Question about Canon imageRUNNER 3300 All-In-One Laser Printer
Ir 3300 when ever my client gives print through PDF , it shows as it is going to print, but after some time it disappears. But other who are connected able to print. when we reset the printer from ir330 it work for some time again the problem repeated. User is using adobe reader 8 version. Please advice
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 89 Answers
Set print settings to print as image. Also make sure to spool printing.
Posted on Jul 17, 2009
I have ir 3300 i want to connect to pc but idont no ip adders pls tell me ip adders
you go add setting,go printer setting give the foolwing ip address
192.168.1.1
Feb 07, 2015 | Canon IR 3300 Digital Copier
How to solve error code of E000002-0000
The problem is in temperature of a fixing film.Try to clean the heater,put on the grease...If ther's still a problem,replace the heater
Sep 23, 2014 | Canon Ir 3300 Black & White Copier
What is the reason for blank copy in ir3300 copier
Check the fixin unit,lamps,thermistor,thermal fuse
Aug 02, 2014 | Canon IR 3300 Digital Copier
Problem with printing on canon ir 2200
go to run prompt on client end and typ \\ip add of main pc where ur printer actually connected nd then u will get shared printer on display, u will get shared icon of ur network printer right click there nd connect it .... if it doesnt show any problem to connect it will work nicely ...........
Apr 16, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Canon ir 3300 error code display e000019-0000
It means that your waste toner box is full.
You can do the next:
On left side of copier, on lower left side you have small cover with screw.With screw driver unscrew it and remove cover. Remowe the waste toner box/container, and clean it, after you removed toner wash it with water and clean the inside and outside of box neck with alcohol to remove the antistatics. Place it back and restart the copier.
Mar 31, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Error code e000007-0000 in caonon ir 3300
my canon ir 3300 shows error e-000007-0000 how can i solve this problem
Jan 16, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
How can i established network connection with ir2800 and desktop
First of all you must have a local network hub.Connect your network hub with your computer and the Ir 2800,your IR have to be equip with a network card.(If only have to connect one computer and your computer is not connected to a LAN network,you can use a cross-over cable connected directly from the computer to the IR machine.Give your computer a ip address by right clicing on the local LAN select properties and select internet protocol ver 4,and select a ip address.If your computer is already connected to a network,dont change the ip address go to command prompt tipe in ipconfig/all.This dos command will show you what the ip address is of your computer.
Example the ip address is 192.168.1.10,Select a ip address for your IR by changing the last class to any number.But you must make sure this ip is not in use,lets say you select 25.In the command prompt tipe :ping 192.168.1.25.If you get a reply,dont use the number.Select a number untill you dont get a reply and a time out response.
Now use this IP address and program it on the IR2800 under additional funcktion system setings,network settings,TCP IP settings.
Switch the machine off for a minute and switch it back on.
Now load the printer drivers of the IR and add the port you selected.
Restart the computer,
And print to your computer.
If you have any trouble along the way,just send me a note
Dec 10, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Error Code description
The Canon is coming on with a code E602-0003 can somebody please help it is only 9 months old and the company we bought it from is out of bussiness. Please email me @ reception@biscayneroofing.com
Thanks
Madlyn
Feb 25, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Error code on screen is E602-0003
i have problem in my cannon ir 3320 it shows
E602-001 & E0315-000d
pl solve it
Aug 22, 2007 | Canon (6981A002AA) for imagerunner 2200,...
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
110 people viewed this question
old marine
old marine
