Question about Panasonic DMR-E55 DVD Recorder
Remote controle when trying to use remote CHLK REMOTE2 comes on the dvd screem
  • 3010 BULL Apr 19, 2009
    Mine is exactly the same but it says chk remote 3 and i cant even pull up the setup or anything
  • 185 Answers
Easy to fix. The DMR E55 has 3 remote control code settings and your remote can be set for any one of them. The error you are getting at the moment means that your remote is set for one code but your DMR E55 is set for another. Why do Panasonic do this? The reason that Panasonic do this, is because if you have several Panasonic units, you can operate one of them from your remote without all of them responding at the same time. Ok, so how is it fixed? Turn on your DMR E55 and press FUNCTIONS then select SETUP. Then select OTHERS. You will see the remote option on the right which will say DVD 1 or DVD 2 or DVD 3, Try setting it to a different code and press return. You should get it to work...
Posted on Sep 19, 2008
Universal remote2 code for rca tv model p52939
2193,2116. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Oct 31, 2015 | RCA Televison & Video
Screem horeezon code with remote
289,288,281,285 Try these codes. If you wish to get more codes and other details check:
Both the sites have setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
Jan 20, 2014 | Televison & Video
The screem dosen,t work
You may try: turn off the brake cable detection of your Car DVD player in setting;check your screen;check power supply of screen
Jul 17, 2012 | Pioneer AVIC-N2 Car DVD Player
Schematics for a tm1050 remote
you will not find any schematic for remote control.
I am suggest you to open the remote control, and clean the keypads, from humitidy, dirty, oxide, and dry with dryer gum, very carefully.Resolder the colder joint in a board remote
2) retigh the spring contact batteries with pliers for a GOOD contact.
3) resolder the wires contacts batteries.
4) clean the contacts batteries.
God bless you
Jun 30, 2012 | Samsung Televison & Video
HAD REMOTE2 set to turn on/off LG TV. trying to reprogram and it wont take code nor scan to find. Sat works tv does not.
dmmcgregor
I'm sorry you are having problems reprogramming your TV 2 remote to your LG TV. Have you replaced your batteries? If so, I have provided a link on how to reprogram the remote and how to perform a power scan. I will also give you several codes that should work with the LG TV. This is the link with the instructions for programming the remote to your TV. It begins with step 6.
http://www.dishnetwork.com/SupportSection/power-scan-instructions
If you have any other questions or problems, please respond to this site.
Ray Calo DISH Network
Jan 22, 2011 | DISH Network IR Remote Control
NAO CONSIGO USAR MAIS O CONTROLE REMOTO, COM ISSO NAO CONSIGO FINALIZAR O DISCO......QUANDO TENTO USAR O CONTROLE APARECE NO DISPLAY " CHECK REMOTE ". E NAO SAI DESSA.
Há algum tempo o meu Gravador de DVD de mesa Panasonic DMR-E55PL-S vinha apresentando a seguinte mensagem de erro sempre que eu clicava qualquer comando através do controle remoto: CHK REMOTE2 Havia entrado em contato com o técnico da autorizada Panasonic de Niterói e ele ficou devendo-me uma solução. Como possuo outros 3 gravadores de mesa (2 Pioneer e 1 Samsung R121), apesar da contrariedade, não esquentei muito a mufa. Hoje, porém, encasquetei, e resolvi tentar, mais uma vez, resolver a má função. Após "ene" tentativas malogradas pintou o insight: - "Cacildas! Se eu faço tanta pesquisa para dirimir as dúvidas dos companheiros, por que não o faço também, para mim"? Assim, digitei no "gluglu": CHK REMOTE2 Panasonic Entre outras dicas, saquei esta: Question: - "Whenever I press any button on my remote control, I get this error message on the front panel display - CHK REMOTE2" Answer: - "Just hold ENTER and press the number indicated on the display for a few seconds, and it will fix the issue". Basta clicar ENTER e pressionar o numero indicado no display do painel frontal do gravador por alguns segundos - isto resolverá o problema. (Clicar ENTER e pressionar o número 2 no controle remoto). Tal dica serviu para o meu DMR-E55PL-S como também para o DMR-E85HS - do **** "flashcode" - devendo servir para outros modelos Panasonic da mesma linha. Soçarba... Mr. Walker
Aug 25, 2010 | Panasonic DMR-E55 DVD Recorder
I have Panasonic dmr-e95H and need to reset the
My DMR-E95H displays: "CHK REMOTE2" whenever I push a button on my "replacement" remote. Is there a way to reset the DMR-E95H without the original remote?
Apr 05, 2010 | Panasonic DMR-EH57 HDD Recorder Player
Screem Comes on brefly and then fades to black
go to control panel and click on screem after click on screem saver select none or try configurate to more time for to active the screem saver, and if it is not that you must take it to a technician
Jul 15, 2009 | Sony STYLEPRO SDM-S91 19" LCD Monitor
Remote control not working
I had the problem where when i would try to use my remote, it would say "check remote2". I've got a DMR-E55. I called panasonic and they told me to hold down the "enter" and "2" button for about 10 seconds. then it worked. hope it works for you too.
Jul 09, 2007 | Panasonic DMR-ES10 DVD Recorder
Panasonic DMR-E55 DVD Recorder Logo
345 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
