Question about Kenwood KAC-7202 Car Audio Amplifier
Amp powers up (switchable) but has absolutely no output
Just currently bought this amp used, was told "works" but upon recieving it, it obviously doesn't.
Amp powers up best I can tell, light comes on strong and steady, cooling fan turns fast.....yet no output.
Have tried 2 different signal sources and still nothing. RCA feed lines are new and functional.....sub cabinet is new and functional.
Any suggestions?
Have Kenwood KDC 10-22 reciever/cd , doesn't seem to have RCA output as well. Any suggestions?
  • 21 more comments
  • Cursedknight Sep 20, 2008
    If possible, I'd like to do any and all repairs myself.
    Upon further reading through other posts, the LED is on, but it's red, I'm thinking that it's going into protect mode right away....doesn't blink or fade, just solid red....continuously.
    Being a Kenwood, should it be red or not?
    I've checked the shield ground on the HU at it checks out good at .5 ohm.
    What about the head unit?
    It has proper grounding at the rca's but still has no output.
    Ok, a bit of a headfull and a long read......but I've checked the page for possible leads as to why there's still a red light.
    I checked for shield ground on the RCA inputs and get nothing at all.
    Haven't opened the amp case as of yet............
    I've also checked the power suppliy at both B+ and remote terminals. Both above 13.4 V.
    Ground wire is 8g and has 0 resistance between terminal and battery post.
    All fuses are intact and functional...
    Tried all combinations of disconnecting speaker and RCA, no results.
    (With power applied)
    Have roughly 2 ohms of resistance between the Grd Term. and neg speaker output.
    Have 0v between Grd Term and RCA ground shield(s)
    Troubleshooter advises that the possibility of "shorted output transistors" is LIKELY.
  • Cursedknight Sep 21, 2008
    If I use the Ohm setting on my multi-meter I get no reaction at all....the meter doesn't change (and yes I tested probe contact reading first)
    If using the Ohm meter, it would indicate that ALL OpT's are in need of changing..... ?!?!?!?!
    If I use the Diode test setting, everything checks out fine....all pins (legs) have variable readings but nothing near 0.....actually all above 510....
    My OpT's range from a Q220-Q229..... which differs from what you said there would be. (barely, but still) some of which the probe leads have to be reversed to get similar readings...but similar readings none the less (FET's <> EFT's)?
    Ok, did I make any sense with any of that?
    OK, now.....after testing the OpT's and some cleaning of dust and or debris..... I re-checked the shield grounding of the RCA inputs, and they now show a 1.19 v test........
    I didn't take anything apart other than the case....... Maybe I didn't get a proper reading the first time?
    I'll check the Power supply transistors........as advised....
    All tested at like values of 0.00...... ocassionally the meter would flash a - but never showed anything other than 0.00 (in diode test mode)
  • Cursedknight Sep 22, 2008
    Would it be feasable that all 8 of them would be defective....or go "bad" all at the same time?
    Being that they're all showing the same values?
    What's the likely parts cost of 8 power supply transistors?
    Is it a simple enough repair for a "novice" to successfully complete?
    I'm no rocket scientist but I have been known to weild a soldering iron from time to time.
    Any special precautions I shuld take when removing them?
    I know a de-soldering pump and Braid are a must, but what about any other necessities?
    N'hey.....thanks a heck of alot in advance!
    Well.... "guru"....
    I've gotten all of the power supply transistors removed, the board clean and all testing done.
    1st : ALL of the PsT's are showing nothing....as in open or broken circuit
    2nd : all of the solder pads (at pins 1 and 2) are reading around 8.3v - 8.5v...
    is this good, or bad?
    And what's next?
    Obviously I need to get the PsT's..... but does the voltage difference indicate a need for more testing and parts? :(
    I did get the board nicely cleaned and relatively solder free, making sure there are no crossed circuits.
    Ok, my mistake.....I wrote a bunch of it down and read some of it wrong when posting it here.......
    I feel pretty lame right now!
    All pads are reading at 4.3v - 4.5v.....
