Question about Panasonic KX-T7453 Corded Phone
Panasonic KX-T7453 default answer ringing line
How do I change the it back so that the default when answering is the ringing line?
  • craigkop800 Sep 29, 2008
    I have a kx-t7630 phone and I wish the calls in to go to the default, so I can just pick the phone
    Craig
  • Panasonic Master
  • 2,460 Answers
Craig From the Idle phone, press PROG 20 ENTER then SEL until the display says Ringing Key and ENTER. Press EXIT to end.
Carl
Posted on Oct 26, 2008
How do you set the phone to automatic pickup a ringing phone line when you lift handset?
If the ringing line is programmed into one of your dss/blf buttons it should answer when you lift the handset. Else, if it is someone else's phone ringing, lift your handset and dial 40. That will only work if allowed in the pbx programming. Hope that helps.
Mar 07, 2013 | Panasonic KX-T7453 Corded Phone
On my KX-T7453 how do I transfer a call to an outside line?
What you said. It has to be allowed in programming, called Call Transfer To outside line. It's done by class of service and programming.
Carl
Sep 13, 2012 | Panasonic KX-T7453 Corded Phone
One line is being answered by Voice Mail without the phone ever ringing. How can I turn this 'auto-answer' off?
You have to check DIL in the 400 series on the 1232/816. This may be done by TRUNK GROUP or Line number. So if it is line one doing this, simply find Day DIL and if it asks for line number place 01. It will show an extension number typically 165. Hit the transfer button then hit the store button. Now this can also be done under intercept with the rings set to 1 ring. That is in the same area and the procedure is the same. You should first find what TG the line is in first, then do this. Now I am sure you want the VM to answer at some point so I would place that in the intercept Day and Night and set it for say 4 rings. By the way, these particular settings are not normally customer settings. I may also advise you to contact someone who can quickly make the changes for you.
To contact me direct, call 585-216-5066.
Aug 23, 2012 | Panasonic KX-T7453 Corded Phone
If I call an extension and they don't answer how do I program the phone so that I can leave that person a message? I'm using Panasonic KX-T7453 Thanks Chris
Press the MESSAGE button. It will light the lamp on the receiving station and when they press MESSAGE it will show that you called.
If you're trying to program "voice mail", then there are specific instructions to setting Call Forward No Answer or just dialing into the VM sytsem and dialing #6 and their extension to leave a direct message.
Carl
Dec 01, 2010 | Panasonic KX-T7453 Corded Phone
HOW DO I GET THE CALLER ID TO SHOW UP ON THE PANASONIC KX-T7453
You need 3 things. CID service from the telco, A TD-193 card in the system, and some programming to make it appear, like a ringing phone or be able to answer the phone after the CID is transmitted.
Which one are you missing?
Carl
Jul 07, 2010 | Panasonic KX-T7453 Corded Phone
How do we change the number of rings before the answering machine picks up?
It depends on how it's forwarded. If you're talking intercept ringing IRNA, then it's system program 203. If you are looking at CF-No Answer, it's programmed in system programming 619 for each extension, or by default in program 202.
These features require a Programming Manual and Installer access to the SYSTEM programming.
Carl
Nov 19, 2009 | Panasonic KX-T7453 Corded Phone
I only want my Panasonic KX-T7453 desk phone to ring when, . . .
press the mode button 5 times and then use the jog dial to get the * down to nothing.
your phone should no longer ring.
Jun 11, 2009 | Panasonic KX-T7453 Corded Phone
Ring tones on KX-T7433
Wow, this is your lucky day :-)
From each phone, press PROGRAM 99 and the INTERCOM or CO buttons TWICE, then dial 1-8 and STORE. (default is 2). You can now make each line and intercom different, or each phone (up to 8) different. After you finish with each phone, just pick up and drop the handset back into the cradle to end programming.
The feature is called Ringing Tone Selection.
Carl
Apr 02, 2009 | Panasonic KX-T7453 Corded Phone
RINGER VOLUME
Go back to that original 7433. Beg, borrow, or steal one of those phones from someone else and plug it back in. Have someone call you on the intercom and make sure the AUTO ANS button is not lit. Does it ring? Now plug in your 7453 and do the same thing. Does it ring?
I think I only had one or two of those models and the ringer is a two step switch (3 positions) OFF LO HI on the side of the phone. Make sure it's set to something besides OFF.
If the phone rings on intercom but not on the outside lines, that's a different problem.
Carl
Sep 05, 2008 | Panasonic KX-T7453 Corded Phone
Kx-t7453
Let's see if I understand you correctly. You want to lift the handset and automatically have it pick up line 1 to make an outside call but it's picking up your last phone line first (example: line 8 if you have 8 lines) This feature cannot usually be changed unless you restrict what lines the specific phone is allowed to use. This is because there is always a chance that a call is coming in but it has not had a chance to ring yet. In an office environment where people are constantly using the phones people would end up answering calls more than you think before the call had a chance to ring. The phone system would think the line is still free. Systems are set up to use the last available line to drastically reduce the chance of that happening.
May 10, 2007 | Panasonic KX-T7453 Corded Phone
Panasonic KX-T7453 Corded Phone Logo
219 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
