see if you can make the ink flow freely.
Be careful not to touch the nozzle area (with holes on it) on the cartridges.
Wipe the copper-colored electrical contacts with a clean distilled water or clean tap water and then with a dry lint-free cotton cloth
Also using a new swab, clean the electrical contacts inside the printer, in the carriage.
Install both the cartirdges in the printer, disconnect the printer from the computer and try to print a self test and diagnostic page
Running a sample page
Turn the printer on.
Press and hold the RESUME button until the printer starts printing.
Release the RESUME button.
Running a diagnostic test
Press the RESUME button four times.
3answers
Print Cartrige Error
they probably are dried up if they were in storage
k24674
Grand Canyon Tech
Grand Canyon Tech
