Question about HP Computers & Internet
Cannot get monitor out of sleep mode
I have a HP m7463w desktop computer. For some reason I cannot get it to come out of sleep mode. I can turn it on and off and it comes back for maybe 3 secs then goes right back to black. I have tried unplugging everything and waiting for a while to maybe have it reset itself and nothing. I ran a virus scan and did find a virus that has been quaranteened, I have set everything to never as far as sleep mode and hibernating goes. I checked the bios and it is set to PCI, I have uninstalled the driver and that didn't work, and checked the color settings, as well as updating the graphic driver and also tried rolling back the graphic driver. Nothing is working. Any ideas what I can do. I do know that before this happened my son was either on You Tube or WWE.com. Thanks
  • MomofJess Sep 19, 2008
    Thanks Andrew,
    I actually forgot to mention that I did try another monitor, and it did not work either. When I was working on the computer, I would keep turning the monitor on and off and use the very small amount of time I had before the computer screen would go black again to work on the computer. UGH I will try your other suggestions to see if they might fix the problem. Thanks again.
    Beth
    Scholar:
  • 32 Answers
About 90% of the time this is a cable problem. Check the connection on both ends. Make sure the cable is firmly seated. If it is, pull out the cable and check the ends to make sure that none of the pins are bent. If so, straighten the pin back out and reinsert the cable.You could also try a replacement cable.
It could be a video card problem but since you seem to indicate that you have worked on the computer, I'm betting that you connected a different monitor to your computer. If that is the case you are good.
The only other thing (well there are other but even less likely) that might have happened is that the refresh and resolution for you video card got changed to a setting that your monitor (assuming it is a CRT monitor) can't handle. This could have actually permanently damaged the monitor. In WinXP right click on the desktop, select properties, select the settings tab and move the slider all the way to less. Click apply and try and connect the non-working monitor.
Posted on Sep 19, 2008
  • AndrewWro Sep 20, 2008
    One other idea is to reset your bios to factory defaults. This can become corrupted (almost never but something I'd do if I was sitting in front of your PC) and if you have integrated video it may be sending a bad signal to the monitor. When you first turn on your computer, press DEL, F1, Insert or an alternate key (the manual for your computer would tell you which one but those are the most common) before the computer begins to load windows. The BIOS screen will start up. At the bottom of the screen it will have a list of options. One of them will be something similar to "F8 - Load BIOS defaults" Select that and follow the prompts to confirm your selection. The BIOS settings will save and the computer will restart. I realize this will be a pain but hopefully the strobe of turning the monitor on and off to see all this won't drive you crazy.
    Given all the other fixes you did (driver reinstalls etc), I'd start with looking at the cable but you will probably be replacing the video card. If the video is integrated, you should still be able to add a video card and just use that port. The BIOS will typically just disable the on-board video automatically but you may have to go back in and tell it to turn if off if you run into problems.
Keyboard and mouse not working and monitor going to sleep
HP Pavilion Slimline S3400f Desktop.
dont worry ALL PC end up like this,, all do.. sooner or later..
NO OS stated, XP"? never post without OS stated, or answer get 10x more harder, See? make it easy for the helper and get more help.....
no Monitor stated. (maker, CRT, LCD what?)
The monitor is not fibbing to you BTW, the PC did go dead or to sleep. seems its monitor monitor of some kind with DVI.
if the monitor works on other PCs then the monitor is not bad.
i Bet it works (old ones 2002, have a hidden deep internal sleep mode. and is not yours IM sure now) DVI IS THE ONLY CLUE THERE.
So PC is dead. this PC came with only VISTA new,
is it still VISTA?????????
HP has support on it still
here (carbon dated by me 2008, IIRC)
https://support.hp.com/us-en/drivers/selfservice/hp-pavilion-slimline-s3400-desktop-pc-series/3688715/model/3688723
this year,? get all those files and books there backed up
when HP support ends after 10 year rule, (be savvy?)
what keyboard USB or wireless keyboard mouse
use wired USB keyboards if wireless the battery is dead. easy no?
now in VISTA, go to Control panel, click power
turn off all sleep modes and all hibernate modes
the turn off screen savers, if turned on , disktop . RC right click
in display settings or personalize, turn off , need login to come out of sleep or screen saver.
try a real keyboard, that has USB cable yet? be first thing to do.
always keep a real keyboard, handy,,,
batteries fail. in all wireless devices like this (inside them)
luck you desktops have lies DIM fails. there are many.
http://www.pcdied.com/sleep-or-dim.html
one other way , and common is PC overheated.
all do that.
ever one not cleaned out every year,.
