Question about Compaq Computers & Internet
I am thinking of adding memory to my Compaq Presario SR111ONX. I was looking for a schematic of the motherboard or a diagram showing the memory slots and how to add it.
  • kgough Sep 19, 2008
    yes, by the description I found the part I was looking for.
  • 2,071 Answers
Just click below;
Compaq Presario Manual Get Manuals for your Laptop
It's Free and It's Easy.
www.FixYa.com
Posted on Sep 19, 2008
    Genius:
  • 1,550 Answers
Page 43 of this manual seems to have the best documentation on memory for this machine. I saw a 2GB max in another document and this shows the biggest module as 1GB.
click this link for manual
It contains schematic for inserting memory .
Thanks for using Fixya
SAM ANDERSON
    Master:
  • 763 Answers
By adding a memory card it should be the same as the memory card as before to add the memory what is inserted on your motherboard. if your going to add a high memory card then you dont need the old memory card after all. because it will have a conflict with each other. try to look on your motherboard's manual for compatibility. hope that helps!
CHARCOIS
  • 1 more comment
  • Charris Suaybaguio
    Charris Suaybaguio Sep 19, 2008
    by the way memory card or RAM has a version like sdr, ddr, ddr2 and ddr3 and look what's yours.
    heres a diagram on how to insert it.
    heres the link about RAM info and installation.
    http://www.ddrmemoryupgrades.com/what_is...
    CHARCOIS
    Brigadier General:
  • 5,158 Answers
Two long slots with tabs on each end... the hold the memory sticks vertical to the board.
Use your finger to gently move the tab away from the memory stick on both sides... after each tab has been moved away pull up firmly on the memory stick...note the position of the slot(s) on the side of the stick that goes into the slot. insert the replacement memory stick in the slot lining it up carefully and push down ... the tabs should go back into place on their own if the memory is seated properly.
Robert
Need a manual for Compaq Presario SR1130NX manual
1) Compaq Presario SR1130NX > HP Support > Main page,
http://h10025.www1.hp.com/ewfrf/wc/product?product=425917&lc=en&cc=us&dlc=en&submit.y=8&submit.x=5&lang=en&cc=us
In the list go to the right, and click on > Manuals
On the Manuals page;
1) Quick Setup Poster 2 is a diagram of how to connect the computer up.
2) Getting Started Guide is essentially a User Manual
3) Compaq Presario Desktop Products - Upgrading and Servicing Guide;
Describes how to;
A) Open the computer case
B) Replace a Harddrive, or Optical Drive
C) Removing and replacing Ram Memory
D) Adding Add-In Cards in an expansion slot
E) Replacing the CMOS Battery. (CR2032)
4) Part Replacement Guide;
Describes how to;
A) Replace an Optical Drive
C) Replace an Expansion Card (Add-In Card)
D) Replace a Diskette Drive (Floppy Disk Drive)
E) Replace the Power Supply
F) Replace the RAID Controller Card
G) Replace the 6-in-1 Memory Card Reader
Back in the Main menu clicking on Product information > Product specifications > Product Specifications, details out the Compaq Presario SR1130NX specifications.
Clicking on Product information > Product specifications > Motherboard Specifications, A7V8X-LA (Kelut)
details out the motherboard specifications, and at the bottom shows a motherboard illustration and photo.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00069442&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&product=425917&lang=en
The Processor socket is a Socket A. Also known as a Socket 462,
http://en.wikipedia.org/wiki/Socket_A
Processor's, and maximum processors supported, are shown in the specifications.
The motherboard chipset is a VIA KM400A, and VIA VT8237
(Northbridge chip = VIA KM400A. Southbridge chip = VIA VT8237)
http://en.wikipedia.org/wiki/List_of_VIA_chipsets#Slot_A_and_Socket_A
Ram Memory supported is DDR Sdram at either 266MegaHertz, or 333MHz
PC2100 and PC2700 respectively.
2GB Maximum TOTAL Amount
2 ram memory slots.
EACH slot has a Maximum Amount of 1GB.
