Question about Kogi L7CH Monitor
Center screen I have an L7CH LCD, I can't get the screen to center. It stays about 2 inches from the left & 1 inch from the top on the 800x600 setting & even further on higher settings. tomzurawski@ameritech.net
  • Anonymous Oct 19, 2008
    The solution worked fine for me with a Kogi L7EH with the same problem. Thanks.
  • Shawnascy Jan 27, 2009
    My PC screen broke 2 months after purchase and a new one is $400 plus labor. I have been trying to hook-up my KOGI - LO7CH-TA-AV53N-2000-KGX as my primary monitor. I sometimes get it only and sometimes I get my cracked PC monitor. I can't find a download driver for the monitor and even when I do get the desktop monitor the margins are all off and I can't fix them either.
    So I thought I would write someone with the same problem, any suggestions? Thank you, Shawnascy
I figured out that the monitor has to be reset. I was able to figure it out. Turn off the monitor, hold down the + - buttons together on the monitor & turn the monitor on while holding the buttons down, you will see a message on the screen that the monitor is resetting, you can let go of the buttons & the monitor will be reset to factory settings.
Tom Z
Posted on Sep 22, 2008
We were wondering the torque on the head bolts on a Kohler motor for a lawn mower.
Hi and welcome to FixYa. I am Kelly. These torques are from the Kohler Service manual for the
CV11-16,
CV460-465,
CV490-495
engine.
There are 5 bolts.... as you look at the bolts there should be 3 on the left side
Bolt 1 is the center (offset bolt)
Bolt 2 is upper right
Bolt 3 bottom left
Bolt 4 upper left
Bolt 5 lower right.
Torque them in the sequence above... to 15 Ft lbs. or 180 inch lbs
reset your torque wrench and then torque them to 30 Ft lbs or 360 inch lbs.
Rocker arms center nuts (called mounting screws) are first torqued to 55 inch lbs then to 100 inch lbs.
Then to set the valve lash you back off the set screw lock nut torque and set the valve lash to .003 - .005 final set screw lock nut torque is 65 inch lbs. Engine must be at TDC i.e piston all the way to the top to make the correct adjustments.
Thanks for using FixYa.
Kelly
Jul 17, 2010 | John Deere Garden
Picture not centered on my philips 47'' lcd tv
NOTE:(Edited and copied from another thread on Fixya.com, c7carl)
Picture is not centered on monitor leaving a 2 1/2 inch; black border on Philips LCD
By dmorrow54 on Nov 13, 2007
Again, nothing in manual for Philips LCD will correct the fact that the picture in HD-D mode will not center. The picture runs off the monitor on the left (facing the monitor) with a 2 1/2" black border on the right (facing the monitor). Using the format button on the remote of directional arrows will not correct the issue. The wide-screen/ full-screen function with format does nothing. Moving into TV mode, the format function works to display screen in several ways 4:3, 19:2, super-zoom, wide-screen, full-screen. Help, please. posted 3 years ago
Guest
  • Rank: Guide
  • Rating: 0%, 0 Votes
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
Add a comment
    • c7carl
    • 5 minutes ago
    WOW! It works!! The picture on my Magnavox (aka Philips) 37MF321D had shifted to the right. I figured I had a big repair bill coming up soon. But hey! Just used the TV remote as described by "Guest', and re-centered the picture to the left. Wallah! Thanks ""Guest" whomever you are! Reply
    Posting advertisements, profanity, or personal attacks is prohibited. Click here to review our Terms of Use.
    Comment:
Feb 05, 2009 | Philips 47PFL5603D 47 in. LCD HDTV
Vertical lines on my 40 inch lcd mitsubishi hdtv 1080
Similar problem with an eleven and a half month old LT-40148. Approx. 1 inch vertical banding line on left side of screen on all inputs. After about two weeks, same problem on the right side of the screen.
Fortunately this occurred two weeks prior to the one year warranty expiring.
Called Mits customer service and they referred me to an authorized service center who I happened to have dealt with before.
They picked up the set. The front panel (LCD screen ) had to be replaced. Set was gone for two weeks as parts were not in stock. There was no charge. I hope this screen last more than a year.
Jan 16, 2009 | Mitsubishi LT-40133 40 in. LCD HDTV
Black Lines
My Hitachi TV Flat screen 42 EDT 4 1A has a one inch black line from the top to the bottom of the
screen on the left side. What or how do I fix it. I did blow it out with a air compressor as suggested by a local repairman.
Nov 09, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Display is off-center
Try the Auto adjust button on the monitor buttons first.
If the entire picture of the computer is showing you can try to shift and stretch the picture through the menu button.
Sep 04, 2008 | E-Machines eMachines Monitor E15T4
Desktop view alignment
right click on your desktop and change the default resolution try 800x600, 1024x768 see if that helps. if it does not download a new videocard driver specific to your computer.
Aug 04, 2008 | Toshiba Satellite 15" Flat Panel LCD...
LCD Television Proview RX326
No better description then a picture! Can You post a few?
Jul 07, 2017 | LG 42LP1D 42 in. LCD HDTV
Kogi L7CH Monitor Logo
139 people viewed this question
Top Kogi Computers & Internet Experts
Laxman Bisht
Laxman Bisht
Computer Links
William Miller
William Miller
Are you a Kogi Computer and Internet Expert? Answer questions, earn points and help others
