Question about Gateway Computers & Internet
7330GZ laptop, screen is super dim, battery icon flashing. Heeeelp please!
  • 84 Answers
Needs a recharge check charger
Posted on Sep 19, 2008
My acer aspire 5742 while pushing power button,the only thing it does is the blue light on and the cooler and nothing else... please heeeelp...
Does the battery charge light come on? Does the HDD LED blink? You get nothing on the screen at boot? Remove and test the HDD, reseat the Memory Mods. Have you tried a system restore/recovery?
Feb 20, 2013 | Computers & Internet
Screen is dim when power not plugged in
In power settings you will find the dim adjust, Your laptop has power settings you can adjust to your preference. That said, the default settings are usually set to a power saving that means when you unplug your laptop from th AC source your laptop will dim to the power savings settings and prolong battery life. Look in power settings by right clicking the power icon in the taskbar notification area and open the power options. There are many options to choose from I use High Preformance, but on battery it shorten battery life. If you need assistance just respond to this solution.
Nov 05, 2012 | Samsung NP-N110 Netbook
My g60 -235dx laptop on startup error message say communication problem with I/O deveice, HD, flash drave , CD-ROM
G60-235dx. (2011 model, is my guess)
ok tell the full story please.
PC boots sequentially.
progress in that matters. so it seem windows unstated runs?
XP?
so you power on and what happens ?,
errors before windows logs in or after.?
my guess #1 is the main laptop battery is bad, remove it.
this pC runs on AC power pack endlessly, (AC power good)
dim screens. can be bad CCFL lamps or low power in the PC.
so again take out the battery
what flash drive, remove that, test the pC with no usb devices at all plugged in.
just an A.C power pack and no main big battery.
this PC has old CCFL lamp tubes that all go dim, fast.
turn yellow then dim the flicker and then DIE for ever.
all do. some in 2 years time never turned off. they do.
it the screen goes black use a flashlight if data is good on the screen the back lamp is croaking. (***** of CCFL tubes)
there are many cause of black screens, I can list 30. (will not)
but dim screens are only
1; main battery bad and shorted.
2: AC power pack near dead. (weak happens)
3: shorts in the main board, modules.overloading power buses.
4: CCFL dim as every one this old does, all do.
see flash light test.
http://www.pcdied.com/monitors.html#flashlighttest
Oct 18, 2017 | HP G60-235DX Notebook
Monitor is dim
Sounds like your inverter is failing. The inverter takes the dc power from the battery and charger and converts to high voltage AC current for the backlight lamp inside the screen. When the inverter starts to fail, the display will sometimes blink, dim out over time, flash just get dark and stay that way.
Sep 28, 2009 | Toshiba Satellite A215-S7422 Notebook
Blank screen
When u power up the computer press "del" or F2 key then check your harddisk is detected or not.
Also load optimal defaults settings.
then restart the computer press F8 key then enter in enable vga mode.then change screen resolution to 1024*768.
Please let me know.
Jun 06, 2009 | Gateway 7330GZ Notebook
Laptop screen flashes... i.e.... goes bright then dim
Check your power supply. Maybe its wire is broken then intermitently making contact every now and then. Its my first suspect. Its like disconnecting and reattaching its power supply only in much faster way. Or test it with a good similar power supply if this will be the same.
Hope this one helps already.
Apr 27, 2009 | Acer Aspire 5500 5570-2609 Laptop
Dell C640 LCD dims when on battery power
You can also presss "fn" and the "up" arrow. This will increase your screens brightness.
Feb 07, 2009 | Dell Latitude D630 PC Notebook
7330GZ won't turn on
I had the same thing happen to my computer 7330 gz and all the trouble was caused by a faulty ac adaptor. Battery wasn't holding a charge either because it's 3 years old and worthless. I got a replacement adapter at best buy for 100 buck and it's universal. Fixed it up just fine and now I'm sharing my solution with you!
Nov 19, 2008 | Gateway 7330GZ Notebook
Screen without icons ?
I had this problem briefly. I had to restore my iphone back to factory settings, and the icons and everything came back. Now, it will also update to version 1.1.4.
Mar 09, 2008 | Apple iPhone Smartphone
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
