Question about IBM ThinkPad G40 2388 Notebook
Thinkpad will not open in regular mode.
My G40 only opens in Safe Mode ?
Someone told me it could be a hard drive problem.
Is there a quick fix for this, or do I need to go shopping for a new laptop ?
  • IBM Master
  • 5,568 Answers
Not likely related to the hard drive, otherwise the Safe Mode also could not start since it does require some Windows support to start and that comes fro the drive.
You should be able to run the disk checking program:
Open 'My Computer' then right click on the C: drive, then Properties, then Tools, then 'Check Now'
More likely is that some of the support files for a normal start have been corrupted since Winndows has a tendency to commit Hari-Kari.
Check to see if you have had 'Restore' turned on and try to restore to a date before the problem appeared.
Posted on Sep 19, 2008
  • 22 Answers
U should buy a new hard disk
IBM Thinkpad R60 - how to run in safe mode
When it is starting up at the Splash Screen(windows logo screen) hold the power button in to shut it off this should bring up the menu to open in safe mode. Might take a couple trys.
Jun 21, 2013 | IBM ThinkPad Computers & Internet
IBM Thinkpad G40 not recognizing replacement hard drive
my recommendation is to format the drive and see if that helps. do it via usb.
May 05, 2012 | IBM ThinkPad G40 2389 (2389HEU) PC...
Blue screen says error loading,dont know how to recover with safe mode or how to activate safe mode.it is a think pad t20
Hi,well these should work for you,to get to safe mode,power up the system as the IBM thinkpad logo is about to be displayed press the F8 key just before the Windows loading screen comes up so as to get to safe mode.if it does not work try reloading the operating system using operating system disc.
Dec 20, 2010 | IBM ThinkPad T20 2647 Notebook
Problem opening Windows
Usually a sign of Hard drive problems, boot up in safe mode if you can.
Right click on C: drive, properties/tools/error check and let it do a full scan with automatically fix errors chosen.
You may want to back up as much as you can if you manage to get into safe mode
Jul 16, 2010 | Acer Aspire One PC Notebook
IBM G40 won't reboot
Unfortunately only few people know your problems solution but I'm happy that i can help you.
Its simply a problem of setting HDD ( Hard Disk Drive ) type which can be changed using BIOS setup. I hope your laptop must have SATA but if its not working on current settings then please change it to another options available.
Surely, your system will get booted after that and furthermore you can re-install your windows again...
Rate this solution if it was helpful to you.
With Regards,
Shyny
May 29, 2009 | IBM ThinkPad G40 2388 Notebook
I had to restart my IBM Laptop by shutting down the power manually.now it will not re-start windows even in Safe mode.im getting a ECC Error sectors 53072284 - 53072411 Hard Disk Drive any help would be...
Sounds like a corrupted or damaged hard drive, if u can get to dos instead of safe mode try running one of these to commands to do a hard drive sector check and repair:
chkntfs - dos hard drive check
scandisk - windows hard drive check
Even if these fix the hard drive problem depending on what sector was damaged u may still need to reinstall windows though
Mar 29, 2009 | IBM ThinkPad R40 2722 Notebook
IBM T22 Thinkpad won't boot up - not even in safe mode
either you have a virus or a corrupted dll file.
eitherway, beside create a bootable CD or Floppy disk, and try to fix from there, thats' time a money.
the next best thing, is to reinsall the operating system.
the other option is get a new hard drive and install the operating system on that so you can preserve the data you have on the old one.
Mar 04, 2009 | IBM ThinkPad T22 2647 Notebook
I forgot my administrator password
safe mode will open windows with minimal amount of drivers, but will still require a password. Safe mode with command prompt will open in a simulated dos mode, and you can type "explorer" at the command prompt to open the gui and get to the start menu. buty this may not help.
i have sucessfully removed administrator password from windows by taking the hard drive out and installing it in another system as a secondary hard drive. i then manually deleted the "sam" file from windows/system32.
you can also reset the password by reinstalling windows or performing a second, parallel, installaation of windows (identical OS) on the same drive, and then deleting the second installation.
May 17, 2008 | Dell Dimension 2400 PC Desktop
Startup problem
I would recommend you to boot your system and safe mode and do a system restore...To open your computer and safe mode hit the F8 button on your keyboad when the computer is booting up..click safe mode..and then once you get to safe mode its going to give you an option to restore your computer to another day..after the restore is finish, you should be able to use the computer without any problems...
Jan 31, 2008 | IBM ThinkPad G40 Notebook
IBM ThinkPad G40 2388 Notebook Logo
47 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
