Hdd not showing in my computer
Earlier i had 80 gb sata hdd in my computer , now i have added one more 250 gb sata hdd in my computer.
but it is not showing in my computer like drive c: , drive D: , but it showing working properly in device manager
what should i do
my computer p4, 1gb ram
    Scholar:
  • 68 Answers
First of all i cannot understand your problem.....you are telling you connected both 80 gb sata hd and 250 gb hd on the motherboard..........but not showing the drives like drive c:,drive d:,etc......first of all when you intall any os....... example when you install windows xp.....the drive letters are automatically allocated....we cannot change it.....if you want to change the drive letters you will need some special softwares.......that you can search it in the net and then you can cahnge it.......actually this is not a big problem....all other functions will be working properly....dont worry.......i am a software engineer and i have experience in it....thats why suggesting you this idea.......
Posted on Sep 19, 2008
  • 93 Answers
It is not showing in my computer because its not yet partitioned and formatted.... so what would i suggest you to do is Rightclick on my computer - choose Manage - in manage you would find something called disk management, if you click on it... you would get all the drives list including the hard drive you added... so right click on the hard drive you added and click on format to activate your drive...
    Sergeant:
    Champion:
  • 200 Answers
Hi
When ever we connect the new HDD to the system we want to make a Format and partition then only it will work.
Because its new one and then its in raw state, we want to make a Format and partition then only we can use it..
Using the OS u can do the format and partition..
I thing u known how..
All the best..
Thank you
Dear i am using ms-7142 v-1 motherboard. now i,m using ide 80 gb hdd.now i want to connect 160 gb sata hdd.its not showing bios also.hdd is working fine.i reinstalled os.and installed sata raid driver
first thing I would try is seeing if the sata drive is recognised on another motherboard if at all possible ,in order to eliminate the motherboard as the issue.If it is recognised on a different motherboard it is more than likeley a bad cable or a bad board .
Sep 23, 2014 | Computers & Internet
Can't setup OS in SATA HDD in Intel d945gccr
Hi.
XP will not install until you go into the BIOS and find the menu page (probably by moving across the top level of tabs) where the SATA hard drives are configured. On that page you will see the ports and at least one, maybe all, will be Enabled. Close to that will be the port mode, usually setable individually for each port. Choices may include IDE (or PATA) Emulation, SATA, AHCI. Set your port to IDE emulation. Now look at the bottom for the key to Save and Exit - often the F10 key, press that key and select OK, the computer will restart and you should now be able to install Windows XP without any problems.
To get into the BIOS you have to press the Del or Esc key when you first turn the computer on.
Regards.
Feb 04, 2013 | Intel D945GCCR Motherboard
Sata HDD very slow
Dear friend you need a sata board to get maximum speed of sata driver connect it directly to motherboard sata jack converter does not give full sata speed
Jul 22, 2009 | Hitachi Deskstar T7K250 250 GB Hard Drive
Upgrading my computer
Dear Fried its possible.. Go the Boot Menu at your BIOS ( For go the BIOS Press DEL at startup your system) there you may se Hard Disk Priority Option. There you can change Hard disk Priority... you may need setup your sata as first one..
Thanks...
Mar 26, 2009 | ASUS K8V SE DELUXE,...
Troubling in sata connection
  • I suppose there is a jumper(beside the power pin) on your new HDD,
  • if its true the your HDD supports 3GB/s mode but your motherboard does not .
  • So place the jumper on the HDD on 1.5GB/s combination.
then
  • Disconnect the 80 GB,
  • Connect the new HDD,
  • Boot from any bootable xp or vista or any disk tool like erd commander and try to format the new HDD.
  • Then connect the new HDD and boot from it.
Tell me what happened.
Jan 31, 2009 | Seagate 20PK 320GB SATA 3GB/S 3.5 7200RPM...
PATA SATA PROBLEM
This motherboard does support SATA. Check out the specs on the ASUS website:)
http://www.asus.com/products.aspx?l1=3&l2=14&l3=225&model=754&modelmenu=1
Dec 30, 2008 | ASUS K8V-MX Motherboard
Sata drive not detected
just no other solution except upgrading BIOS properly
Sep 24, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Vista installation
try updating the os using windows update
Sep 20, 2008 | Computers & Internet
Samsung 80 gb Hard Disk Un allocated
All ways best to used new cables (sata/Ide) I like to set jumpers on the HD's never cable select. Also try installing one harddrive at a time. Second make sure in bios is set to boot from main HD.
May 12, 2008 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Computers & Internet Logo
Brian Sullivan
Brian Sullivan
David Payne
David Payne
