My Samsung YH-J70 Player as a message on screen whitch reads . Warning device can,t HDD Initialize Any ideas
  • 10 more comments
  • keith2000 Sep 19, 2008
    Samsung YH-J70 MP3 Player
    When switch on every time Message reads.
    Warning Device Can,t HDD Initialize .
    Only way to turn off is to press reset button
    It will not play anything
    It still reads Device can,t HDD initialize
  • keith2000 Sep 20, 2008
    I have tried formatting but no luck it does
    not show up on my computer
    Regards Keith
  • keith2000 Sep 21, 2008
    how much is the battery and where do i buy it from ?
    regards keith
    regards keith
    regards keith
    regards keith
    regards keith
    regards keith
    regards keith
    regards keith
    regards keith
    Sergeant:
  • 320 Answers
I really understand your problem. If this type of problem occurs then we could easily solve by formatting the device. But you are saying, its not happening. Please try again re-formatting the device by inserting into another usb port. or try formatting with other systems. Hopefully it should work. For batteries and other accessories Click on the below link or copy the URL and paste it in your web browser. Select the part number of your battery an order it.
http://www.samsungparts.com/search/search.asp
Thank you.......
Posted on Sep 21, 2008
  • 1,879 Answers
Either the HDD is malfunctioning or wrong FORMAT.
use the lowest FAT available
Posted on Sep 20, 2008
    Master:
    Sergeant:
  • 449 Answers
Hi!!!!!
did you drop you r mp3 player
so unscrew clean it well then used a tester check the wire if
is connected and then put it back on
if is not working!!
try to replaced the memory if it is available on the store!!
Posted on Sep 19, 2008
  • ronald suboc
    ronald suboc Sep 21, 2008
    hi!!!
    try to replaced the HDD or the battery
    try to find store of mp3 shops near you!!!
    not online it take you time to recieve
  • 2,071 Answers
Just click below for more information ;
http://www.anythingbutipod.com/forum/showthread.php?p=186206
http://hifiblog.com/past/2005/09/01/samsung-yh-j70-is-here/
Hope it may helps you;
Regards,
VOTIT
    Master:
  • 441 Answers
This might result to having a bad HDD/software/battery. Try replacing the battery on the device.
You can go to this link to help you with that
http://www.anythingbutipod.com/forum/showthread.php?p=165972
    Genius:
  • 1,689 Answers
Kieth please try what namizhka is advising you, about formatting the hard disk drive / flash drive on your player.
if it cannto be done through my computer, just right click on the my computer icon, go to "manage" then select "Disk Management" you should be able to see / format the player here because it will show up as a removable storage.
if you have registered your player in samsung, just go to "my samsung" download the firmware for your player then let it run, update and format your player to make it operational again.
if you have other questions just let us know....
    Sergeant:
  • 399 Answers
Also weak batteries can give this messages try changing the battery.but if the battery is absolutely new try the other options given below.
did you drop it? if dropped samsung yh-925gs and the message comesup. you had to carefully unscrew it, and reattach the hardrive. it is easy, and you will see what to do. just take it appart, notice where the hardrive is, see the unconnected connection, and click it back together. it is surprisingly easy.
or
had to replace the hard drive.
The YH-J70 uses same drive as generation 3&4 ipods - that is; Toshiba MK2004GAL - a 1.8 inch drive 5mm thick. They can be found on ebay quite easily.
For more info on how to do it see here:
http://anythingbutipod.com/forum/showthread.php?p=214227#post214227
Hope this isn't too late to be of help, good luck!
for further queries feel free.
thanks.
  • masterexpert Sep 19, 2008
    any new updates.
    reply.
    Sergeant:
  • 264 Answers
Turn off the Phone. remove the battery. Remove any memory card plugged in.
Press and hold the power button on the Phone for 20 seconds,(Making sure that the charger is unpluged, battery is removed and the memory card is out.)
You wont see anything happening at this moment.
Now try to plug in the battery and turn it on again and check. First use it without the memory card (if any) for some time.
If this does not work. It may be the issue with the internal memory chip.
  • Sameer Kashyap Sep 19, 2008
    Connect the player to the computer, if your computer is unable toread the device than it is the issue with the player and as is said before it is with the internal memory chip. It needs to be check and replaced than
  • Sameer Kashyap Sep 21, 2008
    As i mentioned before that if the computer cant read it the internal memory chip of the player is bad and needs replacement.
