Question about Panasonic Panafax UF-885 Plain Paper Laser Fax
Panasonic copier/fax UF 885
I'm getting error code Opt 02 - what does this mean, and how can I fix it? I can neither send nor receive faxes.
    Genius:
  • 2,120 Answers
It sounds like you are stuck in the boot-up mode.
Try this:
Open the toner door and remove the cartridge
Turn the machine off
Open the document feeder by pulling straight up
While turning the machine back on, hold down the pointed switch actuator closest to the small glass
Close the document feeder..display should read "RAM INITIALIZE"
Scroll down to "SHIPMENT SET"
Press "SET"
Press "2" for "NO"
Wait for the machine to reboot (could take 5 mins)
Some times a bad toner cartridge will cause this.
If this does not work, you have a bad Main PC Board. Uneconomical to repair.
Posted on Sep 19, 2008
Info Code 060 on our Panafax UF 885
Code 060 means that the toner door is open. Check the switches.
You might have to tape the door closed on the rear side or call a technician to replace the door.
Nov 25, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
The fax doesn't want to scan or send a fax
Pull straight up on the operation panel to see if paper is stuck in the feeder and that all switches move freely. Any error codes?
Jun 15, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Panafax UF 885 replace battery
Turn the machine off for 10 seconds.
If the display shows 00% there is nothing in memory.
Apr 20, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
What does the code mean? How do I fix it?
051 means the printer motor is abnormal. I would try replacing the toner cart then switch off/on in the first instance.
Apr 14, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Fax machine error code 021
If a new toner cartridge doesn't take care of it, replace the fuser.
Apr 07, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Panafax UF-885 - Error Code 055
Error 055 is a laser error. the laser is not spinning at the proper speed and may need replacement. There is another solution, where some ferrite cores are added around three cables to reduce electronic interference. Best call a local technician for further diagnosis.
Mar 25, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
UF-585 (AU) OPT is showing on the screen...can't send or rec faxe
Open the toner door
press
function
7
monitor key slowly 4 times
6
scroll down to SHIPMENT SET
set
set
wait for machine to reboot
Jan 29, 2009 | Panasonic Panafax UF-585 Plain Paper Laser...
UF-885 Panafax
Unplug the power cord in the rear of the machine
Open the document feeder by pulling it straight up
hold down the pointed switch by the scanner glass while plugging the machine back in until you hear a beep
close the document feeder
press SET or START
press 2
wait for the machine to reboot.
Dec 30, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Unknown Code
What make and model of fa machine are you reffering to? Cops
Oct 08, 2007 | Panasonic Panafax UF-885 Plain Paper Laser...
I can neither send or receive faxes
hi 003 - Recording paper jammed when feeding from the 3rd cassette. Remove the jammed paper. (1) Open the Printer Cover. (2) Remove the jammed paper. (3) Slide out the Paper Cassette. (4) Remove the jammed or wrinkled paper and reload the recording paper into the paper cassette. Caution: Make sure that the paper is set under the clips of the Paper Cassette. You can load about 500 sheets with standard weight paper (20 lb. or 75 g/m2). good luck
Feb 23, 2006 | Panasonic Panafax UF-885 Plain Paper Laser...
Panasonic Panafax UF-885 Plain Paper Laser Fax Logo
107 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