The graphics expansion slot is an AGP.
(Accelerated Graphics Port)
Uses AGP 8X graphics cards.
Power Supply uses is an ATX form factor.
Approximately 6 inches Wide, 5-1/2 inches Long, and 3-1/2 inches Tall.
Guessing here but it's either a 250 Watt unit, or 300 Watt unit.
Probably made by Bestec, or Delta, or HiPro.
If the above is not what you had in mind, please post back in a Comment.
Regards,
joecoolvette
Dec 01, 2010 | Compaq Computers & Internet
I have this pc HP Presario uWave2 Socket462 Motherboard compaq presario 4000. The problem is that is doens't on, the cpu has the light in green but the monitor doesn't show anything, something if they...
alot of motherboards use shared memory for display meaning that if the memory cards lose connection no video.
take memory cards out of the computer and clean the gold contacts with pencil eraser and try rebooting the computer to see if you get video if not try 1 memory card at a time to see if there is a bad stick of ram causing it not to show video.
Jun 26, 2010 | Compaq Presario 4000 System Board...
Kicks off dial-up after 5 minutes-dial-up shows still connected compaq presario sr111onx
This is normal. All users of dial up get kicked off randomly to make room on the service providers servers for other users to log on. In addition to it's extremely slow speed, this is the downside to dial up. I would suggest switching to DSL or Cable. It's a constant 'On' connection you cannot get kicked off of.
Apr 25, 2009 | HP Compaq Presario SR1110NX PC Desktop
Need Power Pin Outputs for Compaq Presario Motherboard
Orient the motherboard so that the Memory Slots are at the top of the board as you look down upon it, and the white plastic power connection is at your left also at the top of the board.
The power switch block of pins should be at your right hand and also at the top of the board in a line with the power connection and the top of the memory Slots and identified as such, but since you have been persistent in asking, I assume they are not so carefully identified.
If you do not have the other connections assembled on the rows of black plastic with copper colored pins where the connection to power is located, simply use a magnifier to locate the paint that SHOULD be located on the printed circuit board identifying the power switch, the hdd switch and the fan power connecter and note the POWER indication located on the motherboard in white paint. The jumpers or white pieces of plastic should also be located in this area, as a guide.
Compaq does not provide such a diagram as you request, but does have a PICTURE of your motherboard located here halfway down the page in the form of two alternatives.
Apr 07, 2009 | HP Compaq Motherboard
Pc freezes when new memory installed
You problem is the motherboard.On your PCs mother board the 128MB that came with the motherboard might be the highest memory the chipset on your motherboard can accommodate. The chipset is built in and you cannot change or upgrade it. You can speed up the PC with how many memo sticks you added, if the chipset can handle. So it look like if you want a fast PC you need to get a new motherboard chipset with higher memory clock frequency.
Here's the pic of the chipset on the motherboard(square type)
Nov 24, 2008 | Compaq Presario 5000 PC Desktop
My friend has a Compaq presario f600 laptop & needs to replace the motherboard. What sort of motherboard would he need to get for it please?
I think I have the same laptop that also needs a motherboard. The Presario F600 also had a m/n of F572US found on the label with serial. Looking on the Compaq site I found the motherboard is the same as for the F500 notebooks which is 442875-001. Link is at: http://h10032.www1.hp.com/ctg/Manual/c01095493.pdf This number is also found under the memory chips on most Compaq/Hp Laptops. Simply open memory cover and remove the memory chips and there you will find the Motherboard replacement number. Good Luck!
Nov 03, 2008 | Computers & Internet
A new motherboard for a old compaq presario 5240
You will need a new case and a new power supply. I would replace the memory as well.
Compaq had a tendency to make cases to only fit their boards back then. Youre better off building a new unit and starting over again.
Jun 14, 2008 | Compaq Presario 5240 (353200-003) PC...
5 beeps HP Compaq d530
5 Beeps
CPU or motherboard problem
Apr 11, 2008 | HP Compaq Business d530 Ultra-Slim PC...
Computers & Internet Logo
223 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