#1 all time cause of overheat and PC shuts down.
http://www.pcdied.com/overheated.html
Aug 11, 2017 | HP Pavilion Slimline S3400f Pc PC Desktop
Why is that I turn on my computer and my monitor goes straight to sleep mode? every time i turn on my computer the monitor does turn on, it goes into sleep mode. how do I fix this problem?
RIGHT CLICK ON DESKTOP There select "Click" the Properties.
And follow the step that are shown below: 3b34f9e.jpg
9145b0e.jpg On the "Turn off Monitor: option" there Select Never than press OK to accept.
Hope it may be helpful to you.
All the Best!
Oct 16, 2010 | HP Computers & Internet
Monitor going to sleep problem
  • Hi, The Monitor as well the Computer have "Power Saving Modes," [Sleep, ScreenSavers, and Hibernation]; so what you want to do is "Change the way the Computer / Monitor Sleeps!" From the Desktop Screen, click on the "Start Button," next in the [Start Search Window], type: power. In the next [window] that opens, you should see, from your point of view; a "list" in the (left column) "Change when the computer sleep, the wording may be different, but it will be clear enough. Now all you have to do is change the way the Computer and Monitor "Sleep, or Turn-off." If the Monitor have its own "settings;" just find them by the [button on the monitor], and do the same thing as above; but I'm sure the computer will take care of both. If this solution to the problem was of help? Let me know by giving a "Helpful Rating", thanks, and have a "Great Memorial Day!"
May 30, 2010 | HP 2009M Monitor
Compaq Presario stuck in sleep mode
Connect the monitor to some other computer, e.g., a notebook, and see if it does the same thing. If it does, then the monitor is the problem.
If it does not, then your computer is not putting-out any "video" signal, and so the monitor goes to "sleep".
If you have MORE than one VGA-output port on your computer, connect your monitor to the "other" VGA port.
Or, press-and-hold the ON/OFF button on your computer, to force it to completely shutdown.
Jan 13, 2010 | HP Pavilion a1710n (RK573AA#ABA) PC...
Mx75 monitor turns off when I awaken my computer
right click on desktop select properties(screen saver ) select monitor button in that select turn monitor never.(configure carefully)
Nov 24, 2009 | HP Pavilion MX75 17" CRT Monitor
Hp L1706 Monitor Keeps Going Into Sleep Mode
I have an hp media center that runs windows xp with service pack 3 and my monitor is an hpL1706 monitor and was running fine now it says no input and goes into sleep mode how do I fix it?
Apr 10, 2009 | HP Pavilion F1523 15" LCD Monitor
No DVi input, then computer goes to sleep
Hi publicworker,
I had a similar problem whereas my monitor went to sleep mode after a few minutes. I'm running an HP LP 2065 in dual mode with another HP flat screen. However, I did resolve the issue after resetting the output settings.
How to do that:
  • right mouse click on the desktop
  • select graphic options
  • output to
  • extended desktop
Maybe some changings/modification will help you too.
Stefan
Jan 31, 2009 | HP 2025 20.1" Flat Panel LCD Monitor
Monitor goes into sleep mode after a few seconds
This is normaly cause by incorrect power management settings.
check power management setting in both windows and your computers bios
you will not need to worry about the power management settings of the bios when an operating system such as windows is loaded.
Loch Hiam
Az.
Sep 18, 2008 | HP Pavilion a620n (PC028A) PC Desktop
Monitor in sleep mode
my computer is on but screen is black and has power. How can I fix it?
Aug 27, 2008 | HP Vs17 17" LCD Flat Panel Monitor
HP Monitor goes into sleep mode
Problem of monitor sreen going black in 5-10 secs is generally dry solder joints around the inverter transformer on the inverter PCB.
Oct 29, 2007 | HP Pavilion F1703 17" LCD Monitor
Computers & Internet Logo
112 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
