Question about Broan-NuTone VX475 Bagged Central System Vacuum
Old Nutone central vac system turned itself on and ran for hours.
It is a model 350. Probably original to my house, about 25years! Is this some simple fix or do I need to replace the main unit? It has worked perfectly otherwise.
  • cardiogal Sep 27, 2008
    I appreciate the suggestions but couldn't get it to stop running without unplugging it. The serviceman is due next week!
  • Anonymous Mar 24, 2014
    Nutone cv-350 central unit would stay on after disconnecting, but now will not turn on at all
  • 120 Answers
If your unit normally turns on when you open the flap on the wall inlets then you should check each inlet for a switch or a button, sometimes those buttons can get loose and fall into the wall making the unit stay on. if your unit normally turns on when you plug the hose into the inlet then it would probably be a relay usually on the main tank itself try locating them and gently tapping on them with the rubber end of a screwdriver to see if you can un-stick them.
Posted on Sep 25, 2008
My central vaccum just stop working last night. It does not turn on at all.
I've gone through 3 vx475 vac in the past 7 yrs. Last one was sent to me in Apr 2010. Just yesterday, once again, my vac just quit. Green power light is on but no other sign of anything. Had a burning smell when vac quit, like motor just fried. Called Nutone again and they can't imagine whats going on but will send out another vac free and was told to throw out old one. They said dust may get into the motor and cause it to quit. These vacs aren't cheap, can't imagine that its so simple to just call up and have a brand new one sent to me. I've asked if they are rebuilt units and was told no. So my advise to you, if you haven't already, is to simply call them up w/model and serial # and they shouldn't give you any prob. good luck.
Sep 03, 2010 | Broan-NuTone VX475 Bagged Central System...
Nutone Scovill 350 will only turn off if unplugged
Some units have an on/off switch on the power unit itself. Check to make sure that is not turned on. Unplug your power unit and remove the 2 low voltage wires (not the power cord itself) . The low voltage wires start at the unit and run throught your home and attach to each hose inlet. They are usually attached to the unit by simple wire terminals or wire capped to small wires coming out. Just unlug the terminals or unscrew the wire caps and pull the connections apart. Plug your machine back in. If it still comes on the problem is the relay or circuit board/switch/ relay assembly inside the unit. If it doesn't come on with the low voltage wires unattached then you may have two wires touching somewhere in the low voltage wiring.
May 14, 2010 | Broan-NuTone CV353 Central Vacuum
Central vac will not turn off
You have a defective internal relay on the vac. Check for warranty coverage as this is a common occurrence on these big box store units.
If beyond warranty the relay should be a straight forward unit, miniature circuit board type plug in device. Find a Broan Nutone service center or take to vac pro shop for parts.
Nov 01, 2009 | Broan-NuTone VX475 Bagged Central System...
I have a Nutone central vacuum model number CV450W that was working great until I recently removed the hose and it now runs continuously until I pull the plug....any suggestions please
Disconnect the thin low voltage wiring between the vac and the rest of the house. If the vac continues to run you have a defective relay in the vac motor housing.
If the vac stops you have a short in the wiring in the house, likely behind an inlet in the wall.
If any inlets have been disturbed for painting or renos lately that would be the first spot to look in the house for a problem. Look for wires behind the inlet valve which are touching against each other or a mounting screw or against a metal mounting plate behind the inlet. Start at the last inlet used. Be careful not to loose the spring under the screws where the wiring attaches to the inlets
Oct 08, 2009 | Broan-NuTone CV450 Central Bagged Central...
No power. electric is OK. system will not turn on. Please help
Detach the vac itself from low voltage thin wiring leading to the house. With the vac plugged into power, try the manual switch and then try shorting across the low voltage exterior terminals with a rubber gripped set of pliers.
If you can hear a clicking inside, this is the vac's relay trying to start the motor. If the vac is more than 5 years old , or used more than 2 hours a week, you may need new carbon brushes, or a motor overhaul or replacement depending on wear. Carbon brushes are specific to the motor model # inside the vac, most often an AMTEK Lamb motor.
