LG CRN 8245B (CRN-8245B) Internal 24x CD-ROM Drive Logo
Posted on Nov 13, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My computer taking over 10 minutes to login to windows
My computer taking over 10 minutes to login to windows. After the computer finally booted successfully into Windows, I disabled all the startup items under the system configuration.
But still taking long time to login to windows.
Please what it may be the problem
Thanks
Bill Boyd
Level 3:
Top Expert:
  • LG Master 53,816 Answers
  • Posted on Nov 13, 2017
Bill Boyd
LG Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11925872
Points
172802
Indicates a hard drive problem
however there are several steps that you can take to get storage space
go to control panel , programs and features and delete any programs that you seldom use or were install but never use
next get to device manager and run the defrag on the disc
That puts like registers on the same section of the disc so the computer doesn't waste time searching for all the bits of files and folders
next in the search bar under the programs on desktop, type in CHKDSK and enter
That stats a repair program in the computer that runs all of the programs , files , folders , everything and repairs them as it goes
That will take around 6 hours for the average computer
lastly
if there is a spare slot for ram memory try installing an exact identical stick to double the ram memory
The computer uses the ram as a temporary filing cabinet as it processes commands so an enlarged ram facility makes the computer run faster as it can move data around a lot easier
it it turns out to be a hard drive problem , a replacement solid state hard drive _SSHD- is the best way to go because it doesn't have a spinning disc and so is faster in operation
1 Related Answer
Anonymous
  • 82 Answers
  • Posted on Feb 11, 2009
SOURCE: My computer taking over 5 minutes to login to windows
Try defragmanting all the drives.Then download hijack this(you can get it via a simple google search) n do a scan.It will reveal so many items.Dont do anything if you dont know what you are doing.Seek help from me or the home website of hijackthis will help you in assisting for the removal of malwares.Also download ccleaner n remove all temporary datas..
1helpful
2answers
How to remove Windows 7 password to let Toshiba laptop boot from hard drive successfully?
Windows operational system locked always leads to Windows 7 not boot from hard drive completely. Actually, that just need you type correct password to login Windows 7. However on this occasion, only password reset disk or password recovery could help us remove locked Toshiba Windows 7 password.
1. Remove Windows 7 password with reset disk
When you type incorrect password, the window will prompts you that Reset password. Click the link to begin password reset with disk.
Following the password reset wizard, you can easily reset Windows 7 password with boot disk.
2. Remove Windows 7 password with password recovery software
Step 1: Download Windows 7 Password Genius from Internet.
Step 2: Install and run it on accessible computer.
Step 3: Take blank USB disk and insert it into accessible computer for password reset disk burning.
Click "Begin burning" to create a Windows 7 password reset disk. Exit USB disk from the computer when you see the message "Successfully burning".
Step 4: Plug USB reset disk into locked Windows 7 computer, set it boot from USB device.
Step 5: When Windows 7 Password Genius program runs in WinPE, choose accounts and click "Reset password" to remove these accounts password to be blank.
Reboot locked computer and it will boot from hard drive successfully, without any login password anymore.
5answers
Reset my passwords
I reset my laptop password by the following steps,
Step1: Get Windows Password Recovery Standard from: http://www.recoverlostpassword.com/products/windowspasswordrecovery.html.
Step2: Install and launch it to any accessible computer.
Step3: Use a blank and writable CD/DVD to burn Windows password reset disk with the tool.
Step4: Boot the locked computer from CD/DVD.
Step5: Start to perform Windows password reset with the burned disk.
Step6: Reboot computer and login to the machine without password.
(Note: Before starting password hack on Windows process with Windows Password Recovery Standard, you need to find another accessible computer and an empty CD/DVD.)
8answers
Forgot my login password on my toshiba L645D
Hi snowymountai...
Try this solution to your problem.
Start your computer
1. Keep pressing "F1,F2 or F8" as the laptop computer starts.(Depending on your computer)
This will start the computer in Safe Mode.
2. When the window "Advanced Boot Options" opens, choose "Safe Mode" with arrow key and confim by pressing the Enter key, then PC enters the Safe Mode.
3. Once you are in the Safe mode Click "Administrator" on the Windows login screen.
Take note that you have set the Administrator password before, you need to input the changed password instead of leaving "Password" field blank.
4. Then click Start > Control Panel > User Accounts > Select the account that is locked and change the password.
5. Restart laptop and login into the account you just created using your new password.
Please take time to rate me thumbs up
5answers
Can not remember window's password, also Admin has been disabled. How can I unlock it?
The Windows Login Password can be changed only if you have an access to Windows.
If you have another Admin User Account, you can try logging into other account to change the password.
If the computer is not booting to windows, then you can perform system recovery to restore the computer to factory settings.
The system recovery process will erase all the data in computer and restore the computer to factory settings.
You can restart the computer and press the F8/F10 key at start up to access the recovery partition. Once you access the recovery partition, you can perform c drive recovery in your computer to resolve this issue. Below is the link with the details to perform system recovery in your computer:
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C460161
1helpful
3answers
I forgot my password pls help me
there should be a "jumper" near the cmos battery on the motherboard. it'll say something like cmos resest. move the jumper power on the computer. Power it back off and move the jumper back. It should reset your bios password.
1helpful
6answers
How to unlock lost password or reset the device to clear the password
Hi,guy,you forget to tell us what password?but you are so lucky because nowadays there are so many 3rd party utilities which claim to recover or reset the forgotten password
check this out:unlock lost password
Hope the website can help you
Good Luck!
3answers
I have changed the password and cant remember it so am unable to get into the computer have tried F9 whilst booting up but still no joy
is it power on password or windows log on password.
for power on password u will have to disable the disable the cmos battery for about 4hrs if u cant i suggest u take to an expert. For windows log on password,i guess u dnt have a password reset disk....there are password removal kits sold online which u may use,but u can also backup all ur entire data manually and format ur system.
System Errors - WiFi connectivity
lots of choices...
if you have os disk boot off it and select repair which will take you to the dos prompt..(c://)
here type chkdsk and enter this will check and fix any errors.
other choice....when you start pc and get to login window select logout,wait for next page (a few seconds) and select login and it should load a lot quicker if this sorts it let me know and I'll tell you why this is and what to do unless your happy doing that each time.
the wifi...
once windows and drivers all loaded open control panel,select administrative tools select services and scroll to wireless zero config and press start.this will solve 2 issues.first it will get u connected 2nd it will verify that your wifi manager (software addon with drivers)is incompatable or not installed correctly or has conflicts either way youll need to uninstall it and reinstall or leave pc set for windows config
1helpful
Laptop
Hi, It appears that the your computer taking some time to login to windows. I suggest that when the computer finally booted successfully into Windows, you need to disable all the startup items under the system configuration.
Just type in "msconfig" under the "Run" screen and hit the enter key or click OK. Please click on the Startup tab then click on "Disable All" then hit "Apply" and "OK". You need to restart the computer to so that the settings will be updated.
Hope this helps!!!
Thanks
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