    This would seem to be a good thing, no?
    they read as if the leads aren't touching anything
    with the tester on Diode check.....those same pads, in the same order and sequence, show 1413 - 1417
    v?
    I couldn't tell you why it's reading differently.
    Everything prior to removing the power supply transistors was in it's original factory condition as far as I could tell.
    Should the power up LED be red for this model, or should it be a different color?
    "No individual transistor should read near 0 ohms between any if its legs. If you find any that read near 0 ohms, you need to remove them so you can check them out of the circuit."
    Which is it? ohms or volts?
    I've been using the diode test mode for all of the transistor testing, and dcv to test the pads.
    I'm gonna pull 4 of the output transistors to test them off the board now.
    ok, if what you say about testing pin (red) 1-2 (black).... and so on is to be taken as gospel ..... out of the board, the four that I had suspicion of aren't showing any values.
    If I reverse the polarity (red to pin 3) I only get current through to pin 1 and not 2
    Their board placements are : Q222, Q225, Q226 & Q229
    Three of the parts are marked : A1694
    48 P
    And the fourth is marked: A1694
    48 Y
    There is a local Electronics supply store (that's NOT Radio Shack) that distributes nationally, should I just take the parts with me? and are these a fairly common part that should be stocked?
    I do think that these are the problem.
    the 1st diagram shows red lead to pin 1, black lead to pins 2&3 stating that readings should be between 0.5 & 0.7 v
    In this configuration, all four show as if leads not touching.
    the 2nd diagram shows black lead to pin 1, red lead to pins 2&3 stating that there should be NO current
    the 3rd diagram shows black lead to pin 2, red lead to pin 3 and vice versa, stating there should also be NO current
    I'm taking it that these are PNP as opposed to NPN
    You're the guru, I'll re-install them and try to get it to power up...
    I gathered that much from the emitter and collector diagram
    I tried to convert the images to .jpg but for some reason this computer wouldn't let me. So they're in a Microsoft Document Image file
    alright I'm going to re-install all of the parts and try to get it to power up
    done and done....
    powers up like it did before, but no change in output signal
  • Cursedknight Oct 03, 2008
    Perry, please!
    There's got to be something insanly simple keeping this amp from working!
    Still "powers" with led and fan, but no output.....went through all of that rigamarow and got nowhere, essentially.
    Have verified a 2 mV signal getting to it, but still nothing coming out.
  • clause19 Oct 19, 2008
    I have the same problem as you do. I took the amp into a shop and the guy told me it was 2 blown zener diode's. It was like 150 to fix so I said screw it . But im trying to find out where the diodes are in the circuit board.
    Novelist:
  • 77 Answers
Hey cursedknight, I know this is an old post but let me know if you
got your KAC-7202 amp fixed cause I can help you. I have the same amp with some output transistor problems or power supply transistor problems. You can remove the bad transistors that are reading bad and power up the amp and it will work, not all amps will but some. I have an Insignia amp I am workin on and found one bad power mosfet transistor there are 3 per side. I took all 3
on the side that I found the bad one on and powered it up and it worked, but with half the power. Try doing that, if you find one bad
take tall them out on the side you found the bad one on and put power to it. Same thing goes for output transistors. Go to youtube
and type in car amp repair and there are 9 videos of a guy showing you some really good repair tips and also go to www.bcae1.com this guy has all the info and a dvd rom you can buy. On his site there is alot that will help. Good luck
Posted on Feb 02, 2009
  • 631 Answers
If possible return the amp to the seller for a refund (before you tamper with it).
If that's not possible, the amp will need to be repaired. Do you want to try to repair it yourself?
For the head unit, you need to check the shield ground first. The following page will show you how to perform the test.
Shield Ground Test/Repair
Let me know if you have any other questions.
Posted on Sep 19, 2008
  • 13 more comments
  • Perry Babin Sep 20, 2008
    At the top of the page (link) I posted, there are two links to aid in troubleshooting an amp that's going into protection. If the first page indicates that the amp is damaged, read through the second page. The second page will help you find defective components. Let me know if you have more questions.
    The head unit will likely be more difficult to repair. Let's deal with the amplifier first.
