Question about Whirlpool Refrigerators
Water is going to the in-door water dispenser, but not to the icemaker
  • 200 Answers
Check this link
Thank you
Posted on Sep 19, 2008
Water will not stop flowing in to icemaker
Dirt in body of icemaker water supply valve. OR. Ice maker timer stuck when it selected "add water to icemaker.
The first solution is simple, change icemaker water filter and disassimble valve to clean.
The second is simple, buy a new icemaker.
May 15, 2012 | LG LFC25760ST 25 Cu. Ft. Panorama French...
The water isnt getting thru to the icemaker, i have used a hairdryer on the water valve and still nothing , i even changed out the water valve but alas no water is being pumped thru to the icemaker, what...
Does water dispense through the dispenser ok in the door dispenser??
If yes wate r dispenses through the door ok the problem is going to be with the icemaker itself and its not sending power to the water valve when its supposed to fill so it could make the ice
If water doesnt dispense through the door check that water pressure into valve is sufficent..even if water does dispense what seems to be ok check first that thier is good water pressure into the valve before replacing icemaker
Sep 11, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
The water dispenser the ice dispenser etc one the left door is not be working that whole unit seems to be dead.
Highly unlikely both valves failed at same time. Not sureon your fridge but on some, if freezer door switch is not working, dispenserwon't work. Does the freezer light go off & on when door is opened &closed? If you have a voltmeter, check that water valve is getting 120 voltswhen dispenser is pushed in. If no voltage, I would suspect the micro-switchthat you hear clicking when you push in with a glass. Even though it clicks,the contacts could still be bad in it. If the icemaker is not gettingwater, check for the following problems:
  • Be sure that the icemaker is turned on and plugged in. The power cord for your icemaker is plugged into the left or back wall of the freezer.
  • Check to make sure that the water supply line valve is turned on. This valve is usually found under the sink or in the basement. This is the only water supply line needed for the refrigerator.
  • Be sure that the freezer has cooled down properly after the initial installation. This may take several hours.
  • Make sure the plastic fill line on the icemaker has not come out of the back of the icemaker.
  • Check the fill tube (plastic tube above the icemaker) going into the icemaker. In order to do this, the icemaker must be removed. If the tube is frozen solid, you will most likely need a new water valve.
If the ice-maker is getting water, but there is no water tothe dispenser, check for the following:
  • If the doors were removed during installation, be sure that the door wiring harness is plugged in. Refer to your Owner's Manual/Installation Instructions for the specific location of the wiring harness.
  • Check the water lines and make sure they are not kinked or restricted.
  • There is a tank behind the vegetable drawers or on the left side of the Fresh Food compartment that could be frozen. You may be getting water in the ice-maker, but not the dispenser. To rid the tank of the ice, check the set temperature on your controls. If it is set colder than the recommended setting, adjust to a warmer setting.
Hope this will help you. Good Luck.
Jul 20, 2011 | GE Profile PSI23NCR Side by Side...
My refrigerator water dispenser is not working. I
In the back of the refrigerator there is a water inlet valve. It will have three hoses one coming in, two going out. A 1/4 line for the icemaker and a 5/16" for the water dispenser. If your icemaker is working and you dont have water at the door the valve to the water dispenser is faulty, you need to replace the water inlet valve. If neither icemaker or water dispenser is working chek your water supply line
Feb 22, 2010 | Refrigerators
Icemaker works but water doesn't dispense. I have
I think our water will dispense but our tab(arm) came off track and we don't know how to put it back on. Our icemaker works fine but can't see how the arm should be on. Let me know if you have any advice. Thanks, Shelby ~ Ohio
Feb 14, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
No water going in the ice maker but water dispener
Pour about 2/3 cup of water into icemaker . If it freezes and does not dump , replace the icemaker . Check to make sure the coils are clean of dust , lint , pet hair , etc . If it does dump , and does not refill with water , replace the water inlet valve ( piece behind refrig where the wall water line connects to on the fridge ) . Check to make sure the fill tube that fills the icemaker is not blocked with ice , still indicating a bad water inlet valve ( slow seep ) .
Aug 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker not working, but water dispenser is
Water valve has separate coils for water to door and to icemaker. If icemaker is cycling the valve is likely the problem.
May 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The icemaker stop working on my Whirlpool side by side frig
If there are ice cubes setting in the icemake waiting to be dumped then the icemaker is bad. If the icemake is dry then the water valve is bad. You have one water valve with two solenoids. One works water in the door and the other sends water to the icemaker.
Dec 15, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
42 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
