Question about Directv D10 DTV Receiver
No signal I have 2 d10 receivers one in the living room stopped working and went to searching for sat. signal,i have reset it and there is no change,so i move the one out of my bedroom in there and it works fine,i put the one the other one in the bedroom and still get the same message is just broke or burnt up?
  • 68 Answers
If you have switched them around and u still have the same problem from the receiver, them the box is bad. call directv and let them know. they will either send u a new one or send a tech out to replace the bad one
Posted on Jan 06, 2009
Added a 322 reciever to my lake house to be able to watch tv in 3rd room i had 2 standard recievers before. i installed a dish pro quad lnb & reciever had a separator w/it says dp plus 123254 tuner 2...
Is TV 2 off the 322 receiver being back fed from the receiver or do you have a direct connection to the 3rd room? If it is a direct connection, you would screw the coax from the 3rd bedroom directly to the TV 2 Home Distribution channel 21-69 out port.
If you are back feeding, you need 2 diplexers that connect 1) by the receiver and 2) between the receiver and the 3rd TV. The back feeding will use the same cable coming from the dish to the receiver.
If you have any other questions, please don't hesitate to ask.
Jun 26, 2011 | DISH Network 322 DTV Receiver
I am transitioning our spare bedroom into a tv room. There is a coax wall plate in the room. I bought a new satellite receiver but do not think the coax wall jack is turned on. I can not get a signal...
Hi
1st remove the plate from the wall cheek if there is a coax cable connected to it also make sure the plate is not broken if it is of the printed circuit type. 2nd trace out where the cable goes to most likley into the loft if you are using this to receive sat pictures the this lead will need be to connected to a sat dish or a aerial for tv (free view) if you have to replace any cable use the correct type.
regars Derrick
Jan 30, 2011 | D-Link Televison & Video
Dish network control not working on 2nd. tv
You have a dual receiver and 2 remotes. make sure that receiver is in dual mode. That you press the sat key on remote 2 if it will still not operate take remote 2 to the receiver. With remote #1 press the menu button twice you should then be on they system info screen. Pick up remote #2 press and hold sat key until it blinks press record 3 times . press red power button and if tv2 light goes off and on the remote should work again for tv2 . Use remote #1 press select exit screen,
Jun 02, 2010 | DISH Network IR Remote Control
Remote codes
the 4220 does have SAT code 1377 on board, and will work with the following Directv sat receiver models: D10, D11, R15, H10, H20, and HR20.
Try code: SAT1377
What address is the D10 set to, DTV (00001) or AV1/AV2 (00002)? SAT code 1377 is for receivers set to white remote native code 00001.
to blink back the code on the white remote:
1. dtv
2. press and hold MUTE & SELECT for two blinks
3. enter 9-9-0
4. press #1 key, it won't blink because the numeral is zero
5. press #2 key, same as a above, zero blinks
6. press #3 key, zero blinks
7, press #4 key, zero blinks
8. press #5 key, this should be 1 or 2 or 3 blinks
Mar 31, 2010 | One For All URC4220 Remote Control
I HAVE DISH NETWORK HOOKED UP IN LIVING ROOM, I WOULD LIKE TO ADD IT IN BEDROOM OFF OF THE SAME RECIEVER. I USED A SPLITTER, THE PICTURE IN LIVING ROOM IS CLEAR, BUT REALLY FUZZY IN BEDROOM. I KNOW THEY...
You will need to split the signal with a 900mgz splitter between the living room and other room. if your pic is fuzzy you have a bad splitter or bad cable, try replacing these one at a time and it should clear up. If your getting a sat pic but ti is fuzzy its for sure in the line somewhere fro teh splitter.
Nov 16, 2009 | DISH Network ViP 612
Wont calculat route
sat nav needs a valid gps signal to start calculating route, even if it found entered address. Address is searched on built-in map, not live gps position. That means, sat nav may have problem with gps signal. Try to reset device to its factory settings first. hope this helps
Nov 01, 2009 | Garmin Nuvi 360 Bilingual GPS Navigator...
New home theater setup- no signal at tv using onkyo tx=sr605
Could well be the quality of your cables. if you have high end cables the consult a service agent. if you have the cables that came with the products, go and get some better ones.
Nov 04, 2007 | Onkyo TX-SR605 Receiver
Dish Network DVR
You have what is called a diplexer in the back of the the receiver in the front room.It looks like a splitter.If it is put back on in the wrong way you will have a fuzzy screen.look at the diplexer,you will see in/out which would be the input on a regular splitter,then you will have one side that would be one of the 2 outputs that will say SAT,the other side is UHF/VHF.The chances are that when you plugged them back in you had them swapped.Try changing the 2 cables around.If that doesnt work try changing the assigned channel to 68.You can also try doing a auto channel search on the tv in the room without the receiver.this will find the channel that the front room receiver is broadcasting the signal on.Chances are though that your diplexer wires are configured incorrectly.remember,the in/out should plug into the back of the receiver (satellite in)and the UHF/VHF should be going to the other room with the problem and the SAT side of the diplexer should be wired to the satellite dish.GOOD LUCK! rate me with the outcome please.
May 09, 2007 | RCA DISH Network(r) 311 Satellite System
Sanyo DS27880 27" TV, Dish signal lost after tv turned off, doesn't return
checks should on your tv tuner it could be bad.IF circuit should also be check and the video section call in the tech to make checks on your tv.and to do repairs on your tv.
Jan 19, 2007 | Sanyo DS27820 27" TV
Directv D10 DTV Receiver Logo
380 people viewed this question
Top Directv Televison & Video Experts
john milligan
rundiggity
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
