Question about Xerox Phaser 8560MFP Laser Printer
We are having a error code 09.038.46:13190 --> does anybody know what it is? We called the support, but they didn#t know and we need the printer urgently and can hardly wait for them to pass by. Thanks
  • anothername Sep 20, 2008
    Perfekt help! We took out the black ink and found some cracks and deformations on it. After replacing it the printer worked as usual :-)
    Guru, thank you for the help
  • home609
    home609 Feb 16, 2012
    It takes a while but with an allen it works.
  • 2,072 Answers
The black ink sticks are not advancing down into the ink loader properly; Either one is cracked or twisted.
If you have to remove one, use a screw, like a dry wall screw and twist it into the block and back it out.
Posted on Sep 20, 2008
  • Rick Kasper Sep 20, 2008
    You are welcome. Glad to be able to help.
03130031-2F52 error
my printer suddenly stopped working and is showing the following error code 03130031-2F52. If anybody know how to fix it, please email me at thank you.
Oct 21, 2012 | Canon imagePROGRAF iPF8000 Printer
My 2135cn dell printer has a code 062-371 system. Anybody know what this is?
I've had the same error with a Dell 3115CN. I've called Dell and they told me that the cause of the problem lays in the scanner-lock. Underneath the scannerlid is a grey lock-button wich parks the scannerlamp. This button seems very sensitive. Just lock and unlock and the problem should be solved.
Feb 07, 2012 | Dell 2135cn All-In-One Laser Printer
Enter UI Diagnostic(hold 0-zero for 6 seconds and press Start button, find Diagnostic) in dC355 Hard Disk Diag Program and make a diagnostics of HDD. Refer to Initialize Hard Disk procedure in UI diagnostic <!-- from fixya rte -->
May 21, 2010 | Xerox DocuColor 12 Printer
Konica Minolta Magicolor5440DL Error Code
error 0094h = 2nd image transfer pressure/retraction failure
basically it means that either a sensor or cable is not fitted supposedly and reseating could possibly solve the issue.
you can research the error code in the following service manual:
Mar 09, 2010 | Konica Minolta magicolor 5440 DL Laser...
Error code 14-372
Check connectors on halftone pwb if ok, then replace Halftone PWB
Sep 22, 2009 | Xerox DocuColor 12 Printer
Error sc 547
Found this from:
Ricoh CL4000DN Error Code SC542
Turns out error SC542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won’t come ready until the prior error condition is cleared.
A few phone calls with our local Ricoh service rep, and he admitted that the printer might trip this error in a power brownout.
The printer was less than 30 days old and the error was caused by the brownout or the fuser failed. I kept calling the Ricoh rep, and they finally gave me the magic keystrokes over the phone.
I did the magic keystrokes, cleared the error code, and the printer worked fine. It’s been working great for a year now.
I hope someone else who has this problem finds this page and is able to fix the problem also. I didn’t find any help on the net when I searched.
The Fix In order to clear error SC542, you must perform procedure 5810.
  • Press and hold online + escape, then power on.
  • Use up and down arrow keys to select SP2
  • Press Enter
  • Use up and down arror to locate SP5
  • Press Enter
  • Use up and down arrow keys to select 810
  • Press Enter
  • Confirm the selection
  • Power off and on.
The error code is now cleared.
Hope this helps!
Jul 17, 2009 | Ricoh CL4000DN Laser Printer
C6400 error code km1635
you have a fuser problem, burnt out heater lamp needs to be replaced. call service representative for parts
Mar 17, 2009 | Office Equipment & Supplies
Xerox Phaser 8560MFP Laser Printer Logo
727 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
