Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool Ultimate Care II - overfilling
Do these washing machines have a safety mechanism that keeps them from overfilling? Our machine overflowed recently. We think we didn't set the load size dial all the way on large till it clicked. But shouldn't the machine have another mechanisms that keeps it from overfilling?
  • bacuna214 Sep 19, 2008
    Thanks! This is very helpful and we'll check on it and see if we can fix it ourselves.
  • 5,911 Answers
Yes, its called a Pressure Switch and its located behind the load level selector knob in the operator console. A common problem with these model washer (and a very minor one) is that the air hose comes loose from the pressure switch, which causes the washer to overflow. The following link explains:
http://www.fixya.com/support/r762094-washer_overflows
Read through the link I provided and inspect the pressure switch. In many cases this is the a simple problem that appears to be something major. Best of all, reattaching the air hose won't cost you anything. If you perform these steps and still have a problem, more than likely you have a failed pressure switch that requires replacement. I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Sep 19, 2008
How to fix a broken belt of motor of whirpool wash ultimate care 2
  • Replacing the Belt in a Whirlpool Ultimate Care II ' Home ... homeguides.sfgate.com > ... > Mortgage-Backed Securities Replacing the Belt in a Whirlpool Ultimate Care II by Rogue Parrish. Email; ... The Ultimate Care II washer, ... it may have a broken belt.
  • Whirlpool Washer: Ulitimate Care II - YouTube www.youtube.com/watch?v=bVmjmSzMXHE
    • BY CHERRY HILL
    • 3 MIN
    • 36K VIEWS
    2012-05-30 · Video embedded · Whirlpool Ultimate Care II: ... This is fully funcational washer. Direct Motor Drive works perfectly through each ... Whirlpool Washer: Ulitimate Care II
  • How to replace a broken dryer belt. Whirlpool Ultimate ... www.youtube.com/watch?v=PU8QZeDRl_0
    • BY BAILSOFSTEEL
    • 5 MIN
    • 3.5K VIEWS
    2015-04-04 · Video embedded · This video shows me replacing a belt in a Whirlpool Ultimate Care II ... a broken dryer belt. ... Whirlpool ultimate care II clothes washing
  • http://www.bing.com/videos/search?q=broken+belt+of+motor+of+whirpool+wash+ultimate+care+2&FORM=HDRSC3
    Jul 15, 2016 | Washing Machines
    Standard washing machine hoses dont seem to fit my Whirlpool Ultimate Care II washer? Do I need an adaptor of some sort....
    The Whirlpool Ultimate Care II is an American top loading washing machine and requires different hoses available from Whirlpool.
    May 16, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirlpool ultimate care II stops after filling
    Hi, could be faulty timer, faulty water level switch, faulty start capacitor for motor, or faulty motor. always put clothes in machine before starting. you can empty machine by lowering drain hose to flow level.
    Aug 02, 2009 | Whirlpool Ultimate Care II GSW9650LW Top...
    Water keeps filling the washer
    If the washer keeps filling and overfilling then unplug the machine and see if the water still continues to come in. If this is the case, you have a bad water valve. If the washer just keeps filling and never gets to the top then your drain hose is shoved too far down into your house standpipe and must be pulled up and an air gap established.PART NUMBER 285805 @ 30.00 FOR WATER VALVE
    Apr 08, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
    Fills up with water and wont stop
    Bad Preasure valve comes to mind first and formost it acts like a level sensor balanceing the size indicated for fill.
    Feb 10, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
    Whirlpool Ultimate Care II keeps taking water.
    ck your drain nose/drainline, chances are you have along hose, perhaps even draining along the floor behind hte unit, into a "closed" drain system. in which cawee the wwater is syphoning out during the rinse cycle, youlll needt o raise the drain hose to above 48" and have it drain into a stand pipe to prevent siphoning effect
    Nov 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirlpool Ultimate Care II spins only once in a while :-)
    hi there,
    sounds like the timer switch. the switch is mechanical, so it's quite easily replacable.
    also, the overfilling is a result of the pressure switch no engaging. this switch senses the water level and once it's up to capacity, it will shut off the water supply into the tub. check the switch and switch wire to make sure it's working correct. this switch is also mechanical and easy to fix.
    let me know if i can be of more help.
    thanks
    Sep 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Washer won't start spin cycle
    sounds like a lid assy issue, can you hear a "clicking" just before the lid is closed, try opening nad closing a few times listening for a distinct "click" if not the machine doesnt think the door is closed and for safety reasons wont spin and drain.
    Mar 16, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Ultimate II is refusing to go into agtation/wash cycle
    It sounds like a bad timer unit, and possibly a lid switch.
    As far as the water overfilling, that may be an unrelated problem, such as the water level switch... but most likely the timer.
    I have the same model, and it wouldn't drain.. and it would try to spin when full of water... an interesting sight to see!
    Jan 07, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
    Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
    136 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