  • Perry Babin Sep 21, 2008
    You need to disconnect the amp from the power source and check the output transistors to see if they're shorted. No individual transistor should read near 0 ohms between any if its legs. If you find any that read near 0 ohms, you need to remove them so you can check them out of the circuit.
    The output transistors are Q222-Q229.
    Let me know what you find.
    Check the power supply transistors (Q3-Q8).
    If none of those are defective, the next step would require testing with the amplifier powered up.
  • Perry Babin Sep 22, 2008
    If they read 0.00 in diode check mode between the first and second legs, they're defective. You should pull them to confirm but 0.00 from 1-2 is almost always indicative of shorted transistors.
    When one goes, the rest are likely to fail also.
    It should be a simple repair but there are no guarantees that you will be able to successfully be able to repair it.
    After you get the old FETs out of the board, you need to power up the amp (including remote) and measure the voltage on the solder pad for the first leg of the FETs. They should all read ~4-5 volts. If you read something near 0v, something near 12v or there is a significant difference between the various FETs, let me know. It could indicate there there is more damage.
    The FETs won't be expensive. Don't order them until you check the voltage on the gate pads (described above).
    mouser.com
    844-IRFIZ44GPBF
    If you want a good desoldering pump (one that actually works):
    http://www.mcmelectronics.com/product/21...
    Radio shack has desoldering braid. If you use the RS braid, pick up some of the paste flux also. Their braid isn't always fresh and the paste flux will help it work as it should.
    To clean the board of flux, use acetone and a toothbrush (outside, read instructions, don't use a toothbrush made of transparent plastic, it will melt in the acetone).
    4.3-4.5 is OK.
    Do the FETs you removed read 'open' or '0 ohms' from leg 1 to either of the other legs?
    That means that they are probably OK.
    You tested them in the board and read 0.00v on diode check. Across those same points on the board, do you still read 0.00v?
    What do you think caused you to read 0.00v before and now you're reading well above 0v?
    From the latest readings, it appears as if the amp should work if you reinstalled the FETs. If you do reinstall them and apply power to the amp, do so via a single 15 amp fuse and have the FETs tightly clamped to the heatsink.
    The LED should be red as far as I know.
    If the meter is on diode check, the readings are in volts. If the meter is set to ohms/resistance, the readings are in ohms.
    Those parts are probably OK. They are BJTs, not FETs and you have to check them differently. If none read close to 0.00 on diode check, they're likely OK. Most BJT outputs short when they fail.
    There was a link to a page that shows you how to check most transistors on the basic repair page. Did you follow that link?
    As I said before, I'd reinstall the transistors and power up the amp via a 15 amp fuse. If it doesn't power up, we'll have to check the voltage at various points (meter set to DC volts).
    Use the form on the basic repair page and send me the screen caps.
    When checking, you need to use the correct test procedure. The tests shown are for NPN BJTs and N-channel FETs. For PNP BJTs and P-channel FETs, you must reverse the leads.
    Remember... All transistors clamped to sink and 15 amp inline fuse.
  • Perry Babin Oct 03, 2008
    The 0.00 readings on the power supply FETs led us in the wrong direction.
    There is an IC labeled TL494 (IC5 on the board). Clamp all transistors down and power up the amp. Measure the DC voltage on all 16 pins of the IC and post them here. Place the black meter lead on the chassis ground terminal when measuring the voltage.
How do i reset ***** lights on dash?
You had work done,wherever
How about going back & have it completed
properly
No idea what your trying to tell us
Why is it, that you don't understand what you were told
Obviously the shop can't do what is required & is trying to
make you go away,they may not have a data base or manuals,
to even find out how your vehicle works
Sep 18, 2014 | 2010 Dodge Charger
What is best diagnostic scanner for 2002 Envoy with ses and reduced engine power lights on?
We have discussed this yesterday--- I believe
You need professional help,not keep asking questions
Only a professional scan tool & checking factory info, to
(learn) about your vehicles Reduced Power issue, will get
to finding a problem
I told you to use the internet, to try & find & learn about it
I may have also told you to stop using it until resolved
Aug 11, 2014 | Cars & Trucks
Amp turns on but puts out no sound except for faint noise which dies out after a few seconds.
