Question about Hitachi 42HDS69 42 in. Plasma Television
42HDS69-INPUTS I HAVE A 42"HD PLASMA. I USED ONE DAY IT WORKED PERFECT THAN 3 DAYS LATER ITS A BLACK SCREEN AND STUCK ON INPUT #4 WHICH I DONT USE. THE SELECT BUTTON ON THE REMOTE AND TV DO NOT WORK. ANY IDEAS WHAT COULD BE WRONG??
  • ekiessel Dec 28, 2008
    Same problem foir me, any ideas?
  • 84 Answers
Couple of ideas ... on the TV look for the button named input you can change it to the one you cave connected to there .. I am looking up the remote press the TV button then the menu button to move through the on screen input control
Posted on Sep 19, 2008
When i power on tv it say analog rgb searching/monitor going dpms
A guess here---turn on and with TV/video or source or input change the input until (say you have cable hooked also) you see the regular picture again.
The input by accident may have been switched to the RGB(red, green, blue) which is a component or HD input.
Start there and let me know what happens.
Dec 05, 2012 | Hitachi 42HDS69 42 in. Plasma Television
Hitachi 42hd69 won't switch inputs
Hi Try pulling the plug on the TV for a half hour. This may reset it.
Hope that work for you.
Apr 26, 2012 | Hitachi 42HDS69 42 in. Plasma Television
Looking to use the PIP feature with my 42HDS69 TV. When I access the function, the second screen can only utilize the AIR input. No other inputs are available. I just want to change between the digital...
U have cable or satalite service?Yes,this functions,will work correctly.Tv have only free DTV broadcasting air signal only,will not able to watch two air broadcasting channels at the same times.
Mar 21, 2011 | Hitachi 42HDS69 42 in. Plasma Television
Black vertical stripe on screen, any input
good day sir/maam, the black vertical stripe on screen could either be onscreen data input/output,so check your manual, worst it could be failure of the vertical amplifier stage. It could also be interference. at this point its kinda hard to isolate the problem, only diagnostics tools found on service centers could find the fault. better check your local service shop if they could take a look at it.
Oct 13, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
All (4) video inputs are bad
possible change your AV cable...you can't use the same component cable for the normal AV input...component cable (RGB - RED,GREEN AND BLUE),normal AV cable is RED,WHITE,YELLOW.
GOOD LUCK.
Dec 09, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
42"HD PLASMA, No sound on Analog input
I think the problem is dry solder joints on the tv. What makes be believe this is you turning it on and off may have been moving the component/s into contact with the board or the act of you turning it off let everything cool down enough to return to their original positions. It now sounds like the contact has broken with the component and the circuit. If you can check for this yourself otherwise find a competant technician. Hope this helps.
Sep 23, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Black side bars on hd channels
You may have to refer to the instruction manual for details.
There should be in the menu set-up an option to set the aspect ratio for the different broadcast modes. Normaly, when viewing a 4:3 picture on an HD 16:9 set, the sides will be cut off, otherwise the picture will be stretched or compensated.
Jerry G.
Apr 11, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Vizio GV42L LCD TV screen black when turn TV on first time
If you are using a set top box this might be caused by turnig the box on at the same tie as you turn the tv on or slightly after you turn the tv on.  If you are using compnent or HDMI inputs the set needs to see the signal as it is turned on to know what formt the signal is in.
Oct 15, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Hitachi 42HDS69 42 in. Plasma Television Logo
306 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
