RCA D52W23 Color Alignment. Blue,Red,and
RCA D52W23 HDTV Color Alignment. Blue,Red,and Green are shifted. The center of the picture bends inward.
  • 1 more comment
  • jacksonfarms Sep 19, 2008
    The picture is still centered, but the colors don't line up. The top of the picture dips down and there are lines across it.
  • jacksonfarms Sep 25, 2008
    Replaced the whole convergence amp board did not fix anything.
  • jacksonfarms Sep 29, 2008
    Replaced convergence amp board and convergence power supply still not working. Is there a service menu and how do you get to it?
    Scholar:
  • 148 Answers
Look for bad stk's on convergence module. This may take care of pincushion too.
Posted on Sep 30, 2008
    Novelist:
    Champion:
  • 203 Answers
If the convergence amp board didnt solve your problem then you most likely have a bad convergence power board. The board to the left of the convergence amp board should be changed at this point. But if you know how to use a meter we can verify this by checking some voltages, or you can just order it and put it in. Let me know what you want to do!
Tim Nolan
Posted on Sep 25, 2008
    President:
  • 1,952 Answers
This is usually due to a convergence problem. Due to its history, there may be some bad connections. Even in dry storage, it was probably subjected to temperature changes. Try resoldering the convergence ICs first. Update this with the results. In the meantime, I'll look into this particular model for other suspect areas
There is a problem with the tuner. The replacement cost of the tuner wouldn't be worth it. You can try looking for bad connections in that area or check the power supply to be sure the tuner is being fed correctly. At this point, I'd say spend the money on a new set.
Posted on Sep 19, 2008
  • 10,594 Answers
Its problem of convergence board and need to be replaced. You can buy this board at Part Store.
Please replace the board if you have basic electronics knowledge or get help of tech person.
Regards,
PICTURE IS BOWING INWARD AND THE COLOR . LIKE PERSON FACE IT WILL HAVE A SHADOW OF RED, BLUE, GREEN, YELLOW
Tv have a problems known as a convergence problems,it dead.Colors lines R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts are dead,must be replaced on the tv convergence board to repair the convergence problems.The shop,will cost u $300,350 for parts and labors.
Sep 14, 2010 | RCA HD52W58 52" TV
A red blue and green line comes across both the top and bottom of my tv . alignment is also off
Sounds like the classic convergence option symptom. If you press menu and scroll to the set up screen see if the auto convergence feature is still listed. If its no longer there the rca repair kit called ITC222 and ITC222A convergence option missing repair kit from www.tvrepairworld.com will usually repair that problem. The kit contains the parts and the CD with repair instructions.
Aug 03, 2010 | RCA D52W23 52" HDTV CRT TV
RCA 52 HDTV Triple iamges in red, blue and green
I had the same problem with my RCA D52W23. I change out the convergence board and the 2nd fuse the one near the flyback. After getting TV back together picture was good except white backgrounds looked washed out with greenest at the edges. I called cable company and they came out fixed my cable line with was dropping and gave me a new HDTV box which was the newest one. That fixed my problems.
Apr 28, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Letters and numbers are 3d and curved picture
Hello
red, green, and blue lines curve across the top of tv is cause by defective convergence STK IC or you have open resistor at convergence section. if you have defective RGB Color vertical ramp probably you have defective STK IC..
Angel
Thanks...
Aug 02, 2009 | RCA D52W23 52" HDTV CRT TV
Rca d52w23 hdtv will not turn on
unplug it for about 10 minutes and then plug it in and try it
Jan 19, 2009 | RCA HD50LPW175 50" HDTV
RCA d52w23 shows pictures in triplicate:blue green and red.
There are several things that can cause this. There is a "light pipe" that connects from the lamp to the color wheel. If the mirrors inside have become dirty, broken, or have shifted it will cause the picture to do this. Also the color wheel itslef could be dirty or worn out. And the final culprit could be the light engine itself. You can have any in home TV tech test these out for you.
Jan 06, 2009 | RCA D52W23 52" HDTV CRT TV
RCA Rear projection had a 3-d like picture. one red one blue and
Go to menu then setup if you do not see convergence on menu then FL231 is open replace it then do auto convergence.
Jan 02, 2009 | RCA D52W23 52" HDTV CRT TV
Hitachi big screen tv
Convergence IC's bad==replace and then
re-check alignment
Oct 16, 2007 | Hitachi 46F500 46" Rear Projection...
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
Electro Med Services...
