Question about RCA 3-Device Universal Remote
Help RCA 6-Device Infrared Universal Remote [DBRCR6473 i need the codes for a sonyo
    Sergeant:
    Champion:
  • 200 Answers
Hi
The code for Sanyo TV from a Phillips Universal Remote is 0181.
If 0181 doesn't work,try 0506. I have a Sanyo tv and hopefully that'll work for you.
Try one of these
017,021,039,056,057,058,
0154, 1907
Check this website also
http://www.remotecodelist.com/remotes/ge/RM24912_codes.pdf
Posted on Sep 19, 2008
Where can I get the code sheet for this remote?
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Jul 30, 2015 | RCA RCR6473R 6-Device Infrared Universal...
Tip
RCA Universal Remote Code Search Models RCR312W - RCR311BN - RCR311BIN RCR311SN...
RCR311SN - RCR311STN
To setup your RCA Universal Remote Control with your TV or other devices, you can perform a code search. A code search tries to turn your set off with different brands' remote control codes until it finds one that works with your set.
Here are the steps for an RCA Universal Remote Control Code Search:
  1. Turn on the device you would like to control.
  2. Press and hold the device key (TV for example).
  3. While holding the TV key, use your other hand to press and hold the ON/OFF key.
  4. Wait until the ON/OFF key light comes on and stays on, then release both keys.
  5. Point the remote at the front of the TV and press PLAY.
  6. Wait 6 seconds while the remote sends a batch of 10 codes to your TV. If your device turned off, go ahead to the next step. If the device did not turn off, press play again and wait 6 seconds again.
  7. When your device turns off, press the REVERSE key on the remote and wait 2 seconds. If the device turns back on, press STOP and your remote is now successfully programmed for controlling that device. If the device does not turn back on, keep pressing REVERSE every 2 seconds until your device turns back on. When it does, press STOP.
I hope that helps.
on Apr 07, 2010 | RCA Universal Remote Control
Naxa remote control code with RCA remote
You will need the name serial no. of the unit and you have to look up and match it to the re-mote should be instructions with the remote.
Aug 26, 2014 | RCA RCR612 Universal remote control,...
Needs codes rca remote
I'm not sure which remote and device you have. The header says a GE remote and the text says RCA remote. I'll provide locations for both types of remotes.
Try the following web site: http://remotefinder.rca.com/default.aspx?site=rca for RCA universal remotes. Enter the model of the remote as well as the brand and type of device to be controlled.
GE Universal remotes use either a three or four digit code. Find the code lists here: http://www.jascoproducts.com/support/universal-remote-codes.asp . Then determine if you have #24912 remote or which of the remote code lists that applies to your remote.
The code lists for any given remote will be limited to codes for devices released 6 months or more before the universal remote was programmed. If your device is newer than that date, the codes may not work.
I hope this helps.
Nov 20, 2010 | Universal Remote Control GE174Universal...
I have a rca remote controle and i need the code for hitachi tv
I tried to include any info you might need. The first of which are the Hitachi TV codes. The first list is for the 6-Device RCA remote pictured with your post. Since there are a few different 6-Device models I also included a list of those.
Below that are three links. The first is for the manual for the 6-Device RCA remote model #RCR6473N. Next is the codes for the same model.
Finally (just in case that's not your model), a link to RCA remote control support page.
Sorry I couldn't get you the kitchen sink. ":}
Hope this helps.
11643, 11145, 10145, 10056, 10096.
009, 011, 027, 036, 037
http://audiovox2.info/docs/rca_acc/man/RCR6473N_DOC_OM.PDF
http://audiovox2.info/docs/rca_acc/man/RCR6473N_DOC_OTHER.PDF
http://66.77.167.109/rcaaccessories/RcaaccessoriesController.do?ACTION_TYPE_ID=ACTION_TYPE_CATEGORY&ACTION_CATEGORY_ID=STR_CATEGORY_UNIVERSAL_REMOTES
Nov 19, 2009 | RCA 6-Device Universal Remote
Need programming methods and codes for sony tv
Have a look around in this site; http://remotes.com/store/codes_original.html let me know if it helps
May 11, 2009 | Televison & Video
Listed code for my Memorex DVD/VCR not working
I HAVE RCA RCA312W TV AND I NEDD THA CODE TO PROGRAN A SONYO TV
Jan 16, 2009 | RCA Universal Remote Control
Code set problem
make sure your tv is and Infrared tv.. if it is there is a chance that the remote just doesn't have the capability to program to it. you should first try getting your original remote control as http://www.replacementremotes.com has many older and hard to find remote controls for RCA TVs.
Aug 19, 2008 | RCA 3-Device Universal Remote with...
Remote problems
Assuming the Directtv system is Infrared and not UHF.... Try using the remote's "Code Search" feature.
Hope that helped...
Geno
Apr 02, 2008 | RCA Universal Remote 3 Device Remote...
RCA 3-Device Universal Remote Logo
133 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
