Question about JVC RX-9010V Receiver
Overloaded. When watching movies or dvd's or TV my receiver will shut down and it says "OVERLOADED". It happens when I have the volume at 50 or more. Am I underpowered? What do I need to do?
Your probably overdriving your speakers. unit will detectand set overload when it gets hot or your speakers start to disort out. most amps is at full volume at half volume anyways
Posted on Aug 14, 2012
4 Suggested Answers
SOURCE:
SOURCE: overloading when volume is turned up
I have the same prob.
Posted on Nov 01, 2008
  • 4234 Answers
SOURCE: receiver overload problem
The overload message is indicating that a problem was found and the system is shutting down the output section to prevent further damage. There are probably poor connections on the main board and failing capacitors in the front end. Expect a parts vcost in the $10 range. Add in the local labor rate for the total repair bill.
Dan
Posted on May 23, 2008
Shaul Dag
  • 30 Answers
SOURCE: when playing music or watching a movie, after a
Check to see if the receiver is properly cooled.
Sha'ul
Posted on Jun 27, 2009
When watching a movies or playing xbox my avr220 powers down when ever there is a boom in the movie or games or tv this just started about 2 months now
Something is getting overloaded.
When this happens:
Is it running hot? Find out why.
Is the volume set extremely high? Turn it down.
Are the speaker settings proper for the types and bass handling capacity of your speakers? Set them appropriately.
Dec 05, 2009 | Harman Kardon AVR 235 Receiver
Audio fluctuation with volume
It is common theese days to have volume fluxuation while watching TV when viewing a HD show and going to a commercial break it gets ungodly loud, that's from digital to analog variance. However what you describe and the way you describe it leads me to believe its a chip in the receiver. The only way to really know for sure would be to hook up a DVD to your TV input and play a long movie " the godfather" or something like that which is a three hour or so movie and listen for the issue to occur. If it does, you know your receiver needs to be serviced. If it doesn't, swap your cable box or DSS with another one if possible and test again. It will take some time, but it won't cost you anything! Hope this helps. If you still have issues with it, send a response and we can try other things as well.
May 24, 2009 | Audio Players & Recorders
The audio and video are not in sync
Are the movies you're watching store purchased DVDs? Sometimes with downloaded movies, the audio and video are just out of sync.
If they're store bought, it's possible that you've got a delay set in your receiver. Consult your receiver's operating manual to see if there's a "delay" option.
It's also possible that you're hearing that delay in the TV speakers.
If you've got the audio coming through the receiver AND the tv, you'll hear a slight delay when the audio's traveling from the DVD player to the television itself. This could happen "sometimes", if the tv volume is on, and not happen when the tv volume is off.
Mar 19, 2009 | Sanyo DVW-6100 DVD Player/VCR
Overload
you to slow down the volume on the consloe and make sure no wires are touching the reciver.
Apr 13, 2008 | Pioneer SX-315
Problem with HT-X250R
It sounds to me like it is overloaded and won't come back on because it has overload protection. Check your connections and make sure the outlet or power strip it's plugged into isn't overloaded. I would disconnect everything from it and turn the volume all the way down and try to get it to come back on. Let me know what happens.
Feb 17, 2008 | Audio Players & Recorders
Overload
Ok, how much is "a bit"? If you are operating your unit at the 50% or more level, your unit is working as it should, as DVD and CD players output more signal than other sources...accordianman
Nov 26, 2007 | Pioneer VSX-D307 Receiver
Overload
Firstly check all your speaker wiring. Any damage can cause a short which will overload the system. You might not notice it, due to the fact that when you have the system on loud, vibrations move the wires on the cabinets or elsewhere. So make certain there are no loose wires near the speakers terminals into each one. If all that is good go to the next check.
Check If the amp is getting VERY hot when the overload occurs, then it might have a faulty part(s) on it. This might have occurred if you have been using speakers that never did match the amps requirements in the first place.
Mar 12, 2017 | JVC RX-668V Receiver
JVC RX-9010V Receiver Logo
112 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
