Question about Creative Labs EMU 0202 Sound Card
Flash Rom for emu 6400 ultra
Hello, I've got an Emu 6400 ultra that has a problem with its operating system.
I upgraded the Flash rom O.S with the upgrade from EMU from 4.6 to 4.7 and its caught in some kind of loop.I've read that the O.s was bugged after I did the install. I've tried just about every forum and my last ditch hope is to find someone with a ROM burner in town to clear the ROM and re-install the O.S. Anyone in Toronto with this level of experience or equipment to deal with an antiquated piece of garbage from 1999? I've been told to forget about it but it feels like such a waste.
Paeroa
  • 457 Answers
SOURCE: emu 0404 sound card - no output
Try company that made the sound card http://www.zzounds.com/item--EMU8803 look there they may have a solution apparently there is a partition going around asking them (the Company) to revert back to the old standard of the card?
Posted on Sep 02, 2007
SOURCE: emu 1616 pci for mac!
No they don't support the 1616 or 1616m on mac yet. As far as I know only some USB interfaces are supported.
Posted on Aug 07, 2008
  • 146 Answers
SOURCE: HI, I have an emu
You have to select the EMU as the default playback device in Windows and or select it as the playback device in the software you are using for recording or playback.
Go to Control Panel and Sound and Audio Devices icon, and select the Audio tab. There is a drop down box that lists all playback devices. You have to select the EMU in there.
That should get you working.
Posted on Jan 01, 2009
SOURCE: EMU 1616m (cardbus) not offerring its input sources to Reaper
While you probably solved this already here goes. I'm not familiar with reaper but most audio recording software can select between using windows wdm & ASIO. If you aren't set to ASIO you won't be able to see the Hi-Z (Dock A/Dock B) inputs. It looks like Reaper supports ASIO so that should be fine. If though you are using a program that doesn't support ASIO you need to use the EMU patchmix and 'patch' the input through to a 'wave' channel.
Posted on Jan 14, 2009
tow2000_au
  • 69 Answers
SOURCE: i want free download of creative emu 10k1x dbq
driverguide.com
membership is free
Posted on Jul 17, 2010
1005ha bios update usb
Upgrading BIOS is dangerous and can cause fatal damage to your PC. If you are aware of that and decide to take this risk, then continute. 1. Visit http://support.asus.com/download/download.aspx?SLanguage=en-us, search 1001HA and choose DOS as operating system. Download latest bios rom file.
2. Save and extract the downloaded file. You will get a rom file named like "1301.rom" 3. Format a usb pen drive to FAT-16 partition. In my case I used a 32 MB SD card which came with my old Kodak camera, and I used a SD card reader that PC can see it as a usb disk. Copy 1301.rom to its root folder and rename it to 1005HA.ROM. The reason for renaming it to 1005HA.ROM is that EZ Flash on this 1001HA netbook looks up rom with this name. If EZ flash failed saying trying to find a rom file with another name, just shutdown the netbook and rename your rom file to the required name and try again. 4. Plug in the usb pen drive and reboot the netbook. Make sure that during the ASUS splash screen, press ALT+F2. Then EZ Flash will run automatically and try to locate the usb drive and read from file 1005HA.ROM (in my case). 5. It takes around one minute for me to upgrade everything. DO NOT TURN OFF OR EVEN TOUCH YOUR NETBOOK DURING UPGRADE. Read the messages on the screen and when it says you can press the shutdown button, you can turn off your system. 6. Turn on your netbook again and enter BIOS to check if the BIOS version is up to date.
http://www.youtube.com/watch?v=61awfpVe49k&feature=player_detailpage
Jun 11, 2012 | ASUS Eee PC 1005HA Atom N270 TFT Notebook
Tip
Check your emu
right guys before you panic and start to look for the new keys or codes please check that the emu has not been turned off on your box ok so you have a box t press menu then 1570 this opens a new window or a hidden menu in this you will see nagravision and key emu highlighted scroll down to check that the emu has not been turned off accidently if so scroll over press>to turn on then exit exit if it is a digivox repeat the same procedure only key in 1004 and follow the same steps and again the same with the eurovox only again the difference is 1969 and again the same steps just check before you panic it could be an accident and the emu is turned off
on May 01, 2010 | Audio Players & Recorders
I NEED EMU 1010 SOUND CARD DRIVERS
Please be informed that any hardware device needs a driver software to run within a PC, and the driver software depends on the Hardware Make/Model and the Operating System software you are using in your PC to operate it.You will get the Driver software of any hardware within the CD provided with the hardware part at the time of its purchase. The hardware may be an entire PC,Laptop,VGA card, sound card, LAN card etc.
If you do not have the CD or misplaced it somewhere then you need to download the driver software to get going. Thus you need to know all the above information to get the exact software your PC needs. As you have not mentioned the Hardware Make/model and Operating System you are using, i am unable to give you the direct download link.
However you can download the same by visiting the 'software downloads' section of the website of the hardware brand you have purchased. You just need to Google the name of the brand and visit their website and search for the download section.
If you feel that, my answers have helped you getting solution to your problems then please give a vote.
Thanks.
Dec 15, 2011 | Creative Technology EMU 1010 PCI Card...
StarView SV211K 2-port KVM Switch: alot of my channels say scrambled i ve put code in...
you have to turn the emu on when you put the codes in it turns the emu off so you have to turn it back on
May 18, 2010 | StarTech.com StarView SV211K 2-port KVM...
I'm looking for a calculiator that I can down load an algebra solving program too from my desk top. do you know of any?
You have a few choices of so called emulators.
Emu48, an emulator for the HP48G/GX calculators is available at hpcalc.org. But if you do not know RPN Reverse Polish Notation you will suffer a bit.
Virtual TI version2.5 emulates the TI83, but you will need the ROM of a real TI83 calculator.You will find it at TICalc.org under emulators. There are ROMs available on the Internet but you will have to look for them.You can also find someone who owns a TI83Plus and ask to download the rom from thr calculator. Procedure is described on Ticalc.org
TIEmu emulates the TI89, TI92/92PLUS, and the TI Voyahe 200 PLT. It is available for Windows and Linux. For those calculators you can go to education.ti.com and download the OS and drag and drop them on the TI Emu main window.
If you want to do symbolic algebra use the TiEmu.
Hope it helps
Oct 02, 2009 | SoftMath Algebrator - Algebra Homework...
EMU 1212m clicks in audio
Note that there are new drivers that can be found on http://www.emu.com and that some E-MU products need to be grounded, like my E-MU 1616m, check also the ASIO drivers settings,
setting in them the milliseconds to low wil also
cause audio stutter.
Succes.
Sep 05, 2009 | E-Mu 1212M Sound Card
GBA Hardware Problem
I had a dbz game like that. I though have a working buus fury rom. Just tell me if you want it.
Mar 12, 2009 | Nintendo Game Boy Advance SP GBA Black...
Emu
hi press menu then key in 1570 another menu will come up and that is where the emu is good luck
Dec 19, 2008 | StarTech.com StarView SV211K 2-port KVM...
Want to have english version of my pda phone
You will need to flash the new ROM on your device to change the complete language of the Operating System, get the correct ROM from the manufacturer and flash it using the instructions.
Aug 10, 2008 | HTC S200 Smartphone
Open Questions:
Creative Labs EMU 0202 Sound Card Logo
211 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
