Question about Kenmore 24032\24036 Top Load Washer
Washer fills slow only in the rinse cycle
During the initial filling of the machine, both the hot and cold water fill at a full rate.When it gets to the rinse cycle it takes about 45 minutes to fill.The water barely trickles in.The machine also makes a buzzing sound when it gets to that cycle.Do you think this may be a controler problem?? If it where the valve or screens it wouldn't fill normal in the wash cycle, Would it??If it is a control problem what part would I need to replace the whole controller??Dial assembly?? my Kensmore toploader is having the same problem. Fills fine on the initial wash cycle but on the rinse cycle it barely trickles.
  • RaySl Oct 07, 2008
    Top load 70 Series washer Model 110.82870120 that fills properly during wash cycle and drains. During rinse cycle it fills very very slowly and does not seem to want to spin to drain when cycle is advanced (it was filling so slowly for rinse) that I had to go through wash cycle to get rid of soap to allow removal of soap to dry cloths (going on a business trip). The answer to the original post sounds the same but the solution was not very clear - other than to check the screens of inlet hose to washing machine but this does NOT explain why the wash cycle fills properly ??
  • dave goss Jun 04, 2013
    this is not my question how do i get my questio on
  • 1,028 Answers
Ck and clean screens first both sides be sure hoses are not reversed timer has no affect on fill rate if screens are clean replace valve
Posted on Sep 20, 2008
Kenmore 70 series washer
If you can see a constant water pressure from the hot and cold, chances are the water solenoid valves are ok.
I would look towards resetting to factory and checking the main control unit.
May 11, 2014 | Washing Machines
WDSR2120J washer will not fill in rinse cycle
possible 3 solutions for this problem 1 could be the cold fill solenoid 2 could be brushes in motor 3 could be main pcb
Feb 20, 2013 | Washing Machines
Not getting enough water during rinse cycle
In the rinse cycle it will use cold only to rinse with.
You need to see how fast the water is going into the machine on rinse
Things that can effect slow fill, low water pressure, Faulty cold valve
water hose & valve filters clogged, Kinked hose
Feb 21, 2012 | Fisher and Paykel IWL12 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Cold water is slow when filling for rinse cycle
Turn off the cold water.
Remove the cold water hose from the machine.
Look inside the cold water inlet on the machine and clean the debris from the screen.
Problem solved.
Feb 22, 2009 | GE WJRR4170E Top Load Washer
Cold water will not stop filling during rinse
while the unit is filling in the warm cycle. reach behind and shut off the hot water tap.I bet the water flow stops filling, if so, you would need to change the inlet valve on the machine. You see, in warm, if the cold is not filling, you still hear the hot filling and the unit will advance. The rinse cycles are mostly "cold" only. if the valve is not opening it will not allow it to advance from the rinse section on the board.
Feb 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Need a model # to get exact part you will need at rinse most washer go straight cold so I would say water inlet valve if humming sound is present
Apr 28, 2017 | GE WBSR3140DW Top Load Washer
Washer won't fill in rinse cycle
Oct 19, 2008 | Maytag Washing Machines
Does Not Rinse
Check each temperature during initial wash fill. Set to hot water, is hot water coming out? Set to cold water, is cold water coming out? The rinse cycle is cold only. If cold water is not working machine will just stop at rinse.
If cold water not working:
Disconnect cold water hose from machine. Inspect the filter screen on the cold water connection. DO NOT REMOVE SCREEN. If full of debris, use a spray bottle with a hard spray to remove debris. If unable to remove or cold is still not working, replace valve.
Jun 14, 2008 | Whirlpool LSR6332K Top Load Washer
The first thing I would do is remove the hoses from the inlet valve and make sure the screens are not clogged in the valve. On some models the valve will compensate on fill opening both hot and cold. It will not do this on cold rinse. Before ordering any controls check this out first. If it's still the same I tend to believe it's a valve problem. The buzzing you are hearing is the valve. Catriver, post back.
Aug 06, 2006 | Whirlpool LSQ9600L Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
730 people viewed this question
Sal De
 Brian Main
Brian Main
