Question about Ricoh Aficio GX3050 GelSprinter
Ricoh GX3050N printer - not printing...
We just changed all with original cartridges and the printer is just not printing...the paper rolls and I hear the sound like it is printing...but its all blank pages...
what could be the problem...any help is much appreciated.
Regards,
Dan.
  • InkIT Feb 19, 2010
    Does any one has the procedures to take out the print head? And how to clean it?
Could be that the heads are blocked !! try to make the maintenance procedure head cleaning and head flushing from the printer or from the pc select the printer and go to the printing preferences and select maintenance and continue from there and try ,if it does nt solve the problem try to clean the head manually with a soft cloth or there are special cloths for the heads .
Posted on Aug 27, 2009
  • 46 Answers
If you're good at taking things appart clean the print head. Theses machines are known for drying up. But you may get away by doing a head flushing.
1. Press [menu]
2. Scroll down to [Maintenance] then press enter [#]
3. Scroll down to [Head Flushing], press enter[#]
4. I'm not sure about this part but ensure that you flush each head and then test print. If it is still blank or partially blank repeat steps.
The best would be to clean the print head with a damp cloth.
3.
Posted on Aug 28, 2009
Color Laser Printer Pink Tint
have you tried cleaning the charging wire and the transfer belt
Feb 17, 2014 | Ricoh Aficio SP C420DN Laser Printer
Ricoh 3000dn
1. The cover is open.
• Close the cover.
2. No paper in the tray
• Load paper in the tray.
3. The printer has stopped printing due to a major error.
4. The print cartridge is not installed.
• Install the print cartridge.
5. The life of the print cartridge.
• Replace the print cartridge
Apr 15, 2013 | Ricoh Aficio Sp 3300DN Laser Printer
After printer said ink cartridge was empty I removed it & found it was not-I put it back in printer & now getting error message that the cartridge is used & needs to be replaced. How can I
your only option it to replace it with a new one . printer mfg's have chipped the cartridges and they can not be reused.unless the chip is recoded as new .
Aug 16, 2017 | Ricoh Aficio GX3050N Printer
Changed black cartridge now getting a 990 error
  • Remove options and try again (NOTE: when removing the Postscript board, you must replace the 2 IBM ROMs)
  • If the printer now works, replace options one at a time to test them
  • Replace system board
  • Defective system board
  • Mar 24, 2010 | Ricoh Aficio GX3050N Printer
    Ricoh Aficio GX3050 Gel sprinter - error999
    BULLETIN NUMBER: J001/J003/J006/J007/J010/J011 – 021 07/02/2008
    APPLICABLE MODEL:
    GESTETNER – GX3000/GX3050n/GX5050n
    LANIER – GX3000/GX3050n/GX5050n
    RICOH – GX3000/GX3050n/GX5050n
    SAVIN – GX3000/GX3050n/GX5050n
    SUBJECT: SC999 OCCURS
    SYMPTOM:
    An SC999 (Maintenance Stepper Motor Home Position Error) occurs.
    CAUSE:
    Some of the ink in the machine has dried, and as a result the maintenance stopper motor cannot rotate or
    the levers come loose.
    NOTE: The following conditions make it easy for the ink to dry up (See Appendix 3 for more details):
    - Low humidity
    - Long intervals between machine usage
    - Total period of usage is long
    - Low Print Volume
     COPY QUALITY
    Fixed ink Stepper Motor
    Right Flushing Gate
    Levers
    Tech Service Bulletin No. J001/J003/J006/J007/J010/J011 – 021
    Page 2 of 5
    SOLUTION:
    Production Countermeasure:
    The shapes of some parts in the Maintenance Unit have been changed in two steps ("Step 1" and "Step 2"
    below).
    NOTE:
    See Appendix 1 for the details of the Step 1 and Step 2 modifications.
    See Appendix 2 for the visual differences among the unmodified unit, the Step 1-modified unit, and
    Step 2-modified unit.
    See UNITS AFFECTED for the Serial Number cut-in of Steps 1 and 2.
    Field Countermeasure:
    1. Cycle power OFF/ON.
    2. Install one of the modified Maintenance Units ("Step 1" or "Step 2").
    NOTE: For customers experiencing a SC999, have them contact 1-800 Ricoh38 for replacement.
    Feb 02, 2010 | Ricoh Aficio GX3050 GelSprinter
    Ricoh CL2000 SC486
    it is the problem your cartridge sensor chip.You change cartridge unite & buy new cartridge than solve it
    May 30, 2009 | Ricoh Aficio CL2000N Laser Printer
    RICOH GX3050N and Windows Vista
    You can find the driver on the Ricoh site. here is the link:
    http://www.ricoh.com.sg/downloads/drivers1.aspx?path=http://support.ricoh.com/bb/html/dr_ut_e/ra/model/gx305/gx305en.htm
    Mar 14, 2009 | Ricoh Aficio GX3050 GelSprinter
    Ricoh Aficio GX3050 GelSprinter Logo
    733 people viewed this question
    Top Ricoh Office Equipment & Supplies Experts
    Adorjani Laszlo
    quennie732
    fares
    Level 1 Expert
    Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
