Question about RCA D61W20 61" Rear Projection Television
RCA HDTV #D61W20, CHASSIS ITT222
I am having power issues. When power button is pressed, the power light comes on, I hear a small click in the back and then the light goes off again. It will repeat the same process 2 more times for a total of 3. After numerous attempts, TV finally comes on as I can hear the screen make that popping sounds before tvs come on. I've read through previous posts and have heard of 3 possible problems. Bad Power Supply, Bad Capacitors, and Bad Flyback. Is there anyway I can check to see which problem I am having? I have a background in computers but not tv's, but I do have basic soldering skills. Any help would be greatly appreciated
  • RCA Master
  • 8,617 Answers
You will need a new flyback number 259296 and also a new cp150 which is a 2200uf 25V radial capacitor. You can get replacements at the following link and they provide free installation instructions.
http://servicemanuals.vstore.ca/
Posted on Sep 19, 2008
D61w20 rca turns on and off
I have a RCA D61W20 chassis ITC222, I had the same problem and my repair guy found out the blue bulb was the main problem, along with replacing some transisters on one of the power boards, He also had to adjust the service convergence (not auto convergence). Works great now!
Aug 27, 2009 | RCA D61W20 61" Rear Projection Television
Trouble turning on RCA D61W20
the green light blinks three times but does not come on
Aug 16, 2009 | RCA D61W20 61" Rear Projection Television
Who does in home TV repair have an RCA D61W20 or can it be done m
The most obvious item which is causing your problem are the 220K ohm 1/4 watt resistors on the convergence power supply board. There are four of them RP10, RP11, RP12 amd RP13
Jun 18, 2009 | RCA D61W20 61" Rear Projection Television
RCA HDTV #D61W20, CHASSIS ITC222, PUSH & TWIST CAP ON HV CABLE
do you have the part number for the flyback ? I need it if you would please. send it to
swampbiker@hotmail.com
thank you
Apr 01, 2009 | RCA D61W20 61" Rear Projection Television
Rca hdtv wont turn on
you need a new flyback and a CP150 Capacitor. If your chassis is the ITC222 you need flyback number 259296 you can get replacement flyback and the CP150 at the following link and they send detailed photo instructions so you can easially do the repair yourself.
Jan 15, 2009 | RCA Televison & Video
RCA HDTV chassis # ITC222 will not come on.
most likely the Flyback 259296 and CP150 you can get replacements at the following link with free instalation instructions
Nov 25, 2008 | RCA D52W19 52" Rear Projection Television
RCA HDTV #D61W20, CHASSIS ITC222, Power button flashing 1, pause, 9. Possible error code 19, anyone know what this means
This is not a friendly chasis, the only easy fix that you might check on the power supply board and the left side (looking from the back) 3 capacitor (220,330,and 2200uf 16V) have the top pop up. Other than that poping, arcing noise, burn smell when first start up is bad york, Flyback Transformer and even the cooling leak for those tubes you will need professional TV repair man. Those TV picture not very nice anyway.
Nov 07, 2008 | RCA D61W20 61" Rear Projection Television
Powers off
do you hear any sounds what so ever? Clicks or anything when you press power.
Jun 06, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
46" projection not coming on
You have an power supply problem & or a high voltage flyback transformer gone bad. The regulator is usually an STK followed by some numbers, located on a separate small board above the main chassis in the rear of the tv. The flyback is down on the main chassis & has a red high voltage lead wire coming out of it that goes to the high voltage/focus block.
Aug 07, 2007 | RCA P46924 46" Rear Projection Television
RCA projection televeion problem.
take your tv to a tech for repairs the tv power supply or related circuit is defected.good luck
May 14, 2007 | RCA D61W20 61" Rear Projection Television
RCA D61W20 61" Rear Projection Television Logo
224 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
