Question about Lexmark X4270 All-In-One InkJet Printer
Ink where is the ink located
I think it is model X4270 since we're in that category. I have the same problem?
Posted on Sep 20, 2008
    Sergeant:
    Champion:
  • 200 Answers
Hi
Can tell me ur model no and product name, so that i can help u..
Thank you
Posted on Sep 19, 2008
Where is the ink absorber located on my pixma mx410
I don't have a Pixma printer but the ink absorbers are usually located at the right side if the printer just under the print heads. This is the area used by the printer to clean the print heads. My guess is that more of the ink used by a printer ends up here instead of of be ing used for printing. There is good information on youtube. See Link
Canon Pixma MX410 ink asorber YouTube
Jul 31, 2014 | Canon Pixma MX410 All-In-One Printer
ERROR 09,038,46:11950
Fault codes associated when ink count flags are stuck after melting 2.5 ink sticks.(Black ink)
1. Are the ink sticks all Xerox ink? Are they the correct ink sticks for the printer model?
Yes)Go to Step 2.
No)Advise customer. Run clear ISC Fault test to clear the error. The clear ISC fault menu item is located in the internal diagnostics function menu. This must be performed following an ink loader replacement.
2. Manually verify that the ink stick is able to advance in the ink loader chute. Check for broken or wrong type ink sticks.
Yes)Go to Step 3.
No) Remove any blockage and/or replace the ink stick. Run clear ISC Fault test to clear the error. The clear ISC fault menu item is located in the internal diagnostics function menu.
3.Run the appropriate Ink Melt [1, 2, 3, 4]
Heater test.
1 = Yellow
2 = Cyan
3 = Magenta
4 = Black
Did the test pass?
Yes)Replace the printhead.
No) Replace the ink loader assembly. Run clear ISC fault test to clear the error. The clear ISC Fault menu item is located in the internal diagnostics function menu. This must be performed following an ink loader replacement.
Sep 02, 2011 | Xerox Phaser 8500/DN Printer
Ink absorber is almost full.What do we do next ?
You have not mentioned which brand/model is your printer. I take it as Canon. You have two options:
1 If the ink absorber is full you have to replace it. Getting it serviced is not a good option as it costs the same. It is normal wear and tear and not a defect.
2 If you know how to open the printer, you can do it yourself. Then open it and locate the waste ink pads which are on the right hand side. They are small in size. Not difficult to locate. You can remove the pads and the holder with a gentle pull. Using a tissue, soak up as much ink as possible and clean the area around the waste ink area.
  1. Locate the Waste Ink Pads on the inside of your printer. They are on the right hand side and are quite small.
  2. 4You can remove the pads and the holder with a gentle pull.
  3. 5Using a tissue, soak up as much ink as possible and clean the area around the waste ink area.
May 11, 2011 | Office Equipment & Supplies
I whant to refill pixma canon ip2700 with black ink but dond now how
Color Cartridge 1. Place the cartridge over somepaper towels in case there are any spills.Remove the label sticker from the topof the color cartridge. 2. Drill into the three small holeson the top of the cartridge to widen them so they will allow syringe needles. 3. Fill a syringe with 6 mL ofmagenta ink. Insert the needle into the refill hole that is located below thetwo protruding rectangles on the top of the cartridge. Slowly inject the ink. 4. Fill a syringe with 6 mL of cyanink. Insert the needle into the refill hole located below the large rectangleon the top of the cartridge. Slowly inject the ink into the cartridge. 5. Fill a syringe with 6 mL of yellowink. Insert the needle into the refill hole located below the small rectangleon the top of the cartridge. Slowly inject the ink into the ink chamber. 6. Replace the cartridge into theMX310 printer. Black Cartridge 1. Set the cartridge on some paper towels. 2. Drill a hole into the dimplelocated directly above the semicircle on the top of the cartridge.Fill asyringe with 20 mL of black ink. Insert the needle into the hole and slowlyinject the ink. 3. Replace the cartridge into theCanon MX310.
Nov 28, 2010 | Canon PIXMA MX310 All-In-One Printer
Where is ink cartridge located on mp 620
Look at the front, the ink cartridge cover is at the bottom right corner. Need to flip open to remove the cartridge
Apr 18, 2010 | Office Equipment & Supplies
Waste ink absorber is full, printer won't print
Clean it! All you need is a lot of tissue or toilet paper. Locate the sponge (it's usually located where the cartridges are when they're not printing). Try cleaning all the dried ink and blobs of ink.
Hope that helps!
Mar 04, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Need to change ink don't know where ink is located
this is the complete Manuel INCLUDING how to put/change the ink cartridges and diagrams so you know where it is--- http://h10032.www1.hp.com/ctg/Manual/c00461370.pdf
May 06, 2009 | HP Officejet 5610 All-In-One InkJet...
Cannot locate ink catridge for HP PSC 750 printer
With power on, simply lift up from the hatch located on the front of the unit. The ink jet will slide to the middle position.
Mar 27, 2009 | HP PSC 750 All-In-One InkJet Printer
The ink carthridge location
how do I get to the ink cartridge on a hp 5510 all-in one?
Feb 15, 2008 | HP Officejet 5510 All-In-One Thermal...
Lexmark X4270 All-In-One InkJet Printer Logo
16 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