    Master:
  • 763 Answers
Try to reset the device and remove the battery for a couple of minutes then try again. if still persist then format your device to become fresh after that add the music that you like. hope that helps!
CHARCOIS
    Genius:
  • 1,550 Answers
When do you receive this message .
At start up or after some time ?
Are you receiving the message regularly ?
post back
  • SAM ANDERSON Sep 19, 2008
    Did you drop your mp3 player ?
    If yes
    Then you have to carefully unscrew it and reattach the hard drive.
    There will be some unconnected connection and click it back together
    This will solve your problem .
    More clearly i am providing you the steps
    • Make sure player is off.
    • Take off back cover. 4 tiny screws.
    • Take out the HDD, the big rectangle thing. The back of it should be silver.
    • When you take it out, the front should have a "gold sheet" attached to it.
    • At the lower corner the "gold sheet" is a cut out part. This "cut out" part is where the HDD connects to the "mother board".
    • Bend that piece ever so slightly where u can place your finger between it and the HDD.
    • You will then plug in that "male" part to the "female" part on the mother board.
    • when you feel it snug or snap, your MP3 should work now.
    • turn on the mp3 player to make sure it loads.
    • if it does, then you have fixed your "problem"
    • reassemble player accordingly.
    Scholar:
  • 148 Answers
There was a problem on the mp3 hdd.. have you try checking and testing it by plugging into the computer..?
  • 1 more comment
  • Zander Rovic Ocampo
    Zander Rovic Ocampo Sep 19, 2008
    keep us updated, and I'll get back on to you later.
    in the moment of no response...
    1st try to reset your MP3 player.. and if this solution did not solve the issue.. you have to reformat the MP3 to revived the HDD...
    try to plugged it into your computer (PC), reformat the MP3 hDD,.. you can see the mp3 icon as a removable drive on your MY Computer
Samsung YH-J70
Keith, I have the same problem. Do you already have a solution?
regards Jeroen
Sep 29, 2008 | Samsung Yepp YH-J70 Digital Media Player
Samsung YH-J70
I had the same problem - the hard drive had failed, which is a common fault. I bought a new one on eBay - a Toshiba MK3006GAL 30GB - which worked fine.
BUT... the drive came completely unformatted and I had to format it on a laptop first as I could not get it to format in the YH-J70. If the drive is FAT32 format, however, you should be OK to just put it in the YH-J70 and format it with Samsung Media Studio.
Sep 19, 2008 | Samsung YH-925 MP3 Player
Samsung digittal audio player yh-j70
All the drivers and software are still available for download on Samsung's website.
http://www.samsung.com/us/support/
Sep 08, 2008 | Samsung Yepp YH-J70 Digital Media Player
Missing file after avg "healing"
Yes easy fixed. Open from my computer then go into folders options and click on show hidden folders option, your system folder should show up then open that folder and youll see the vbs file. Delete it, and all is good !
Jan 08, 2008 | Samsung Yepp YH-J70 Digital Media Player
How do you update firmware on YEPP YH-J70?
unzip file, put it directly on disc don't use any program, disconnect, turn off, put on recharge and power on the player.
Dec 09, 2007 | Samsung Yepp YH-J70 Digital Media Player
Help
yes. did you drop it? i dropped my old samsung yh-925gs and the same message came up. i had to carefully unscrew it, and reattach the hardrive. it is easy, and you will see what to do. just take it appart, notice where the hardrive is, see the unconnected connection, and click it back together. it is surprisingly easy.
Oct 11, 2007 | Samsung Yepp YH-J70 Digital Media Player
Samsung YH 925
Hi, run the recovery utility that you install from the CD. Reinstall firmware. C
Aug 07, 2007 | Samsung YH-925GS MP3 Player
Error message
Did you try pushing the reset button and/or reinstalling the software? sometimes that helps. Also, I have a question for you: I am thinking of replacing the battery on my yh-j70, as it is getting weak, was it easy for you to open the player and can you then simply pull out the battery or do you have to solder? Would you happen to know where batteries can be bought for this unit? Thank you
Oct 30, 2006 | Samsung Yepp YH-J70 Digital Media Player
110 people viewed this question
 Grubhead
Grubhead