It sounds like a defective/incorrect AC-to-DC adapter may have caused your problem. These adapter come with different output voltages, AC or DC output and different amperage ratings. AC-to-DC adapters list the polarity of the DC voltage as it relates to the DC power plug and you must match both the devices voltage and power requirements. As for the amp...not working on batteries either, I would suspect output transistors or IC.
May 23, 2014 | Marshall Amplification Marshall MG2FX...
Remote mirrors do not work.
Try using a jumper wire n test light to see if mirror switch is juiced n transmitting power on & off. If no current thru switch, then may change out. If power is transmitting; do same to mirror silanoid, motor. If direct current to motor & no movement? I ld replace motor. If both check out, then start traceing out wire; cuz its got short in it. Best way; if able or find someone u trust& have em use an Ohm meter. It ll let u know if wires are grounding out n if switch or motor good.
Good Luc: BamBam
May 04, 2014 | 2004 Ford Crown Victoria
Samsung Surround Sound & Palsonic TV = no surround sound on TV
Do you have an optical audio output jack on your tv? Some tv's don't output audio from that jack unless you go into the setup menu and turn in on.
Jul 18, 2013 | Samsung Ht-e5500w 2d 3-d Blu Ray Home...
Gas pump
That doesn't tell us enough to help you
You need to take the car to a repair
shop & have it properly diagnosed.
You obviously know that & you know, even if
we could guess correctly,that it has to be fixed
in order to use it & have it working correctly
Jun 08, 2012 | 1999 Ford Contour
I have hp probook 4530s and i can't switch between the two graphics card (ATI and intel)
Hi ,I just bought the sane midel about a week ago, me niether kneew how to switch between graphics card, but i came upon a forum witch belongs to HP itself,
here is the trick to do it,
http://h30434.www3.hp.com/t5/Notebook-Display-and-Video/how-to-change-display-between-inel-hd-and-ati-Radeon/td-p/878217
Re: how to change display between intel HD and ati Radeon Options
09-19-2011 10:14 AM
Instal ATI driver and utility, choose advanced mode in it, choose power, choose switchable graphics method,
i chose manually and not application needs based, Apply & close, on the desktop choose right click and chose configure switchable graphics. Click on high performance GPU (radeon) or Power sawing GPU (Intel HD)
Aug 21, 2011 | Computers & Internet
I am not getting any picture from the tv. dvd and radio is working fine.
press the AV button on the remote control & if it doesn't work, look for the TV button on the remote control; & if it doesn't work again, check the booklet that comes w/ the tv upon purchasing it or bring your tv to where you bought it & make use of the guaranty voucher for them to fix it for free, (try those buttons first before bringing it back to the store).
May 12, 2011 | Televison & Video
Wont turn on
try the following;
disconnect your remote lead, connect the remote terminal to the positive terminal with a piece of wire. If the amp powers up then the remote output from your headunit is at fault. You can connect the remote lead to a switchable live at the headunit end to work around this problem. The amp will switch off when you switch the ignition off and vice versa.
If that doesn't work then there may be a problem with your positive feed so check your fuse (there should be one near your battery where you see the amp cable connect)
If that doesn't work, check how secure your earth lead is, kicker amps use a lot of power so these connections need to made to a clean metal surface. Scrape the paint away if you need to, make sure you have bare metal to connect to.
Lastly, if you have only just installed the amp, check that you have thick enough power cable. As I said before, the amp will draw a lot of current, if the main power cable is too thin then you may not be getting enough current to power the amp.
Hope this is helpful.
May 07, 2011 | Kicker ZX-350.4 Car Audio Amplifier
I bought a 96 jeep cherokee sport & the interior lights only come on for the front passenger door. the three other doors & the hatch dont turn on the interior lights & i cant find any fuse box...
Can you turn on the lights with the Interior light switch?. If a light works, obviously the fuse is good. You will need a wiring diagram and a test light to figure out where to start.
Aug 25, 2010 | 1996 Jeep Cherokee
Kenwood KAC-7202 Car Audio Amplifier Logo
386 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