If you need brushes, the motors comutator should also be inspected for excess,wear, like gap ing between its conatct segments and "apple core" shaped wear
You you have a meter and can test for continuity across the motor leads, do so and post back.
If you don't have a meter, you will likely want to lift the vac off the wall after these checks and take to a repair shop, saving $$$$ for a house call...
Oct 06, 2009 | Broan-NuTone CV353 Central Vacuum
NuTone Central vac won't turn off
If the central vacuum tank will not turn OFF even with the switch in the “OFF” position, then the low-voltage wires should be disconnected from the tank. If the tank continues to run and still will not turn off, then most likely the relay inside is defective (but it could be a defective and/or shorted ON/OFF switch). If with the low-voltage wires disconnected the tank is able to then be turned off with the switch, then there is a short in the low-voltage wires or a hose is plugged into an inlet somewhere. ~ TTURAMBAR
Mar 11, 2009 | Broan-NuTone VX475 Bagged Central System...
I have an old central vacuum that I don't have a manual for.
If it is a NuTone system you should have a filter and a BAG in the tank. just got to their site and look up your model number to see what you need.
Dec 16, 2008 | Broan-NuTone CV353 Central Vacuum
I have a 3 year old NuTone CV 353W central vac system and recently the switch on the hose handle does not turn the system on from any outlet in the house. I have to plug the hose into the outlet and then...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=567634
Generic problem for all Vacuums
I have a 3 year
posted by patfitz on May 03, 2008
I have a 3 year old NuTone CV 353W central vac system and recently the switch on the hose handle does not turn the system on from any outlet in the house. I have to plug the hose into the outlet and then turn the unit on from the switch on the canister. Any help would be greatly appreciated. Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. There are a couple of things that come to mind, 1st. you may have a bad switch in the hose and in most cases that can be repaired – if not you would have to purchase a new vacuum hose. 2nd. You may have a bad inlet valve in your hose and most of them are low volt of which would only cost less than $10.00 and can be replaced yourself unless you have what they call a SuperValve of which has 2 low volt wires and then it is wired to your home electricity and that should be replaced by an licensed electrician. It is a low volt and high volt inlet.
#3. the last thing you may check id that you may have a bad relay in the canister itself. Because you should be able to turn on the Central Vac with the switch on the hose and everything should work just fine . feel free to contact your local vacuum cleaner dealer in your area of call the Nutone Factory cust serv line for further assistance. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://nutone.com/ Customer Service
Nutone Inc.
9825 Kenwood Road
Suite #301
Cincinnati, OH 45242
Customer Service 1-888-336-3948
Technical Support 1-888-336-6151
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 03, 2008 | Broan-NuTone CV450 Central Bagged Central...
No suction on lower level
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=539794
Posted by phil55555 on Apr 23, 2008
Nutone central vac
no suction on lower level second floor fine
ran fish tape but it does not go all the way through,
do i need to take pipe out.
Not @ first, try to get a central vacuum cuff and go to each and every inlet / outlet down the basement and put the cuff in the inlet – the central vac should come on and possibly might unclog the pipe, 2nd, try taking another canister type vacuum while the central vac is running and open the inlet door and try to “pull apart the clog in the pipe” – this does work upon occasion if not you can try a plumbers snake – but be careful because the walls of the pvc pipe are thin wall and you don’t want to poke a hole in the pipe or other wise you will have to replace the pipe. The absolute last resort should be to replace the pipe if all other do not work. Feel free to contact your local vacuum dealer in your area or in the yellow pages , or contact the factory @ the phone #’s listed below:
http://nutone.com --- Customer Service
NuTone Inc.
9825 Kenwood Road Suite 301
In U.S.A. call:
1-888-336-3948 for Customer Service
1-888-336-6151 for Technical Support
In Canada call: 1-888-882-7626
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 23, 2008 | Vacuums
Broan-NuTone  VX475 Bagged Central System Vacuum Logo
278 people viewed this question
Top Broan-NuTone Vacuums Experts
Steve
Gerry Harvey
Gerry Harvey
JoeVacs
Are you a Broan-NuTone Vacuum Expert? Answer questions, earn points and help others
