Question about NEC-Mitsubishi Nec Display Solutions (CLCD1980SX) (Black) 19 in. Flat Panel LCD Monitor
Entire screen of NEC "MultiSync LCD 1770GX" has horizontal flickering
The LCD monitor seems to have horizontal lines that flicker. It's been doing this for about a month and over time has worsened. Started as a narrow horizontal band across the screen, and over time uncreased in size to now the entire monitor is covered with the flickering lines. It is all in color, and erratic flashes allow me to see groups of color that indicates that the image is still coming through but it just can't be distinguished. Almost appears as two columns that overlap a small bit in the middle.
  • djwren Dec 10, 2008
    Vertical lines in Display and the lower half of the screen jumps/flickers badly. It doesn't seem to have any bad capacitors. Wonder if it could be the image processor or the control board in the monitor.
  • 40 Answers
SOURCE: monitor power shuts off without warning
You might check the filter capacitor on the power supply and see if it is swelling or shorted.
srich
Posted on May 27, 2008
bixnood
SOURCE: flickering pixels
plug it in all the way thats how i did it
Posted on May 17, 2009
SOURCE: NEC Multisync 1770gx lcd monitor goes blank when I move the unit
HI
you must to check the volt at pin 1 of the lcd slot screen you'll get about 3.3 volts if not it can be the problem.
Gilson
flipflopme@gmail.com
Posted on Jun 28, 2009
  • 1121 Answers
SOURCE: NEC 2080 UX - power light flickers - pics of appears broken caps?
you can change these, you need some soldering skills. the monitor is 3 colour sets. so they have same components on the 3 colours. so you take all is leaking out clean the liquid (sulfuric Acid), and replace with a new ones. you find the components in your local electronics stores.
Posted on Feb 09, 2010
budmrtn
  • 11361 Answers
SOURCE: NEC 1980sxi lcd monitor has developed a vertical
That is a sign of bad LCD panel, not much you can do about it, it will get worst with more lines.
Posted on Mar 07, 2010
NEC Multisync LCD 2080UX has a strip that appears on screen after 20 mins use.
Might be from overheating, monitors do overheat sometimes. I had the same issue happening to one of my old monitors and it wasn't fixable unfortunately. I had to replace it and get a new one.
Nov 05, 2013 | NEC MultiSync LCD1810X 18.1" LCD Monitor
White horizontal lines flicker and screen goes off.
check the wiring inside the monitor, pull the sceen out and move the wires with the screen on so you can see when it's working. then tape the wires where it works.
Dec 16, 2009 | Proview PL926WBi 19" LCD Monitor
HI
Gilson
Jun 15, 2009 | Computers & Internet
Screen off center
try updating the latest driver for your video and bios. try connecting your laptop to external monitor
if both of this didnt solve your problem, i suspected you lcd screen is faulty and need to replace.
May 29, 2009 | NEC MultiSync XE21 (White) 21 in.CRT...
Lines in monitor
Yes. If you're a techie, you'll need to replace the "Horizontal IC" some circuitry may be corrupted. Otherwise, my answer would be none, there's no way you can get rid of the 5 horizontal lines on the monitor.
Try degaussing the monitor.
Mar 15, 2009 | NEC MultiSync LCD1765 17" Flat Panel LCD...
I have an NEC Multisync LCD 1770GX monitor. Is it possible for something to interfere with the display? I see screen distortion on and off during the day. It looks like 'snowy' flickering that mostly...
Cables usually give up first. If you can substitute the cable or another monitor try that. If you see the same thing on the monitor, you have eliminated the cable. If you have another monitor you can beg borrow or steal from a friend, try doing that. If the problem still follows, then you have eliminated the monitor and the video card is the only thing left. If your PC has a built-in video card then the motherboard is toast
May 10, 2017 | NEC MultiSync 1770NX 17" LCD Monitor
NEC MultiSync LCD1770NX 17" LCD Desktop Monitor
components starting to fail. unrepairable. buy a new one
Oct 21, 2017 | NEC MultiSync LCD1770NX (Black) (Black,...
Mitsubishi diamondpro 930sb flickering
I have had the same problem with my 991sb and most recently my 930sb. The first was replaced at NEC's expense however on this second one i'm out of luck. I think its a problem with its power inverter. It may be repairable by a tv repair place. I'll be looking into it and let you guys know.
Sep 06, 2007 | NEC Diamond Pro 930SB 19" CRT Monitor
NEC-Mitsubishi Nec Display Solutions (CLCD1980SX) (Black) 19 in. Flat Panel LCD Monitor Logo
309 people viewed this question
Top NEC-Mitsubishi Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
mukhtar21 shaikh
mukhtar21 shaikh
Are you a NEC-Mitsubishi Computer and Internet Expert? Answer questions, earn points and help others
